The Official Core 2 OverClocking Database *READ 1st Post for Instructions*
Discussion in 'Intel Processors' started by videomasterz, Dec 29, 2006.
  1. enginurd
    enginurd [H]ard as it Gets
    21,823
    Jul 17, 2006
    Holy wow... on a quad... NIIIIICE!!!!
  2. setter
    setter Limp Gawd
    193
    Jan 24, 2007
    User Name: setter
    Stability: 8 hrs p95
    CPU: Q6600
    OC: 3.8ghz
    Stepping: B G0
    Week: L803
    Code: A746
    Vcore: 1.512
    Cooling: Air
    Cooler brand/model: TRUE black
    Motherboard: asus p5q deluxe
    Bios Version: 0803
    Operating System: XP SP-2 32bit
    RAM brand: ocz reaper hpc
    RAM size: 2x2gb
    RAM rated speed: 800mhz
    RAM actual speed:844mhz
    Latency: 5-5-5-15 2T
    Voltage: 2.1V
    [​IMG]
    Ive since switched over to a q9550 and reaper 8500 ram, hoping to achieve 4ghz with the new cpu.
  3. ochadd
    ochadd Gawd
    894
    May 9, 2008
    User Name: Ochadd
    Stability: 9hours+ Small FFTs orthos
    CPU: E7400
    OC: 4204
    Stepping: R0
    Week: L917
    Code: A223
    Vcore: 1.425
    Cooling: Air
    Cooler brand/model: Tuniq Tower w/ 45cfm Scythe Sflex
    Motherboard: Asus P5k-E Wifi/Ap
    Bios Version: 1202
    Operating System: XP 32
    RAM brand: Patriot
    RAM rated speed: 6400
    RAM actual speed: 800
    Latency: 5-5-5-12
    http://valid.canardpc.com/show_oc.php?id=581088
    [​IMG]
  4. enginurd
    21,823
    Jul 17, 2006
    4.2Ghz on a $100 CPU... nice.
  5. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    Today June 18, we are launching a very complete and comprehensive Overclocking database we think on the planet so far, We already have over 600 entries taken from the "The Official Core 2 OverClocking Database" found here on [H] http://www.hardforum.com/showthread.php?t=1138241 , and have expanded the database to take AMD and Corei7 overclocks as well.
    As some of you may know mentok1982 started this in July of 2006, and I took over on December 2006, and since 2006 have kept doing the Intel Core2Duo database for 2 and a half years BY HAND! Now with the help and webmastering of "gose", we have made the Overclocking database a Live online database.
    Some new features for this online database compared to the old database include temps for idle and load, longer entry fields for what type of cooling your running, you can sort each column with ease, you can even see a % of overclock you have, with each entry you click you can see picures of the members validation screenshot and even a pic of their system itself. The "Keyword Filter" is a new and easy way to search for anything among the 600+ current entires, like who is using the same cooler as you and so on. A nice new and improved stats page, for example which brand of cooler or even motherboard is the masses using the most. Best of all if your new you can create your own account, make a submission with a validation screenshot of prime95 4+ hours stability, post your overclocking entry, and even edit it if you get new gear, or even add anohter entry for another system.
    NOTE* If you're a current database participant already, and you see your username in the database, PM meXyour email address and I'll link the two together so you can edit your past entries.
    You may also click "Feedback" and leave us some comments on what you would like to see added.
    All this being said I will no longer update the image database on [H] please head over to our online database, to submit and edit your entry.
    We are proud to annouce our new online database located at its new home! :D
    www.cpuoverclockers.com
  6. BUS@THAILAND
    BUS@THAILAND n00b
    51
    Sep 15, 2007
  7. haadij404
    haadij404 2[H]4U
    2,279
    Apr 3, 2006
    thats awesome videomasterz! i just spent a good 30 minutes looking at peoples overclocks and comparing them to mine.
    thats a very useful website. thanks for everything!
  8. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    no problem, you should also thank "gose" he was the mastermind behind the website :D
  9. BUS@THAILAND
    BUS@THAILAND n00b
    51
    Sep 15, 2007
  10. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    got my i7 to 4.3ghz.. will post at cpuoverclockers.com
    [​IMG]
    [​IMG]
    [​IMG]
  11. M.D.Geist
    M.D.Geist Limp Gawd
    256
    Aug 1, 2007
    Hey vidz, I know I should've done this sooner, but oh wellz, better late than never! Ended up getting a newer E8400 with E0 stepping a while back. Here's my results!
