The Official Core 2 OverClocking Database *READ 1st Post for Instructions*
here's what my E6600 is doing on air w/ an eVGA 680i board w/ 1.38vcore. not too bad w/ 54C load temps running Orthos for 10+ hours ehh?
UPDATE:
Added: Gam3Ra, hotrodj3ff, Zinn, ziddey and [TMC]Jondoms
Deleted: None.
Editted: wdn (OC: 3760, Vcore: 1.54 volts, RAM actual speed: 940, Latency: 5-7-7-20 2T)
ozziegn please follow the format so i can add you thanks....
First post reflects current changes. Please REFRESH!
User Name: Zinn
Stability: 5hours+ Small FFTs Orthos w/ concurrent 2 x Prime95 and RTHDRIBL
CPU: Core 2 Duo E6300
OC: 3226mhz
Stepping: 6 B2
Week: L630
Code: ?
Vcore: 1.41875v (although CPU-Z reports 1.366v...)
Cooling: Air
Cooler brand/model: Zalman CNPS9700
Motherboard: Evga 680i SLI
Bios Version: P24
Operating System: XP 32
RAM brand: Buffalo
RAM rated speed: 6400
RAM actual speed: 920
Latency: 4-4-4-12
This 680i board is more stable (at this speed) than my Gigabyte S3 was at FSB 400, but it won't overclock quite as high...
I see you have VistaUlt there, may I suggest...
VistaHP = Vista Home Premium
VistaHB = Vista Home Basic
VistaBU = Vista Business
By the way, I hope to be the first person to submit a Q6600 overclock on Vista Ultimate. It won't
be long now...
User Name: Jalidi
Stability: Orthos Blend 9+ hours
http://jalidi.dyndns.org/orthosblend.jpg
CPU: E6600
OC: 3007 mhz
Stepping: 6 B2
Week: L632
Code: A399
Vcore: 1.264
Cooling: Air
Cooler brand/model: Shuttle SD37P2 Stock Cooling
Motherboard: Glenwood-DG
Bios Version: 6.00
Operating System: WinXP SP2
RAM brand: Corsair
RAM actual speed: 666
Latency: 4-4-4-8
edit #1: CPU-Z validation link - http://valid.x86-secret.com/show_oc?id=158308
UPDATE:
Added: Zinn (2nd entry), and Jalidi
Deleted: None.
Editted: ziddey (Vcore: 1.50 volts, OS: Windows2003)
I noticed this guide calls for smallfft stability. From reading around, it seems that's the general consensus for testing cpu stability. However, when I went to find my cpu's stable voltage point, 1.44v under load would be 27+ hours stable with small fft. However, the system was still showing general stability, and 3dmark loop would bsod eventually. Testing large fft, it'd always crash after around 2 hours. I pulled vcore up to 1.455v under load and it looks to be stable again. I'm at 4 hours large fft currently, and look to be going strong. Maybe small fft doesn't go high enough to hit all the cache c2d's have.
thanks for the info ziddey im trying to see if my oc of 3420 is stable ont his e6600 but it seems to blue screen about 2 hours in orothos on blend.... im just upping the volrage slowly..since my cpu is idle at 62 C! right now... kinda hot gotta get a better cooler this zalman 9500 is used and the copper looks dull...
yikes! What vcore are you running? Maybe try soaking the base of the hsf in vinegar for a few hours. Should remove the oxidized copper. That or just sand it down a little I guess.
lVlarvin has a great zalman 9500 , 1 of a kind
Ya, RLY!
Photoshop > legit
Clockgen > legit
Its ok, I can pull 8+ hours of 3900+ orthos now. Once my board is modded lvlarvin's result is going to get owned by something legit.
Here we go... Even tough I sold my cpu/ram/mobo, here is a couple of months old results
User Name: Ooztuncer
Stability: small fft's 12.5 hours
CPU: E6400
OC: 3808 mhz
Stepping: 6 B2
Week: L629
Code: A728
Vcore: 1.600 (in bios)
Cooling: Air
Cooler brand/model: TT Big typhoon (lapped to 1000 grit / outside the case with delta)
Motherboard: DS3
Bios Version: F7
RAM brand: OCZ
RAM actual speed: 952
Latency: 5-5-5-15
thanks for the submission Ooztuncer... will update db soon and will also add my oc... it sucks just waiting on a better cpu cooler..the zalman 9500 isnt that great.. :(
Title should read: E6400, 8x481=3848
User Name: wdn
Stability:9 hours 7 minutes Orthos small fft
CPU: E6400
OC: 3848
Stepping: 6 B2
Week: L631
Code: B271
Vcore: 1.58 volts
Cooling: Air
Cooler brand/model: Zalman 9700 LED
Motherboard: Gigabyte GA-965P-DS3 Rev 2.0
Bios Version: F7
Operating System: XP 32 service pack 2
RAM brand: Corsair CM2X1024-6400C4
RAM actual speed: 962
*----Update to post # 70----*
User Name: hotrodj3ff
Stability: 4.5 hours Small FFTs orthos
CPU: E6400
OC: 3200MHz
Stepping: 6 B2)
Week: L632
Code: A942
Vcore: 1.3250
Cooling: Air
Cooler brand/model: Zalman CNPS9500 AT
Motherboard: ASUS P5B Deluxe
Bios Version: 804 BIOS
RAM brand: Corsair
RAM actual speed: 800Mhz
Latency: 4-4-4-15
UPDATE:
Added: Ooztuncer (3rd highest for e6400)
Deleted: None.
