can anybody do close to 500mhz at 1T?
the quads are supposed to drop right into the AM2 socket according to AMD from all their releases I've heard. I would assume a simple BIOS update would do the trick. The AM2+ are for DDR3 memory, are they not? Kinda confusing.
Done, nice OC air or water?
That's air. Arctic Cooler 64 Pro.
I think my mobo is limiting me.. same as the memory.
I'm not sure where to go after this. I need some hardcore advice
for the more seasoned oc'rs.
I was happy when i hit my 1 ghz overclock on air
Run a divider on your memory and see if it's a Mobo limit. Also drop your multi and try, if you still can't raise it it may be a HT limit which may be your CPU not mobo.
Is it safe to have HT run at 1100 ? mine does that stable.
with overclocking, there is one way to find out: change it and find out!![]()
I know that for a fact, i've been trying to read about HT, and what works and what doesn't.. Im just lost a lot of people seem to be afraid to push the HTT past 1000 mhz
What mobo is that on. Im thinking of selling my Tforce 550