    User Name: M.D.Geist
    Stability: 4hours 22mins Small FFTs prime95
    CPU: E8400
    OC: 4.0ghz
    Stepping: E0
    Week: Q840
    Code: A039
    Vcore: 1.2125 in bios
    Cooling: Air
    Cooler brand/model: Thermalright Ultra 120x
    Motherboard: Asus Maximus Formula x38 (non SE)
    Bios Version: 1207
    Operating System: Vista Ultimate 64 sp1
    RAM brand: Corsair Dominator (8500c5df)
    RAM rated speed: 8500
    RAM actual speed: 1000
    Latency: 5-5-5-15
    [​IMG]
  12. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    ^^^ cool thanks alot!! I also see you submitted your entry in the new database as well cool!
  13. StillFunkyB
    StillFunkyB [H]ard|Gawd
    1,386
    Oct 6, 2007
    Suggestion...
    It would be cool if there were colums for idle, and load temps as well.....
  14. NukeULater
    NukeULater Gawd
    900
    Sep 12, 2006
  15. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    ^^^ Thank you sir!! still doing some tweaks to it!
  16. Beezzer
    Beezzer Limp Gawd
    152
    Feb 26, 2009
    Out of curiosity, why aren't there any Q9650's listed in this or the new database?
  17. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    Because noone has submitted a Q9650, want to be the first :)
  18. Beezzer
    Beezzer Limp Gawd
    152
    Feb 26, 2009
    Lol, is that like saying the team that will win is the one that scores the most points? Actually, I'm in the midst of dialing in my overclock, then I do plan on submitting it in the next week or two.
  19. Condor06
    Condor06 n00b
    4
    Aug 11, 2009
    Hello everyone!
    Great thread, thanks very much!
    Well, I have one question:
    Is there some way to find Stepping Info (Week and Code) of my Core 2 Duo processor (Intel E8300) without looking on the CPU box (which I throw out) or on the CPU itself (because he is already mounted on the board)!?
    I want to post my overclock results of my E8300 (and be the first one for this processor), but I can't find Week and Code information (neither one program for system information doesn't show this info's)!
    Thanks in advance!
    Kind regards,
    Stole
  20. NukeULater
    NukeULater Gawd
    900
    Sep 12, 2006
    If I remember correctly CPU-z should show that information.
  21. enginurd
    21,823
    Jul 17, 2006
    AFAIK, they're only located on the box and IHS of the chip itself, and not available through any software.
  22. extide
    extide 2[H]4U
    3,434
    Dec 19, 2008
    Damnit you guys make me mad! My northbridge isnt stable past ~455Mhz without insane voltage.
  23. Condor06
    Condor06 n00b
    4
    Aug 11, 2009
    @NukeULater
    Hm, where did you found that in CPU-z? Maybe you misunderstand, I am talking about Week and Code ("Stepping Info" like there, in thread, videomasterz wrote), not stepping field in CPU-z on "CPU" tab...
    @enginurd
    I am afraid of that!
    Anyway, if somebody still think or know that is possible to see this informations with some software, let me know...
    Thanks for answers!
    Regards!
  24. Condor06
    Condor06 n00b
    4
    Aug 11, 2009
    Post of videomasterz, on page 55:
    YES, he ment THERMALRIGHT ULTRA 120, you can assure for that in this post:
    http://www.hardforum.com/showthread.php?p=1032012155#post1032012155
    I hope this help, you can now correct this value in database... ;)
    Just noticed! ;D
    Regards!
  25. jvz555
    jvz555 2[H]4U
    2,258
    Dec 9, 2008
    VID:1.2875
    Undervolted: to 1.2v and O.C'd to 3.4ghz
    User Name: jvz555
    Stability: 2 weeks/6 hours prime95(not shown here but have tried it)
    CPU: Intel core 2 quad q9550
    OC: 3400mhz
    Stepping: E0
    Week: L835
    Code: B078
    Vcore: 1.2 bios/1.120 windows
    Cooling: Air
    Cooler brand/model: Zigmatec HDT-S1283
    Motherboard: Gigabyte GA-EP45C-DS3R
    Bios Version: F5
    Operating System: XP/Vistax64
    RAM brand: patriot
    RAM actual speed: 400
    Latency: 5-5-5-12
    [​IMG]
  26. BUS@THAILAND
    BUS@THAILAND n00b
    51
    Sep 15, 2007
  27. Condor06
    Condor06 n00b
    4
    Aug 11, 2009
    One more question:
    What is better for DDR2 memory timing settings:
    5-5-4-14
    or
    5-5-5-12
    ie. Is there differences in "priority" between the individually kinds if latencies (CL, tRTC, tRP, tRAS and so on)?
    P.S. System is stable in both cases, memory working on 1000 MHz, and this is the best that I can get from this modules...
