Post Your Workstations 2016
Hmm, well this is how the other half lives :(. Temporary desk made out of wooden planks and bricks and, yes, I have pantyhose on my computer air-intakes. I have no shame.
No shame, but you have a Revox R2R!
Nothing wrong with a little DIY solution like cinder blocks and wood sheets. I've seen $10k setups that look like their desk belonged next to a pig's feeding trough.
What matters is that it is clean, which is more than can be said about most workstations. You devoted time and effort to making it look nice given what you had available to you. If it's clean, it means you take pride in it and its deserving of respect from everyone else.:cool:
I guess I could've cleaned up a bit better. This is my temporary setup, probably going to move in the next few weeks, at which point I'll go back to my real desk that I much prefer the look of, a glass top with black accents.
Sorry for the poor lighting.
Hallo to alle you wonderful people out there
Very nice workstaions you all have, so here is my - or should I say our workstations
First is my main rig;
Intel I7-3930K @ 4 Ghz
Phanteks PH-TC12DX
6x4GB Corsair Vengeance Pro 2133Mhz CL9 (24GB total)
Gigabyte X79-UD5 E-ATX
Gigabyte G1 Gaming R9 390 8GB
Samsung 840 120GB
WD Green 2TB
LiteOn BluRay
Apple G5 Case Modded for E-ATX
XFX XXX 750 PSU
The mointor is a Samsung S27E591C
My other is accessories for the main rig are:
Razor Blackwidow Tornament Stealth Edition 2014
Logitech G400 Gaming Mouse (Used for gaming)
Logitech TrackBall M520 (Used for all other then gaming)
Microsoft X360 Wired Controller
Logitech C910 Webcam
Blue Snowball Mic
Razor Kraken Pro Headset
Hauppauge PVR Gaming 2
Running Windows 10 Pro 64Bit
The second computer on the left side is my backup PC
Intel I5-3470
Intel Stock Cooler
1x2GB Crucial 1333Mhz & 1x4 GB Kingston 1600Mhz (6GB Total)
AsRock H61 M-ATX
ASUS DCII HD6970 2GB
SanDisk Z400 128GB
WD Green 250GB
CoolerMaster CM690 II
Corsair VS550W
The monitor is a old LG Flatron W1942T
My other is accessories for the backup rig are:
Lenovo standard keyboard
Microsoft Touch Mouse Wireless
Running Windows 10 Home 64Bit
The rig is the middel are our server rig
Intel I3-2100
2x4GB Crucial Ballistix Sport 1600Mhz CL9 (8GB Total)
Intel DH61BE M-ATX
SanDisk Z400 128GB
WD Green 1TB
WD Green 2TB
2XWD Red 3TB
CoolerMaster CM Force 500
Corsair CX430W
The monitor is a old Eizo S220W
My other is accessories for the server rig are:
Logitech K400 (Keyboard with buildin Touchpad)
Creative T3150 2.1 Speaker
Running Windows 10 Home 64Bit and Serviio as mediaserver
The third rig in the office is my wifes rig:
Intel I7-2600K
4x2GB G-Skill RigjawsX 1600Mhz CL9 (8Gb Total)
ASUS B75-M Plus M-ATX
ASUS Strix GTX970 OC 4GB
Intenso SSD 128GB
WD Green 500GB
AeroCool DeadCube Red Windowed
Corsair HX 620W
My other is accessories for my wifes rig are:
Speedlink Ledos Gaming Mouse
Speedlink Rapax Gaming Keyboard
Creative Draco HS-850
Other rigs in the household are (No pics yet):
HTPC in living room
I5-2300
1x8GB Kingston 1333Mhz CL9 (8GB total)
AsRock H67M-ITX/HT ITX
Sapphire HD7950 3GB Boost
SanDisk Z400 128GB
WD Green 250GB
CoolerMaster Elite 120
Corsair VS550W
The monitor is a old LG 42LG3000 TV
My other is accessories for the HTPC rig are:
Microsoft AIO Media Keyboard
Intel Compute Stick in Bedroom
Intel Z3735F
2GB Ram
32Gb SSD
The monitor is a old Samsung LE32D404 TV
My other is accessories for the compute stick are:
Also, I started on buildning a Retro Gaming 2003 Rig:
Parts so far:
MSI KT6V-LSR Motherboard
Q-Tech 350W PSU
Aopen HQ08 Case
/Mirabilis - Denmark
But why...
Why not?
