mentok1982
- Sep 17, 2004
Astro jubblies.
ibinco said:@ aoki thing is im already using the zalman 9500AT. And have probe readings of 55 @ load. I just think thats way 2 hot for only 1.4vcore. And bios reads 38 idle @ 1.4v .
So thats why im looking into watercooling, want to take this chip to higher grounds and i need water.
ibinco said:I know this is rather offtopic but could some1 help me (a noob in watercooling) give me some advice as with which set to go for my E6600 CPU, as heat is going to be my limiting factor, it runnings hot damn hot! It wiill be the first time ill be using watercooling. Thanks in advanced, no need to spam this thread..please PM me.
aoki said:You can buy a very good air cooler, like the thermalright ultra 120, tuniq tower 120, scythe infinity or noctua nh-u12. It's cheaper, safer and less noisy than a watercooling system!![]()
mascaras said:your joking right???
less noisy ???? not to speak about temps , i got less 10c with my WC than with a scythe NINJA.
My watercoool Kit coast 95
24/7config : E6400@3200mhz @ vcore default
Temps with CoreTemp >>> Core 1 : 32c || Core 2: 35c
Temps In bios >>> 18c
CoreTemp -Temps @ 3200mhz @ Vcore default
regards
Can you tell me a watercooling more silent than an thermalright ultra 120 with a 120 fan @ 1000 rpm. The radiator will have at least 2 fans, add to this the noise from pump and possible vibrations to the box from the pump.
The coretemp shows 77oC while dual priming, but its wrong because I can touch the heatsink and its nowhere close to that.
BillParrish said:OK, cause I got one
http://www.thermaltakeusa.com/product/Liquid/DIY/cl-w0076/cl-w0076.asp
$145 US shipped.
Core temp reads the internal temp diode and you are getting pretty damn hot, my run (posted above) only brought my core temp to 52C. Have you considered the possibiliy your heatsink is not hot might be because it is not conducting heat away from your processor effeciently ? These conroes are not prescott furnaces but even with a 120mm fan you are not moving a tremendous amount of air at 1000 rpm and that heatsink should be pretty warm. I would considere remounting it. Or perhaps that fan is turned up a bit ?
revenant said:shortinin' bread!
whoa... hello nostalgia!
mentok1982 said:I have to type something into my database posts because later I remove the pics, and there
has to be something in the post. You are the first one to comment on one of these random
comments. Congrats!![]()