    Thanks in advance!
  28. Zoson
    Zoson [H]ardness Supreme
    6,115
    Aug 4, 2001
    User Name: Zoson
    Stability: 24/7 LinX
    CPU: E8600
    OC: 4400MHz
    Stepping: A E0
    Vcore: 1.344v
    Cooling: Water
    Cooler brand/model: AquaXtreme MP-05 SP CPU Block, EK NB-MAX, Swiftech MCW30, Swiftech MCP655b, 3x HWLabs SR-120
    Motherboard: ASUS Striker II NSE 790i
    Bios Version: 805
    Operating System: XP 64
    RAM brand: Patriot
    RAM rated speed: 12800
    RAM actual speed: 800MHz
    Latency: 7-6-6-16-26-1T
    [​IMG]
    [​IMG]
  29. Frito
    Frito Limp Gawd
    254
    Nov 7, 2005
    User Name: Frito
    Stability: 8 hours 2x SP2004 on small FFTs
    CPU: E4500 (2.2 ghz stock)
    OC: 3450mhz
    Stepping: D M0
    Week: unknown (lost box for my cpu)
    Code: unknown
    Vcore: 1.5v
    Cooling: Air
    Cooler brand/model: Zalman 9700 NT
    Motherboard: Gigabyte P35-S3G
    Bios Version: F3a
    Operating System: Windows 7 Ultimate, Ubuntu 9.04 (was stress tested in win7)
    RAM brand: Corsair, Patriot
    RAM rated speed:
    Corsair 6400 (400mhz)
    Patriot 5300 (333mhz)
    RAM actual speed: 345mhz
    Latency: 5-6-6-16
    [​IMG]
    http://valid.canardpc.com/show_oc.php?id=671554
    [​IMG]
  30. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    ^^^ As a reminder please post your results at www.cpuoverclockers.com where the database is easy to access and easy to search :)
  31. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
  32. nismozcar
    nismozcar [H]ard|Gawd
    1,442
    Jun 8, 2007
    nismozcar
    Pentium E6300
    4000MHz
    R0
    1.48v
    Water
    DangerDen TDX
    Asus P5Q3-Deluxe
    2105
    Win 7 x64
    Kingston HyperX
    DDR3 12800
    1600MHz
    9.0,9,9,27,2t
    [​IMG]
    E8400
    4250MHz
    C0
    1.43v
    Water
    DangerDen TDX
    Asus P5Q3-Deluxe
    2105
    Win 7 x64
    Kingston HyperX
    DDR3 12800
    1666MHz
    9.0,9,9,27,2t
    [​IMG]
    E8600
    4500MHz
    E0
    1.52v
    Water
    DangerDen TDX
    Asus Maximus Extreme
    1104
    Win Vista x64
    Patriot
    DDR3 10666
    1350MHz
    6.0,6,6,18,2t
    [​IMG]
  33. blackacidevil
    blackacidevil Gawd
    673
    Oct 1, 2004
    E8700
    4600 Mhz
    E0
    1.44 volts idle, 1.41 load. (damn that .05 vdroop)
    Asus P5E w/ Rampage Formula 0803 BIOS
    lapped Thermalright Ultra 120 Extreme
    Mushkin Redline PC-8000 DDR2 @ 920Mhz 5-5-5-18
    Vista 32bit
    http://valid.canardpc.com/show_oc.php?id=1007284
    [​IMG]
  34. vanilla_guerilla
    vanilla_guerilla [H]ardness Supreme
    5,895
    Oct 3, 2005
    good temps for 1.4v plus. did you lap your cpu?
  35. blackacidevil
    blackacidevil Gawd
    673
    Oct 1, 2004
    No. Probably wont either.
  36. videomasterz
    videomasterz Gawd
    834
    Nov 9, 2006
    As a reminder I'm not updating the database in excel format no more, you need to go to cpuoverclockers.com and register and post your overclocking data there. All users that posted previously have been ported over and if you need your password just pm me and ill take care of it. All credit has been given to previous overclockers :) Thanks!
  37. Thrust
    Thrust Limp Gawd
    482
    Sep 20, 2006
    is there a core i7/i5/i3 version of this database. This is by far the most useful info in regards to overclocking I know of.
  38. damocles
    damocles n00b
    7
    Jan 1, 2008
    hi, i got a question.
    Actually got an q9550@3400 with an Artic cooling Freezer 7 Pro (idle 36,40,37,36 Full 57-61-58-57), if i change the freezer 7 for a Cooler Master Hyper 212 Plus, there will be any lower temp beneffit? i want to do a greater OC.
    Suggestions.
    Thanks
