meimeiriver
- Mar 28, 2007
This case is said to host big coolers. But does it fit (in height, for the removable tray) TITAN's Amanda cooler (TTC-NP04TZ)? It's a great cooler; and I want it. But I want the TJ09, too.
the back brace can be removed if needed for the mobo tray to slide in
HahahahaI broke down and picked one up. My TJ-07 was starting to get old![]()
Hahahaha
That's funny cause I ordered mine on Monday. I was wanting one for a long time and since I had a TJ07 without a window I really wanted a nice new Silverstone case with a window to cool my 8800GTX.
Gonna make my TJ07 a server case for my backup / server / HD htcp rig.
As I recall you purchased the TJ07 around the same time I did. So what pushed you over the edge?
go velcro! magnets in a pc = not always a great idea (just keep them clear of your drives)
I have a small rattle in the non-windowed side panel, where the HD area venting is.. I am thinking about taking a glue gun to it and sealing in all the seams.. or something like that so the mesh's bracket doesn't rattle any more.. gah! pretty annoying. I have pushed the mesh's tabs all the way down, as hard as they will go also.. so it's how the bracket attaches to the side panel which is loose.. if I do any gluing of that it will have to be real careful like.. to keep it clean looking.![]()
I was thinking the same thing about the magnets.
Wouldn't be the same true for having a fan so close to harddrives ?
Or are they shielded some how ?
My case came, the cable management was 100 times better than my TJ-07, the airflow appears much improved, and the weight is substantially less IMO.
I will have to post pics, my wiring jobbie is complete and it's incredibly clean.
cant wait to see pics Ockie/JonDoms
i just got mine a little while ago.. did the wiring.. its decent, but still looking for ways to possibly improve it.
Just wondering, I surfed through the thread and I did not find this question/answer combo. I just ordered my TJ-09 (Black w/ Window) and I have 5 HDDs to place in this mother (soon to be six with the Hitachi 1 TB) and I want to know if it is possible to mount the HDDs backwards to hide the wiring. Has anyone doen this? If so how, and pictures please.
One possibility i was wondering about was flipping the cage around within the brackets, so they still slide in fine, but are turned around.
I dunno, just can't wait to touch this thing!
Blocatan (AKA Barracuda)
www.daklan.org
Sorry, other picture didn't come out.
if you have a small screw driver your fine for flipping the hdd cages around..
i found that 24" sata cables would fit perfectly and give you just enough slack to route them a bit better, to bad for me my local place only had 36" ones in stock at the time i went in, may check in again to see if they have any 24" back in stock.
but if you do flip the hdd cage around it is a very tight fit for the cables so i would look into modding the hdd cage to make it better
I do believe stock sata cables shipping with motherboards are only 18" and they are definitely too small. 24" at least is needed. Thanks for the heads up on the locking cables as I was going to get some, guess not now lol.
Is that too small to use? Or too small to route the wires cleanly.
Congratulations on the new case. Have you noticed any issues with it? Mine is very good but I did notice my window is slightly bowing away from the side panel in between where the rivets hold the window to the panel. Convex for sure. Does yours do this? Have you noticed any rattling at all while your system is running with everything in the case? I have, though I have minimized after literally taking the side panel of and mucking around in there at least 30 times since I bought it last month.
Don't worry too much about your wiring job, mine looks nearly identical lol.
I beg to differ on the video card fan however. I find it much too weak. My video card and chipset temps are much higher than they were on my old case which had a 120mm fan on the side panel blowing right onto the pci area. I really miss that about my old case. If I could ever find the patience to get the center fan removed I have a 79cfm aluminum evercool sitting here that I wouldn't mind trying out to see how it fares. Much louder yes but on my Sunbeam controller it wouldn't matter much as long as the airflow was better. With the summer months coming my temps are not what I would like them to be for a case that is suppose to have great cooling for a video card. Cpu and hard drives temps are great however.
They are fine if you dont mind having them come straight across the center fan to the front of the drive cages. If you want to route them through the back you definitely need longer. 24" at a minimum.
Alright thanks. I'll put a longer one on order.
If you look at my pictures 24" is good for the left HDD but 36" is better for the right. This way
you do not have to route the cables through the Fan Vent in the middle of the chassis.
I noticed that with my right hdd and went out and got a 36". It's extra slack let me route the cable above the fan vent and the excess goes into the HDD cage area.
^^^^^ very good post! thanks for the pics....![]()
very nice JonDoms!
I think i found my new case i've been looking for...clean, sexy, and beastly![]()
