adrift02 said:P.S. How do u get pics to display with ur post? I will edit when I figgure out how bc I have a screenshot of the 6+ prime.
whiskey29 said:By the way, Mentok, is that word mentok comes from a language in SE Asia ?
jamiewa said:wow, your coretemp says over 70c... intel says the chip should only go up to 60c. how are you not concerned?
oozish said:oops, just double checked and my voltage is actually 1.3500; memory voltage 2.15 (nice memory!).
alpha0ne said:Your HZ DDR2 will run @ 4, 4, 3, 7 with only 2.10Vdimm at those MHz![]()
oozish said:I get an error(s) running at that timing(s). My memory is weird it's good to about 960fsb at 4-4-4-12 but finicky about anything else, even with higher voltage. Up to that speed, however, I can run it fine at 2.1. After that even higher voltage (I've tried up to 2.4) doesn't seem to matter.
I start getting more errors before 100%...looks no go to me.
Any suggestions? (this is at 7x450 @ 2.1v)
