Silverstone TJ09!
Wow, those are some really good, sharp pictures. What camera/lens did you use to take the photos?
I spent a nice little bundle on a Canon 50D and haven't taken any photos that look that nice yet because, well, I hardly know my way around that damned thing yet.
here you go
Exif IFD0
* Camera Make = Canon
* Camera Model = Canon EOS 40D
* Picture Orientation = normal (1)
* X-Resolution = 720000/10000 = 72
* Y-Resolution = 720000/10000 = 72
* X/Y-Resolution Unit = inch (2)
* Software/Firmware Version = Adobe Photoshop CS3 Windows
* Last Modified Date/Time = 2008:06:22 14:47:01
* Y/Cb/Cr Positioning (Subsampling) = co-sited / datum point (2)
Exif Sub IFD
* Exposure Time (1 / Shutter Speed) = 1/13 second = 0.07692 second
* Lens F-Number/F-Stop = 4/1 = F4
* Exposure Program = aperture priority (3)
* ISO Speed Ratings = 400
* Exif Version = 0221
* Original Date/Time = 2008:06:22 14:11:51
* Digitization Date/Time = 2008:06:22 14:11:51
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Shutter Speed Value (APEX) = 237568/65536
Shutter Speed (Exposure Time) = 1/12.34 second
* Aperture Value (APEX) = 262144/65536
Aperture = F4
* Exposure Bias (EV) = 0/1 = 0
* Metering Mode = pattern / multi-segment (5)
* Flash = Flash did not fire, compulsory flash mode
* Focal Length = 28/1 mm = 28 mm
* User Comment (Hex) = 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
User Comment Character Code = not defined
* Last Modified Subsecond Time = 00
* Original Subsecond Time = 00
* Digitized Subsecond Time = 00
* FlashPix Version = 0100
* Colour Space = sRGB (1)
* Image Width = 800 pixels
* Image Height = 533 pixels
* Focal Plane X-Resolution = 3888000/876 = 4438.36
* Focal Plane Y-Resolution = 2592000/583 = 4445.97
* Focal Plane X/Y-Resolution Unit = inch (2)
* Custom Rendered = normal process (0)
* Exposure Mode = auto exposure (0)
* White Balance = auto (0)
* Scene Capture Type = standard (0)
Thanks, I'm going to get a TJ09 soon, I'm doubting my PCP&C 750 Silencer cables will reach... they BARELY cleared my P180.
The cables on a PCP&C 750 Silencer will reach with no problems in a TJ-09. I have the Crossfire Edition in mine.
Heres some pics
I'm thinking about getting one of these... Seems like a timeless design, all the hype that came with its introduction doesn't seem to have waned...However, I promised myself I'd only make logical upgrades - seems hard to justify this purchase as my Antec 300 is doing an admirable job... :(
Logic is losing the battle... :)
My new baby:
Where did you get that shelving on the left? And where did you get the rest of your setup for that matter?
I used Canon 40D with Canon EF 24-105mm f/4.0L IS USM.
Canon 40D with EF 24-105mm f/4.0L IS USM. Now..., you've mastered your camera, have you? :D
Now that peeps had this case for some time, how is the dust control considering that this case has no fan filters. I'm still debating on these cases (in no order):
- TJ10
- TJ09
- Lian-li PC-X500
The Lian-li has fan filters which I like, but how is everyone controling dust? If I go for wither the TJ10/TJ09 i plan to have the front and rear fans as intakes and the top fans as exhaust.
Does anyone have an idea where I might find these four aluminum round posts to mount my radiator on top of my Silverstone TJ09 case?
Thanks in advance,
Techlord.
By systemlord at 2010-05-21
I'm committing some major necromancy here, but I want to know if anyone has had success placing fans with filters attached to them in the tool-less fan brackets in the top of the chassis. Since the tool-less fan brackets are designed for fans 25 mm thick, I doubt it would work. Dust is an issue for me because I have more out fans than in fans. I want to put fans in the top to correct that, but it will only work if I can find a way to install some filters up there.
