Status Ockie?
Come on people we need to convince him more....
I'm sure Ockie will start Galaxy 5.0. Perhaps he already started and will tell us at a later date
Status Ockie?
yeah I heard he has a prototype already in his basement.
I'm sure Ockie will start Galaxy 5.0. Perhaps he already started and will tell us at a later date![]()
I thought my power was low yesterday!!! Stop draining me lines, Ockie!![]()
"1.21 Jiggawatts"![]()
thats so lame LOL
Ockie, I thought I saw your Galaxy 4.0 on Ebay?!? $20,000 whats up?
Haha, man you guys and your rumors.![]()
Anyways, does anyone know if Mountain Mods makes custom cases?
In all actuality, I would love to see you hook up a kill-a-watt meter and tell us what that thing draws for amperage. Does it have it's own dedicated 20 amp circuit?
They are very expensive and the quality they offer is nowhere close to Lian Li's.
If you insist on going MM, make sure you request them to use thicker aluminum and may be a better mobo tray.
I assume the case alone is going to cost close to $2k.![]()
If you go on the MM site they have a case they built for someone which is basically two cubes on top of each other;
They will do anything. If its gonna be full of disks i would got for something like two cubes next to each other as two ontop would have a very high centre of gravity with disks all the way up.
I beg you to hit the 100 hdd barrierwould be amazing. And 4 PSU's...
Why go for a disgusting amount of hard drives when you are soon able to get 1TB hard drives that are ridiculously fast. You would also save money from the amount of power you would have to use compared to more hd's.
You should look at when this project started, and where he got a lot of his drives
Besides, saving power wasn't his objective here. This is a work log after all. Rational things just don't happen here.![]()
Why not run Linux on it using NFS or Samba to connect to your other systems. I'm sure Linux won't have an issue with mapping 30 drives, unless you're limited by the motherboard. I have not had time to read through all these posts.
These two options are not mutually exclusive. I would recommend both of them.OPTION 4: Custom case. I know a waterjet/laser cutting person now that would cut for free if I wanted to undertake such a task (and supply me with alum at cost). This would be the lesser than the above option but an immense task and a massive case. Also the power consumption I would think would be the greatest here as my drive limitation is endless. With the board selection that I have in mind, thats 64 drive capacity. However, I forsee many problems with such a project. I do have a design idea in mind.
OR
OPTION 5: Sell the replaced drives and use it to fund larger drives. Cheapest option.
My first suggestion would be to make a "mini-Galaxy" that you could take to LANs and such. Of course, you could probably supply just about everything a LAN could need with just a couple drives, so that leaves a bunch left over.
I'd suggest selling the old drives and buying new ones. $500GB drives are now around $100, with 750GB drives under $200. This, of course, won't give you an enormous jump in capacity right now, but it's something I figure you'll probably do eventually anyway.
Out of curiosity, what is the current breakdown of drive sizes in Galaxy 4.0?
why not just build a small Galaxy that can hold like six 1TB drives or whatever your storage needs may be and add it to the network?
then get 20 1TB drives!6 1tb drives would be too small.
Option 3 or Option 5![]()
For the sake of another worklog, I choose option 3
I love seeing your work, the attention to detail is amazing.
30 ftw![]()
LOL, I was hoping deep inside you guys would pick the cheapest option.
Problem with 1tb drives are that they are great and everything, but 750's are half the price, meaning 1tb (1 drive) vs 1.5tb (2 drives), to make matters more interesting is that 500's are less than half of the price of a 750, so for the price of 1tb (1 drive), you can have 2tb (4 drives) for a little less in price. This is why physical space is quite important to me.
In the end, I assume spending the little extra for the larger drives would be worth it, but then when the 1.25's come out, then it's all over again. I just wish I can find the end of all cases and be done with it....
*reports Ockie for [H]ardware porn*
Do you sleep with your computers in your room? I don't see how you wouldn't have a separate room for something like this.![]()
What are the sizes of the drives you currently have in Galaxy 4.0? I.E. if you upgraded replaced all <500GB drives with 750GB drives, how much space would that gain you?
This is the only 48 drive case I could find: I think there is another one out there, but I can't seem to find it.
This? They've dropped the price from $2/GB to $1.50/GB within the last month. What that tells me is they're preparing to move to 1TB disks. It's apparently noisy, but if you're not in the same room with it it's not too bad.
But I'm with you on the noise and heat bit. Here at work we've got probably 20 machines running 24/7 in a 15'x25' room, with no special air conditioning. It's 85 degrees in here all day, every day.
