From the top where the fans mount, to the top of that corner bracket is just a hair over 2 1/2 inches.
As far as removing that bracket and tray sturdiness, I would say that as long as your careful it should not be a problem
do you have the exact specs for the L-brackets and screws you used?
You're going to have problems with a full-size rad up there, bro. You might be able to move the entire radiator assembly toward the front of the case, avoiding that motherboard brace completely. I'd suggest getting a measurement from the front of the top mesh to where that brace starts (from the perspective of looking downward at the top of the case). The distance might be enough to fit a 120.2. You might be able to squeeze a little more if you place the fans against the mesh and mount the radiator so far forward that the hose outlets are underneath the solid part of the top of the case, instead of the mesh.
Hope you understood that garble.
Haha, when I started this thread I had no intentions of buying this case (My TJ06 is only 6 months old!) but today I caved.... with my two 8800s sandwiched together, and no direct airflow to them, buying a TJ09 just seemed to make a lot of sense to me. I'm still a little delirious. PS: I got the silver windowed version off of newegg for 260. Man I can't wait!!!
ah nevermind. from another picture of the same build, it looks like they screwed it through the top vent.
so much for that. painted black L-brackets it is.
got mine Thursday and put my parts in it yesterday. the case is just gorgeous, so beautiful. the cooling is great, and i love how roomy it is inside, easy to do wiring and fit that 8800 GTX in there. also love the slide out motherboard tray, first case to have that and my god, is it about time i got that feature. never going without that again.
only issue i have, the hard drives are exposed, thanks to that mesh there, so they are kinda loud compared to closed cases. that kinda sucks. never realized how loud my drivers were (Seagates).
anyone have any problems with rattling when the side panels are on ?? its kinda a weird buzzing sound that happens from time to time .. and i have to loosen or tighten the side panels .. quite annoying .. other than that i love my tj09
You mentioned the case has good cooling? At the moment I beg to differ. My CPU is cooler in the TJ09 than in my P160 but the GPU and chipset are MUCH hotter.
I agree entirely with that. I was expecting better GPU cooling with this case. My CPU temp has dropped by around 3 degrees but my GPU temp has risen by 2 or 3 degrees compared to my Lian-Li PC60. Overall a far nicer case to work with though and I'll see how it goes with the GPU temps but suspect I may change the case fan to something with a bit more ooooomph.
Here are a few pics of my TJ09B-W:
This shot was taken a couple of weeks ago; the cable management is a tiny bit neater today than it is here.
Thanks for looking!![]()
My GPU temps have dropped back to normal after a re-build. I had to RMA my TJ09 due to non working front USB ports. The replacement works fine and have CPU idle at 32 C and GPU at 54 C. Just need to do a bit more cable management but isn't that always the way![]()
thanks to dutt1113 for letting me use his pic as reference
but i plan to put a thermochill pa120.2 up there
so are any of you guys kind enough to take this measurement for me??
thanks in advance
and is that gfx card cooler removable? the one attached to the left side of the hard drive cage?
Mighty impressive cable-managment.
Interesting how you put your Video card in the second PCI-E slot; I didn't even realize you could boot that way (guess I'm still thinking of the old days).
One question for you, though, or others perhaps. How is the noise and/or dust level? With the side-panel having this huge opening in the middle, can you not hear everything inside? And I figure the case must attract a lot of dust, too, that way.
Still, it looks like the nr. 1 case for me.![]()
here's another one mine (after the crushed one i posted earlier this one came in perfect condition.
Inside: intel 6700 with Scythe Infinity, ASUS P5WDH DELUXE, 4GB Corsair 800mhz RAM, EVGA 8800 GTX ACS3, Creative XFI xtreme music, seagte 300, WD raptor 74, WD raptor 150, Seasonic 700W modular.
nope I dodn't try different position of fan on infinity. I think It might fit on the top but it's pointless beacuse on the top of the case there you can put two more fans. I got it like that and my temps are: CPU around 30 C. Motherboard is also 30 . The hottest drive (Raptor 150) is 32. Another two drives are 25, 27 C. Graphic card temp is 61. Also there is fan between hardrives. Basically I got all 5 fans mounted.
Let me show you all my TJ09. Get ready cause I'm sure you never saw such thing in your whole life. I send it at
19th of December 2006 from Poland (Europe) to Cyprus (Europe). I received it today it's 21 March 2007. Here it is.
Hmmm I guess plane runover it. Well I don't wish anyone such thing to happen with his 400$ !!!
