The Official Core 2 OverClocking Database *READ 1st Post for Instructions*
keldegar
Where can I get that information from... I see that other people are already in the database without that same information... How did that happen?
its on your box the CPU came in, or on the IHS itself.
UPDATE:
Added: None.
Deleted: None.
Editted: agibby5 (included week and code)
First post reflects current changes. Please REFRESH!
wdn
User Name: wdn
Stability:15 hours
CPU: E6400
OC: 3360
Stepping: 6 B2
Week: L631
Code: B271
Vcore:1.32 volts
Cooling: Air
Cooler brand/model: Zalman 9700 LED
Motherboard: Gigabyte GA-965P-DS3 Rev 2.0
Bios Version: F7
Operating System: XP 32 service pack 2
RAM brand: Corsair CM2X1024-6400C4
RAM rated speed: 6400
RAM actual speed: 840
Latency: 4-4-4-12 2T
Now the 120mm exhaust fan finally arrive and installed in the new build & Speed Fan set up properly. Time to start some serious overclocking. Note 40C CPU temps after 15 hours of stress testing. Less than stock voltage1.32V. Zalman 9700 rules.
wdn
User Name: wdn
Stability:4 hours, 15 minutes
CPU: E6400
OC: 3440
Stepping: 6 B2
Week: L631
Code: B271
Vcore:1.4 volts
Cooling: Air
Bios Version: F7
RAM actual speed: 860
Skell
User Name: skell
Stability: 9 hours 50 mins, Orthos Small FFT's, Priority 10
CPU: E6400
OC: 3200
Stepping: 6 B2
Week: L635
Code: A994
Vcore: 1.4125 volts
Cooling: Air
Motherboard: Gigabyte GA-965P-DS3 Rev 1.0
Bios Version: F9
Operating System: XP 32 SP2
RAM actual speed: 800
Solid as a rock!
AthlonXP
User Name: Athlonxp
Stability: 11 hours+ Small FFTs orthos,
CPU: E6400
OC: 3200MHz
Stepping: 6 B2
Week: L631
Code: B271
Vcore: 1.3 in bios
Cooling: Air
Cooler brand/model: Scythe Infinity
Motherboard: Asus P5B Deluxe
Bios Version: 0804
RAM brand: G Skill
RAM actual speed: 850
Latency: 4-4-4-12
(currently testing 3.4ghz with 1.385 set in the bios)
Blizzfury
I know it's just average and all, but meh :p.
Username: Blizzfury
Stability: 12 hours+ Small FFTs orthos,
CPU: E6400
OC: 3200MHz
Stepping: 6 B2
Week: L632
Code: A184
Vcore: 1.36250 in bios (Had it at 1.350 but failed orthos around 7 hours 50+ mins :( )
Cooling: Air
Cooler brand/model: Zalman 9500 AT
Full Load temp: 50-53c
Idle temp: 39-43c
Motherboard: Gigabyte GA-965P-DS3 rev 2.0
Bios Version: F9
RAM brand: G Skill
Latency: 5-5-5-15
Picture: (click to enlarge)
Verification: http://valid.x86-secret.com/show_oc?id=154494
UPDATE:
Added: Skell, AthlonXP and Blizzfury to the database.
Deleted: None.
Editted: wdn (Reflect new OC: 3440 MHz)
deaNhaycH
Finally got around to posting up here.
User Name: deaNhaycH
Stability: > 7 hours orthos, small FFTs
CPU: E6400
OC: 3702MHz
Stepping: 6 B2
Week: L628
Code: B036
Vcore: 1.5
Cooling: Air
Cooler brand/model: Tuniq Tower 120
Motherboard: ASUS P5B Deluxe
Bios Version: 0711
Operating System: XP x86
RAM brand: GeiL
RAM actual speed: 925.8
Latency: 5-5-5-15
http://img299.imageshack.us/img299/30373/37wk7.jpg
EDIT: Added to database.
wdn
User Name: wdn
Stability:4 hours 30 minutes
CPU: E6400
OC: 3512
Stepping: 6 B2
Week: L631
Code: B271
Vcore:1.45 volts
Cooling: Air
Bios Version: F9
RAM brand: Corsair CM2X1024-6400C4 "with the lousy Promos IC's"
RAM actual speed: 878
Latency: 4-4-4-15 2T
buffbiff21
Here's my entry. I got more left in this chip... believe me. But I want to wait for Water to take it higher.
User Name: buffbiff21
Stability: 5 1/2 hours dual Orthos small FFTs
CPU: E6600
OC: 3600 MHz
Stepping: 6, B2
Week: L626
Code: B089
Vcore: 1.4875
Cooling: Air
Cooler brand/model: Zalman CNPS9500
Motherboard: eVGA 680i
Bios Version: P23
Operating System: XP Pro 32
RAM brand: Corsair
RAM rated speed: 8500
Latency: 4-3-3-8
CPU-z Validation link:
http://valid.x86-secret.com/show_oc?id=154529
UPDATE:
Added: deaNhaycH and buffbiff21 to the database.