Editted: wdn (OC: 3848, Vcore: 1.58 volts, Bios Version: F7, RAM actual speed: 962, 2nd Highest for e6400)
hotrodj3ff (OC: 3200, Latency: 4-4-4-15)
will add my oc soon once i get the tuniq tower 120 in....
the vcore in the bios was around 1.45? cpu-z is showing 1.44 ... my idle temps are 65*C with zalman9500 room temp is around 78 degrees *F .... ordered the tuniq tower120 hopefully itll bring down the temps...
i just decided to sell the zalman 9500 led to whoever wants it... will put it up for sale soon... as well as other cpu coolers i have like the thermalright xp120...
i was able to oc to 3.6ghz but so scared the idle was around 70*C hahahahahhaha
User Name: ilal2ielli
Stability: 17 hours ORTHOS small FFTs
CPU: E6300
OC: 3220MHZ
Stepping: 6 B2
Week: L632
Code: B445
Vcore: 1.325v (CPU-Z reports 1.296v idle, 1.264 load)
Cooling: Air
Cooler brand/model: Arctic Cooling Freezer 7 Pro
Motherboard: Gigabyte GA-965P-DS3 rev2
Bios Version: F9
Operating System: XP32
RAM brand: G. SKILL
Latency: 5-5-5-15
Validation: http://valid.x86-secret.com/show_oc?id=163254
Screenie:
User Name: Crooked Paul
Stability: 5+ hours Orthos small FFTs
CPU: E6300
OC: 3150MHz
Stepping: 6 B2
Week: L629
Code: B083
Vcore: 1.325v
Cooling: Air
Cooler brand/model: Arctic Freezer Pro 7
Motherboard: Gigabyte GA-965P-S3
Bios Version: F8
RAM brand: G.Skill
RAM actual speed: 900MHz
Latency: 4-4-5-11
http://valid.x86-secret.com/show_oc?id=161770
Can I get in with this?
User Name: Rippermac
Stability: 12hours+ Small FFTs orthos
CPU: E6400
OC: 3472Mhz
Stepping: 6 B2
Week: L626
Code: A441
Vcore: 1.46
Cooling: Water
Cooler brand/model: DD TDX
Motherboard: ASUS P5W DH Deluxe
Bios Version: 1707
RAM brand: Buffalo FireStix
RAM actual speed: 868
Latency: 5-6-6-18
UPDATE:
Added: ilal2ielli, Crooked Paul, and RipperMac
Deleted: None.
Editted: None.
Gonna post mine soon got the Tuniq Tower 120 in, my temps went down from 65*C idle to only 55*C idle!!! very good cpu cooler! and room temp is 88*F and e6600 is @ 3,420 mhz
question - when I get my E4300 running should I post results here? I know it's technically not a "Conroe" but where else would I show it off? ;)
CPU: E6300
OC: 3150Mhz
Stepping: 6 B2
Week: L629
Code: B067
Vcore:
  • BIOS: 1.2875
  • Vdroop: 1.24 - 1.224
Cooling: Air
Motherboard: ASUS P5-B Deluxe
Bios Version: 0804
RAM brand: G.Skill 2GBNQ
RAM rated speed: 400MHz (DDR2-800)
RAM actual speed: 450MHz (DDR2-900)
Latency: 5-5-5-15-4-42-3-11-7-13
RAM Voltage: 2.1V
Pic
3DMark06 Score
CPU can go higher, but RAM is at it's threshold. Too bad, but then again...it's not bad:D
Mywish would be ahead and enter your results and your screen shot we will wait the da boss to register it in the database or not. :)
Yeah, and once there were a handful of posts like that maybe a moderator could move/copy them to a new Allendale thread.
well there is a quad core in there.. so i wouldnt mind if you entered your allendale cpu.... but we gotta change the name from conroe overclock database to something more creative such as the intel overclocking database..... or the 65nm overclocking database... something of that sort..... go ahead and post the results... i gotta fix up the excel file alot of ram speeds are mixed up... when i rearranged it....
