Intel_Hydralisk
- Feb 6, 2005
kind of like how PvP is war of the worlds? so tired of hearing the zerg crying about mutas as a P. Impossible to deal with them mutas as a P. Well, not anymore!
Opening with phoenix against Z was NEVER a bad idea. My hardest ZvP matches are against P who open with phoenix. Even if the Z never gets mutalisk, it's a strong build.
The real problem is that people never ever utilize phoenix the way they're supposed to. People assume that anti-air means anti-battlecruiser / carrier / colossus. Phoenix are harassment / map control units. They will outright deny overlords throughout the map and force all the overlords to huddle in the Z's base. Lone queens can easily be sniped. Workers die extremely fast to phoenix.
Phoenix will outright deny mutalisk play. It's not even a matter of how well each player plays. Phoenix is about as close to a hard counter to mutalisk as it gets. I've never ever seen a Z win after phoenix are fielded if the Z continues to make mutalisk. Fielding phoenix forces a tech switch with the initial mutalisk investment completely wasted.
The reason Blizzard made the void ray and phoenix changes is to help people realize that void rays were always meant to be anti big units (they were NEVER intended to be the 'base destroying harassment unit'). The void ray damage change in a previous patch buffed them in combat and nerfed them in base harassment. 1 void ray was never meant to level a main building in less than 20 seconds and be able to get away. Phoenix were simply underused because your average player had no clue how to utilize them. If you can't A click and win, then it's too hard a unit to use apparently.
