sifulee said:
sifulee said:I broke the record thanks to F6
CPU name: E6300
OC: 3556MHz
Stepping: 6 B2
Week: L625
Code: A705
Vcore: 1.5
Cooling: Water
Cooler brand/model: Corsair Nautilus 500
Motherboard: Gigabyte GA-965P-DS3
Bios Version: F6
RAM brand: Crucial Ballistix
RAM rated speed: 6400
RAM actual speed: 1016
Latency: 5-5-5-15
67shelby said:Not this record.....![]()
Overclock- 3589MHz
Stepping: 6 B2
Week: L625
Code: A705
Vcore: 1.475
Cooling: Air
Cooler brand/model: Tuniq Tower 120
Motherboard: Asus P5B-E
Bios Version: 0402
RAM brand: OCZ
RAM rated speed: 7200
RAM actual speed: 1025
Latency: 4-4-4-12
1. Still on Air, really, who needs water with these chips?
2. New Board, new memory, new timings.
3. A 7950GX2 is also installed.
sifulee said:For now!![]()
I'm at 3620 priming right now 45 mins so far at 1.5v![]()
67shelby said:I hope you get it above 3625.![]()
nooh said:@sifulee ,check my temps out.
I have primed the one I am doing now for 1 hour and its stable , its at 3603.89mhz.
I pray it passes four hours cos thats what you need to prove its stable
sifulee said:Lol, I don't think I can beat that. I've ran into the fsb wall now. Btw my 3620 failed prime.
I have a quick question... when your oc fails are you able to go back to the previous speed you was stable with? I can't and I have to reset cmos and start all over. My mobo is very sensitive and I have to oc it very slowly after 500fsb. Also what are you temps like. On water mine is 28-30c idle and 40-53c load using speed fan.
Well best of luck with your oc.
Thanks man for standing by me.Mayhs said:WOW congrats bro! ur so lucky i knew ud do it![]()
Your right its definitely his Vdimm.Then again you never knowNathonius said:1.8v ??? That's not your core voltage is it? Memory voltage maybe...?
Innit man ,I was biting my nails using 1.475Vcorealpha0ne said:There will only be tears if he is using 1.80Vcore ??![]()