First E4300 ? :D
User Name: U HAX0R (that's a zero)
Stability: 4hours+ Small FFTs orthos
CPU: E4300
OC: 3006Mhz
Stepping: 2 L2
Week: Q641
Code: A278
Vcore: 1.440
Cooling: Air
Cooler brand/model: Zalman 7700CNPS Al-Cu
Bios Version: F8
RAM brand: G.Skill
RAM actual speed: 890
Latency: 5-7-7-19
http://img.uhax0r.com/oc.jpg
just call it the Core 2 Overclocking Database, then it will include the Quads too.
I second this idea (partly because I'm the guy with the Quad in here :D ). Calling this the Core 2 Overclocking Database would be more accurate, and inclusive, allowing new members of the Core 2 family to feel welcome. You know we are going to start seeing some Q6600s soon, as well as more E4xxx CPUs, so let's make them feel welcome.
hey just an update. i didn't know what code this chip was up until earlier when i reseated the heatsink. it's an A864:
User Name: Justin_Diduch
Stability: 10hrs Orthos Small FFT's
CPU: E6300
OC: 3507
Stepping: 6 B2
Week: L632
Code: B422
Vcore: 1.55
Cooling: Water
Cooler brand/model: EK-Wave LGA775
Motherboard: Gigabyte 965P-DQ6 v2.0
Bios Version: F9
Operating System: WinXP 32
RAM brand: Corsair
RAM rated speed: 1066
RAM actual speed: 1002
Latency: 5-5-5-15
My overclock isn't very good, but for a Asus Striker I think the FSB isn't that shabby.
User Name: chanchan
Stability: 11 Hour Orthos + HDR Test + 3D06
CPU: E6300
OC: 3062
Stepping: 6 B2
Week: OEM don't have box
Code: Ditto
Vcore: 1.35
Cooling: Water
Cooler brand/model: Thermaltake Bigwater 745
Motherboard: Asus Striker
Bios Version: 0802
RAM brand: OCZ
RAM actual speed: 875
Latency: 5-6-6-17
UPDATE:
Added: liveload, U HAX0R (1st e4300!), Justin_Diduch (Very Nice OC! GoodJob!), and chanchan
Deleted: None.
Editted: Zinn updated Code of CPU: A864
User Name: InorganicMatter
Stability: 7 hours of Orthos
CPU: E6300
OC: 2800MHz
Stepping: 6 B2
Week: L637
Code: A854
Vcore: 1.28V
Cooling: Water
Cooler brand/model: ThermalRight SI-120, Panaflo
Motherboard: Intel D975XBX2
Bios Version: 2333
RAM brand: G.Skill
RAM rated speed: PC6400
RAM actual speed: PC8000
Latency: 5-5-5-15
http://valid.x86-secret.com/show_oc?id=165305
Did I do it right? :D
User Name: merlin87
Stability: 9+ hours Orthos
CPU: E4300
OC: 3001MHz
Stepping: 2 L2
Week: Q640
Code: A459
Vcore: 1.44
Cooling: Air
Cooler brand/model: Tuniq Tower
Motherboard: eVGA 680i
Bios Version: P24
RAM brand: Corsair
RAM actual speed: 667
Latency: 5-5-5-16
ORTHOS
CPUZ
How does my memory speeds look? Im still trying to learn. :D
Stock heatsink from Intel. Undervolted it to 1.15 volts and ran orthos stable for 27 hours.
First Post :D
User Name: adunz
Stability: 9hrs+ Orthos. OCCT 30mins
CPU: E6300
OC: 3430MHz
Stepping: 6 B2
Week: L631
Code: A886
Vcore: 1.344V Windows 1.400 BIOS
Cooling: AIR
Motherboard: ASUS P5B-Deluxe
Bios Version: 910
RAM brand: Crucial
RAM rated speed: 8000
RAM actual speed: 980
Latency: 4-4-4-12
CPU-Z Validator
IMG]http://www.octavewebdesign.com/cpu.jpg[/IMG]
very funny. next time you post a photochop you could try to do a little better :rolleyes:
First Post :D
User Name: adunz
CPU: E6300
OC: 3430MHz
Stepping: 6 B2
Week: L631
Code: A886
Vcore: 1.344V
Nice OC there. That's pretty amazing for the voltage you're running :)
Hi Juicestain,
Can you kindly post a screenshot where Orthos is actually running on the screen at the time you take your screen shot and CoreTemp or TAT to show your temps, all on the same screen? And CPU-Z show your memory timings? Like everyone else does to support his entry. Thank you.
It would also be more helpful if you fill in all the text the rules ask for like for. And a single screenshot that shows everything that was going on for that moment in time on your PC -- the screen should be complete, unedited and speak for itself. Thanks.
I got 3440 MHz on 1.4 volts BIOS a few weeks ago with my E6400. So adunz's voltage numbers are consistent.
