mritche said:The room has no computers; I have four of them on the opposite side of the wall in another room where their noise doesn't bother me. I put a small hole in the wall for wires.
Nice idea. Very sleek setup.
LittleMe said:It goes with that mousepad to the left of it.
omg i thought i was the only one to have an amp on its side under my desk
kalpha said:Hey mritche, nice tri-monitor setup. Is that run on 2 computers?
CAD OC'er said:
K10 said:here's my setup.
johto said:Gaming with dual is imho kinda stupid, picture is cut just in the middle what usually is the most important area in gaming.
obviously youve never used a dual monitor setup. games never play like that. he just did some 'tweaking' to get them to span across the two. now, if you have a tight dual screen setup w/ two of the same monitors and a graphics card that can support that resolution, then thats a completely different story... :drool:johto said:Gaming with dual is imho kinda stupid, picture is cut just in the middle what usually is the most important area in gaming.
TSS Modder said:obviously youve never used a dual monitor setup. games never play like that. he just did some 'tweaking' to get them to span across the two. now, if you have a tight dual screen setup w/ two of the same monitors and a graphics card that can support that resolution, then thats a completely different story... :drool:
i play w/ dual monitors, and its extremely convenient. play the game on my widescreen lappy w/ trillian xfire, TS, or Vent, or GameComm, and iTunes on the second monitor, allowing me to keep tabs on everything going on.![]()
exactly. (for me) the game will minimize, which can be annoying, but if you leave everything open on the second monitor, nothing will be touched.Warborn said:So what happens when are start up Doom3, for example? It plays on your primary monitor but leaves the second one untouched? Then you can alt-tab between the game and the apps on the other monitor?
TSS Modder said:exactly. (for me) the game will minimize, which can be annoying, but if you leave everything open on the second monitor, nothing will be touched.
im running a setup w/ a widescreen lappy, and that widescreen resolution seems to mess things up for me a little bit, so i cant honestly say that it will minimize on a standard dual monitor setup.Warborn said:Is there any way around that? Can you play Doom3 on your primary monitor and alt-tab into other applications without mizimizing Doom3? Anyone know a setup that allows that?
Warborn
revenant said:I would think having a big center LCD two smaller ones on each side would be cool for a driving game... making the sides the sideview mirrors.. but it might be distracting.Two monitors will never really work for gaming, unless you make one of them your primary, and the other a utility screen or something, but having your field of view broken down the middle is just too distracting. IMHO
barefootbilly said:17" and 2005fpw. The I got the 2005 because the height matches the 17" within 1mm. Too bad it doesn't have an adjustable stand and gets put to shame by the 2005fpw.
towert7 said:Is the FP2005 farther back then the 17" monitor? Because for some reason that picture makes the 20" widescreen look small.
defsquad said:Jokke,
Is that desk an Ikea Galant? I was looking at that configuration, how do you like it? Did you custom choose the rounded end, etc?
I love it. Two brand new monitors, and a 8$ microphoneMad_Dad said:Running Duel 2405's though a 6800Ultra using DVI .... 3820x1200 resolution.
Warning File is 3.1MB
http://www.users.on.net/~stephen_carney/Mad_Dad_Duel2405/MD_LCDs
decoded said:Samsung SyncMaster 903B. Just got it last week. Loving it soooo much. No issues at all.
CSS looks amaizing on it. Sucks that I had to spend 100CND for a DVI cable. Oh well. I'm happy now though. Beats the shitty 17" no name i was using for years :|
lol, the mic works, only used for Ventrilo during online games, though about replacing it, but ah what the heck.towert7 said:I love it. Two brand new monitors, and a 8$ microphone![]()
Good setup on your desk. I just wondering the Dell monitor is 1905FP? or 1704FP the other monitor is it 20inch or 21inch?revenant said:ok, I know this is a little different, but here's the back of my LCD setup after I re-routed the cables through holes I drilled in my desk... it came out nice I think... still have a little cable moving to do, but it's a vast improvement from what I had before...
the cables for the center monitor go down a hole at the back of it's base and route under the back overhang lip of the desk, hugging the top and then through an in port, and back out another hole on the side by the PC which I drilled. It worked out well.![]()
and how much do you think a mic should cost? 50$... 60$...towert7 said:I love it. Two brand new monitors, and a 8$ microphone![]()
