Slot 1 & 3 dual channel.. one in orange, one in green.ThatsAgood1jay said:One question thoe. How do you have you rmemory plugged into your mother board?
take pics of your screen in the bios.. We can probably get this resolved.ThatsAgood1jay said:Well this is a real pisser. I figure the memory is under volt`d cause its running at 1.85 volts but i cant change that.
yea.. use a tripod, or set the camera steady on something so it doesn't blur. Turn off the lights if you can't get the screen to be bright enough or visible. Then just snap your picture making sure the camera is perfectly still.ThatsAgood1jay said:How do i take pictures of the bios screen. with a camera? (i know its a noob question but i really dont know)
hah. =) Saved you from buying another mobo or RMA'ing it.ThatsAgood1jay said:OMFG i feel like such a noob of not trying the numlock pads. Thanks for all your help. The comp is wicked fast now.
what stepping, and how does it oc?Jordan1 said:AMD Sempron 64 2800+ Manila
(cf)Eclipse said:what stepping, and how does it oc?![]()
you want a cookie?temporalwar said:WAITING FOR AM2 Opteron's
ThatsAgood1jay said:Whitch out of the current two Nforce 590mcp mother boards is better?.
The foxconn.
http://www.newegg.com/Product/Product.asp?Item=N82E16813186098
Or.
The ASUS
http://www.newegg.com/Product/Product.asp?Item=N82E16813131011
I`m ditching this MSI hunk of stuff.
no-=Antimatter=- said:Wanna loan me $836 ?![]()
w1retap said:Ordered my AMD X2 5000+, Asus M2N32-SLI, 2gb Corsair XMS2-Pro. Should be here sometime this week. Pix when it arrives. ~_~
As requested... =)Darkside said:Yes i want to see that pic...for sure![]()
Leon2ky said:I updated the members list and marked which processors are no longer available, or at least on Newegg.com
