Please refer to the previous galaxy projects found here
Galaxy 3.0:
The goals of galaxy 4.0:
- To increase storage capacity
- To reduce the noise (aka the first high capacity whisper server)
- To increase functionality
- To modernize it
Multiple phases in this build, phases are below:
Phase 1:
- Replacing the Power supply to two 500 watt PSU's (Why you ask?) Because of noise! The 1KW PSU that I have currently in Galaxy is awesome, however it's quite loud and quite annoying at it too, also, 500w PSU's are much cheaper (MUCH)! Meaning I can use the extra money from the sale to upgrade galaxy in other areas.
-Replacing the Stacker Case to a larger case. (Why?) The stacker is a nice case, however as I have it right now it's a maxed out case. The stacker will be replaced by a PC-343B Lian-Li case, allowing more room for expansion. The Lian-Li case holds 30 drives plus internal drives in the configuration I desire, it also features a power button on the front whereas in the past I had to mod one for the back of the stackers. Oh did I mention I also would have USB and audio ports on the front?!
Not that it matters... but hey, why not
- Replacing the drive cages (Why?) The current supermicro drive cages are awesome, however they are loud and they do not feature a fan speed switch as a couple others do, so this is a driving feature for me. This allows me to turn the noise down much more while still achieving effective cooling. Also, the drive cages I do want features power switches and integrated LEDs, meaning each drive can be independently shut off with the press of a button (power saving too for data I may not use for long periods of time!). The integrated LED is a pretty cool function too, it shows power and HDD reading activity without having the need to run the activity cables! Also, I need more units, so why not just get something new to play with?! Oh yeah, did I add that the units I desire comes with locking SATA cables!?! YAY!
Phase 2:
- Replacing the motherboard, processors, and memory. (Why?) Because with the current move in technology, the current components are out dated and not as effective as new components in my goals. I am planning on replacing the board with an AM2 board and a X2 3800+ as they are dirt cheap and can be cheaply upgraded later on. I would love to have Q-Fan and Cool 'N Quite as it would reduce heat, noise, and power consumption. As this is a private server, there wont be constant access to it so the extra processing power will sit idle, meaning power, heat, and resources wasted. Another big reason for the upgrade is the PCI-e capability
Phase 3:
- Replacing the SATA II Controllers and going with PCI-e controllers, possibly using multilane breakout cables to clear up cable management. I don't know exactly what I want here but it would most likely boil down to two larger PCI-e controllers.
Expected arrival:
Lian-Li PC-343B
Ordering soon:
6 x 5in3 SATA Hot Swap units providing a total drive capacity of 30 drives + Internal mounting space
2 x Power Supplies, silence is what I am looking for and so is functionality, still keeping an eye peeled
Here is a picture of the galaxy 4.0 case
Galaxy 3.0:
- To modernize it
Phase 1:
Phase 2:
Phase 3:
Expected arrival:
Lian-Li PC-343B
Ordering soon:
