unhappy_mage
[H]ard|DCer of the Month - October 2005
- Jun 29, 2004
That's cheap for 24TB of storage. Really, try pricing that from HP. Their system takes up to 12 750GB drives, that's 9 TB. They cost 15 grand each. Multiply by 3 to get up to 24 TB (well, okay, 2 2/3) and that's $40k. Maybe Dell is cheaper? With that system, you can hypothetically get 10 drives; I could only figure out how to get 8, for a system cost of $10,372. Since you need 4 of those systems (32 drives @ 750GB = 24TB) your cost is $41k. I'm sure someone will find a place that has much, much cheaper storage just to prove a point, but my point remains: for $1.50 a gig, the Thumper is cheap. And that ignores the 16GB of memory and 2x285s in there.48k?! WOW![]()
I saw that too, somewhere, but I can't dig it up. It'd be quite the monster. However, 8u cases are anything but manageable. I mean, you could smuggle people in your average 8u case. A bunch of 3u cases with SAS expanders might be a more reasonable way to do things if you need that many drives. The ones linked hold 16 drives, and you could cascade them together. 16TB in 3u isn't terrible density, and you can keep going pretty far with that density.That one is based on the same case concept, there is another one out there and I'm not sure if it's a limited run or what, but it's basically like an 8 stuffed with drives, I believe it was 48 on the front, two on the rear (system drive trays), something like that for a total of 50 drives. I believe it was a little cheaper too, not 100% sure though.
Indeed. I haven't found figures for power consumption yet, but it's only (only - hah!) got 2 1500W power supplies, and they're for redundancy, not 3000 watts. Where I live, 1 kW costs about $1230 per year to keep running (8760 hours per year * 14 cents per kWh = $1226.4) so it'd be pretty expensive to keep running, even before you factor in the cost of taking 1500W of heat out of the air. Ah well, someday.Anyways, that sun server is indeed impressive, I can't imagine the heat that beast would produce... I might be able to omit the need for a home furnace, just pump air from the computer room!Haha.