Deleted: None.
Editted: wdn (Reflect new OC: 3512 MHz with new bios F9 and Ram speed 839
as well as new Vcore:1.45 volts)
Also a very nice OC by deaNhaycH, wow 3.7ghz on air?!?!
deaNhaycH
Thanks :D
My case is well ventilated, and the tuniq is a very good cooler. It gives me wonderful temperatures :)
Theres another person on 3.7GHz with air, whos also using the tuniq :)
AthlonXP
ok update this now
User Name: Athlonxp
Stability: 4 hours+ Small FFTs orthos,
CPU: E6400
OC: 3400MHz
Stepping: 6 B2
Week: L631
Code: B271
Vcore: 1.385 in bios
Cooling: Air
Bios Version: 0804
RAM brand: G Skill
Latency: 4-4-4-12
http://img355.imageshack.us/img355/4234/34ocva3.jpg
UPDATE:
Added: None.
Deleted: None.
Editted: AthlonXP (Reflect new OC: 3,400 MHz, new Vcore 1.385 in bios)
Gam3Ra
User Name: Gam3Ra
Stability: 4 hours+ Blend orthos
CPU: E6400
OC: 3504MHz
Stepping: 6 B2
Week: L631
Code: B102
Vcore: 1.300 in bios, 1.304 real
Cooling: Air
Cooler brand/model: Noctua NH-U12F
Bios Version: 0910
RAM brand: Patriot
RAM actual speed: 876
Latency: 5-6-6-18
This baby does 3200Mhz at only 1.9V real ;) My ram is almost burned and don't boot at above 1.9V. She is 1x1GB Patriot 6400LL and that is the max of it at that voltage (elpida chips). Good CPU?
wdn
Title should read 8x455=3640
E6400 8x455 = 3640 MHz
User Name: wdn
Stability:6 hours 49 minutes Orthos
CPU: E6400
OC: 3640
Stepping: 6 B2
Week: L631
Code: B271
Vcore: 1.52 volts
Cooling: Air
Bios Version: F9
RAM actual speed: 910
Latency: 5-7-7-20 2T
I believe this becomes the new speed record for air cooled DS3.
Note 48C core temperature after nearly 7 hours of Orthos. Woot
AthlonXP
my chip is virtually the same when ocing, I will try and see if i can get up to around 3.64 myself.
fhpchris
For the 1000x time, lvlarvin's result is fake in the E6600 database.
He cant even run 3dmark over 3.6ghz...
Hausner's was even edited in photoshop, and the color is all off....Come on...
A d o b e P h o t o s h o p 7 . 0
You do not need to use photoshop to resize or save a screen capture...use mspaint for god's sake...
When Hausner comes in here and show's me Pi 32m single/3dmark @ 4300 and Dual 32m @ 4200+, 8m/3dmark @ 4400+ and 1m @ 4450 then I might care to believe him.
My x6800 can only orthos 3.8, yet it can pass 3dmark @ 4100+... If you are orthosing 4100+ then do the math...
well the requirements are 4hours+ in prime or orothos and proof.. showing pics and also a cpu-z link or pic... i didnt add lvlarvin there.. i just took over this db... so i would have to go back old threads to such on what he posted.... thanks for your concern...
wdn
E6400 8x466 = 3728 MHz
User Name: wdn
Stability:5 Hours 30 minutes Orthos
CPU: E6400
OC: 3728
Stepping: 6 B2
Week: L631
Code: B271
Vcore: 1.54 volts
Cooling: Air
Bios Version: F9
RAM actual speed: 932
AthlonXP
wow nice oc man, Yeah once I am done moving all my stuff to my new case I am going to push it up to 3.6 or higher. Honestly though i think 3.4ghz is a good speed for this chip, cant complain with a 1.266 ghz overclock!
deaNhaycH
wdn, those temperatures are absolutely sick for that voltage! Nice overclock.
*takes off imaginary hat*
hotrodj3ff
User Name: hotrodj3ff
Stability: 4.5 hours Small FFTs orthos
CPU: E6400
OC: 3000MHz
Stepping: 6 B2)
Week: L632
Code: A942
Vcore: 1.3250
Cooling: Air
Cooler brand/model: Zalman CNPS9500 AT
Bios Version: 804 BIOS
RAM brand: Corsair
RAM actual speed: 750Mhz
Latency: 4-4-4-16
Z
Zinn
Guest
User Name: Zinn
Stability: 8hours+ Small FFTs Orthos w/ concurrent ATITool artifact scan and RTHDRIBL
CPU: Core 2 Duo E6300
OC: 3304mhz
Stepping: 6 B2
Week: L630
Code: ?
Vcore: 1.425v
Cooling: Air
Cooler brand/model: Zalman CNPS9700
Motherboard: Gigabyte GA-965P-S3
Bios Version: F5
RAM brand: Buffalo
RAM actual speed: 944
Latency: 4-4-4-12
My video card was artifacting, (the alert noise was what got me to come in and turn Orthos off) but the CPU was 100% :)
nooh
@FHPCHRIS,
Dude I too felt that the results given by the guy were untrue but after arguing I saw that it wasn't worth it , before that I had the highest overclock on air and I use the scythe infinity .
People saw I was jealous but I wasn't but wanted to see how he did it. I am using the same board as he is and I think its the worst board I have purchased. Anyway after I gave up with the guy and I found him rude when we asked from him something he owed to us which was proof.
I think the overclock is right but its watercooled and he submitted by saying he used HSF.
Anyway i reflected on this later and I let it go cos it wasn't worth it.
Also he has not stood up for himself which made the matter worse. Its just fair on everyone that people show real results and sufficient proof for the overclocks they submit.
We see patterns and what is expected from a certain so and so component , also the results should reflect this . Now this said lvlarvin did not do this at the time.
This said let the guy be , I lost my overall place at the top on Air because of him but if it made the place more aware of things like this in the future and that it doesnt happen again its good enough.
It was sad that Mentok left his work because of the guy, it was his work and dedication and people should take that in mind and be serious about what they submit.
There are a lot of people putting the time and hard work to get the clocks they get and we should all respect that and not cheat.
fhpchris
If its right, why did he edit/open the picture in photoshop.. why are some of the colors wrong in the picture...
I didnt call that 4.1ghz crap out before, but yes... I am calling it out as fake(clearly so on air, unless he lives in alaska or something) now.
wdn
E6400 8x470 = 3760 MHz
User Name: wdn
Stability:6 hours 9 minutes Orthos
CPU: E6400
OC: 3760
Stepping: 6 B2
Week: L631
Code: B271
Vcore: 1.54 volts
Cooling: Air
Bios Version: F9
RAM actual speed: 940
nooh
I didn't call that 4.1ghz crap out before, but yes... I am calling it out as fake(clearly so on air, unless he lives in alaska or something) now.
One thing that really bugged me when all this happened was why didn't he stick up for himself , also I pmed him three times and not one time did he reply( lvlarvin )
Another thing is I remember mentok writing I will take lvlarvins submitted overclock out so why is it still on?
ziddey
User Name: ziddey
Stability: 23+ hours orthos blend
CPU: e6400 es
OC: 8x450=3600
Stepping: f5 b1
Week: l617
Code: a856
Vcore: 1.59v set in bios, 1.57v idle, 1.52-55v load (can probably do lower but haven't tested yet)
Cooling: water
Cooler brand/model: swiftech apogee
Motherboard: gigabyte ga-965p-ds3 rev1 c1
Bios Version: f7
Operating System: w2k3r2 x86-32
RAM brand: buffalo firestix
RAM rated speed: 800 5-5-5-15 2.1v
RAM actual speed: 900 2.1v
Latency: 5-5-5-15 (can do 1000+ 4-4-4-12 @ 2.3v or better, but not on this motherboard)
http://www.ijib.com/~ziddey/rig.html
http://valid.x86-secret.com/show_oc.php?id=156137
http://img110.imageshack.us/img110/3504/23hr25minorthos8x450555ln5.jpg
L617A E6400 ES 8x450=3600 1.52V | DS3 Rev1 C1 F7
2x1GB D9GMH 1:1 450MHz 5-5-5-15 2.1V
7900GS 710/840 1.5V/2.1V
Apogee | MCW60 | DDC2+Petra | Coolrad 22T | HR05
update: http://img455.imageshack.us/img455/8587/25hr46minorthossmallfftqx5.jpg
less vcore
JonDoms
Haven't seen any 6600 entries recently.
I can't push it anymore without WC.
I have a lot of fans running to cool the NB.
1st P5N-E mobo!
User Name: [TMC]Jondoms
Stability: 4 hours dual Orthos small FFTs
CPU: E6600
OC: 3600 MHz
Stepping: 6B2
Week: L630
Code: B016
Vcore: 1.40 setting in bios +10mv (1.36 from CPU-Z & SpeedFan.)
Cooling: Air
Motherboard: P5N-E SLI 650i chipset
Bios Version: 0202
RAM brand: Crucial Ballistix Tracers
Latency: 5-4-4-12
@ 2.2v in the black slots!
since i am taking over ill do something about it....
well got my new conroe system up.. was bending some games.. stock 8800gtx scored 9,983 in 3dmark06.. gonna try to overclock later on...
will update the db soon in an h our....
nooh
look forward to seeing your overclock. Wish you the best.
I got the same scores for my 8800gtx , we need some dx10 games for that card.
