robbiekhan
- Apr 13, 2004
Add this to the launch argument in ubisoft launcher:
he has a xbox...
i know its for pcwatch the video maybe?
its for pc, not your xbox.
Thx when i will buy pc , i will be know : )
maybe driver reinstall?There's got to be something seriously wrong with my game. This is what it looks like under both the "ultra" and "outlaw" settings, everything possible turned all the way up. I have no idea why the screen shots look so washed out, the colors and lighting look great but the textures and some of the models are absolute garbage.View attachment 675836View attachment 675837View attachment 675839
try turning off the "cinematic" effects, if you can.There's got to be something seriously wrong with my game. This is what it looks like under both the "ultra" and "outlaw" settings, everything possible turned all the way up. I have no idea why the screen shots look so washed out, the colors and lighting look great but the textures and some of the models are absolute garbage.View attachment 675836View attachment 675837View attachment 675839
but main character is too low res on hes screenI had the same thing happen in the same area. Something about that area causes the game to basically run out of VRAM, and so what you're getting is basically garbage textures/models because the game is at the limit. You just need to reload.
On my 4090, on Outlaw settings at 4K, with DLSS Quality and Frame Gen enabled, I’m doubling my frames with no visual difference - and the game goes from unplayable to smooth.
Incredible tech from Nvidia.
game issueRestarting the game fixed it for a bit but then it happened again when I got to the bar so I think I'm done until they can figure out how to get their game engine to load textures properly.
Have any of you guys played the Avatar game, is that any good. I'm in the mood for an easy open world game and just remembered I got a free copy with my CPU purchase last year and was wondering if it's even worth installing.
It's got nothing to do with my display, the game isn't washed out like that, it was just the screen shot.Monitor is too bright I run everything low as possible for all games.
its fine, stop worryingIt's got nothing to do with my display, the game isn't washed out like that, it was just the screen shot.
If it's just happening with screenshots, what is the issue?It's got nothing to do with my display, the game isn't washed out like that, it was just the screen shot.
Wait, so is this out or are only pre-orders able to play? What about Ubi+? My wife has been waiting for this for a while, so I want her to be able to play ASAP, lol.
Ubisoft+ subscribers can play it now, too.Wait, so is this out or are only pre-orders able to play? What about Ubi+? My wife has been waiting for this for a while, so I want her to be able to play ASAP, lol.
The washed out look of the screen shot, not the texture issue. I was posting about the texture issue.If it's just happening with screenshots, what is the issue?
Are you using HDR (maybe the screenshot tool wash out color in some way not supporting it correctly) ?why the screen shots look so washed out,
Yeah, probably. I don't ever really use the screen shot feature so it's not a big deal, I just needed it in this instance to show the texture issues I was having.Are you using HDR (maybe the screenshot tool wash out color in some way not supporting it correctly) ?
Have you tried that fix ?Yeah, probably. I don't ever really use the screen shot feature so it's not a big deal, I just needed it in this instance to show the texture issues I was having.
So game of the year?
Sarcasm?So game of the year?
The RTXDI just isn't worth the FPS hit IMO. You're better off turning it off for better DLSS/DLAA. Snowdrop engine as it is already is doing such a good job that it doesn't need Nvidia's bolted on BS outside of maybe the DLSS 3.5 features.I turned all of this BLUR garbage off lol doesn't seem necessary.
I'll do thatThe RTXDI just isn't worth the FPS hit IMO. You're better off turning it off for better DLSS/DLAA. Snowdrop engine as it is already is doing such a good job that it doesn't need Nvidia's bolted on BS outside of maybe the DLSS 3.5 features.
You should be able to have all ultra settings and DLSS to quality if you're at 1440 or below on a 4080 if you turn RTXDI off.I'll do that
I'm on a ultra wide display already so I guess I don't have whatever issue this is.If I go from 21:9 to Full Screen the whole games FPS is messed up with Fill Screen which is what they call it 12:9 looks way better.