The only thing I find wrong with the setup is he probably needs to find a way to reclaim desk space with some monitor mounts. The monitor on the far left is running out of space to sit.
I would suggest monitor arms, anchored to either the desk or the wall. Would save a ton of space in this instance, especially if he has some uses that require desk space and only one monitor.
Why not?
yeah that's what I mean. There is no space at all and actually... why 4 monitors?
That is a beautiful case. Love the color scheme.
Case is sitting on (4) large sofa feet. Used a 8ft $30 door from home Depot as a table that I painted w/ Black lacquer, it's ankered to the wall on one side and other side uses a ikea bookshelf. Turned out to be an awesome strong workspace, it's very smooth feeling and I like resting my arms on the table, easier to do large sweeping motions with the mouse.
I'm only running 19 fans ATM, I should probably add one more 200mm on the front panel to hit a even 20 fans total lol :p. It's actually surprisingly quite, It runs eeerly silent with most the fans running close to 500 rpm. Temps are amazing my 980ti@1500mhz runs at 23c idle and 49c load and my i7@5ghz runs at 32c idle and 52c load on air using a lapped hyper 212 w/ a low rpm Gelid push/pull setup.
1x200mm exhaust (front fan, removes hot air from gpu radiator)
6x140mm exhaust (bottom/rear, for gpu radiator and rears for cpu and memory/mobo)
9x120mm intake (top fans, w/ 2 in push/pull on gpu radiator)
Sure are. Currently really enjoying them for what is considered "entry level" bookshelf speakers.
Guess I should'a read your sig more closely. I'm thinking about a pair of Zensors, but it's hard to find them anywhere to audition.
Well, I have moved things around a bit since last year and added some new LED lighting.
For the ambient lighting behind my monitor, I have a Philips Hue Bloom:
Philips 259515 Friends of Hue Personal Wireless Lighting Bloom Single, Retail - - Amazon.com
For the case lighting, I got an NZXT Hue+ lighting kit, so I can change the colors in my case too. :)
https://www.amazon.com/NZXT-Hue-Advanced-Lighting-AC-HUEPS-M1/dp/B018YZ0H1O/ref=sr_1_1?s=electronics&ie=UTF8&qid=1467429573&sr=1-1&keywords=nzxt+hue+
My 2015 Workstation :
My january 2016 Workstation :
Acer Predator Z35... I did not like. Bad TN color and many dead pixels :-$
My actual Workstation :
My "Old" Level 10 updated : Intel Core i7 4790k, SLI GTX 980Ti, 16Go 2666MHz, Raid 0 4x SSD.
Reactions: JMCS
This is my current main system. Just getting ready to tear it down to build the new one. Thought I'd get some shots before I do.
hardly anywhere near as neat or nice as any of you.... but here it is
this is my living room, sold my 144hz monitor to pay some bills, stuck with only usb 15.6" monitor, and a 39" emerson 1080p 60hz tv (with a ungodly long response time...but I still quake)
My new addition to the rack. If you watch Silicon Valley, you'll get it.
What do you have planned?
I'm moving up to a 6800K, X99. HX850i, 32GB DDR4 3000MHz, Noctua D15s, Phanteks Enthoo Pro M, Samsung Evo 950 Pro M.2 SSD and some of the Corsair ML series fans. I haven't decided on a new GPU yet, waiting to see what Vega has to offer and considering the 1060 as well when we have more info. Then I'm moving some parts over like the HDD, optical, and sound card. I'll use the old GPU until I pick a new one. Then I'll move that to my Mame machine.
What board are you looking at for the X99? I have the EVGA X99 Classified and I'm extremely happy with it.
I didn't want to spend much more than about $200 on the mobo, which limited my options. I ended up going with the Asus X99A.
Hers and His gaming station.
Case: Phantek Enthoo Mini XL (Two motherboards, 1 PSU, 1 Case, Love it)
Monitors: LG 34UM95-P 34" Ultrawide
PSU: EVGA SuperNOVA 1300 G2 Power Supply
I have the Water Pump and most of the fans turn on when either switch/motherboard is on. The Phantek Power Splitter is great for this.
Hers:
Motherboard: Gigabyte H97N-WIFI ITX
CPU: Intel I5 4590
GPU: XFX R9 Fury X w/ AquaComputer Full Cover Block.
Memory: Don't Remember
His:
Motherboard: Gigabyte GA-Z97MX-Gaming 5
CPU: Intel I7 4790K
GPU: MSI GTX 1080 SeaHawk EK X
Memory: Can't remember this one either!
