http://img199.imageshack.us/img199/3553/img2444zz.jpg
[IMG]http://img717.imageshack.us/img717/6447/img2442ky.jpg
[IMG]http://img163.imageshack.us/img163/8906/img2441n.jpg
[IMG]http://img703.imageshack.us/img703/8328/img2439vr.jpg
[IMG]http://img824.imageshack.us/img824/3613/img2436y.jpg
[IMG]http://img838.imageshack.us/img838/5407/img2425v.jpg
[IMG]http://img7.imageshack.us/img7/9406/img2415ee.jpg
[IMG]http://img17.imageshack.us/img17/616/img2401l.jpg
Need help. When I turn on my projector, my 24" monitor goes out of portrait mode. When I shut the projector off it automatically goes back, any ideas on solving this??[/QUOTE]
It looks like you're using the EVGA Geforce GTX 560 Ti GPU, correct? And you're trying to connect 3 devices to that one graphics card? Here's the thing. That GPU does support the Nvidia surround technology (3 or more monitors), but you will need a second GPU in SLI with the first one. Even then, that card in sli only supports three monitors, so you can only use three of the dvi connectors. Unfortunately, there are even more requirements. All of your displays must have a common resolution, refresh rate, and sync polarity. So all of your displays must be at 1920x1080 60hz, or whatever your resolution is. So basically, this translates to you can't do what you're trying to do with your current hardware. The reason that you can't use all three ports on your GPU is that the card only has two display clocks. One clock is for one of the DVI ports, and the other clock is shared between the other DVI port and the HDMI port. I know, it sucks, and it's disappointing. I've been there. Here's a link to Nvidia's page on Surround: [url]http://www.nvidia.com/object/3dv-system-requirements-surround-technology.html[/url]
Hope this helps!
I think it may be a Windows' display limitation.@ t3itguy
Thanks for the info, I should have said what hardware i'm using. The 560 is running the Westy and projector as a clone, and the 24" in portrait is running off a nvidia gt220. When i'm just using the 37" & 24" monitors everything is fine, when the projector is turned on and is recognized all monitors work but the 24" in portrait goes back to landscape mode.
@ t3itguy
Hmmm, not so sure on that one. It may be a limitation in Nvidia's driver or Windows's display settings. However, I would go through and check all of your settings in both windows display properties and the nvidia control panel when the projector is on, just to make sure that it's set properly. Honestly, it just sounds like it's not configured properly for when the projector is on.
Here it is updated.
I took the picture with my iPhone 4 so it may not be as sharp or clear but my girlfriend's asleep so I didn't want to wake her up.
http://i4.photobucket.com/albums/y120/jon855/photo.jpg
Your gf is ok with that wallpaper?I took the picture with my iPhone 4 so it may not be as sharp or clear but my girlfriend's asleep so I didn't want to wake her up.
My wife wouldn't be OK with it, but I don't care.Your gf is ok with that wallpaper?![]()
Magpul FTW!
Some of you should grow pair. They are just guns.
Unless you work in a gun shop, they're largely irrelevant to the thread topic. Guns aren't toys. I'm a hillbilly from Kentucky, and have my share of guns. I take them out when I intend to use them.
They're also largely irrelavent to [H] in general.
that is an epic view, would love to have a backyard that looks like that
Gotta get the interwebz![]()
That is a beautiful view. Is that the window behind your monitor? Are there other windows I the room?
^^^ WTF is that??!!!!
It's an actually decent case for what it is. I like the concept though I wished that their rear were actually cut for 120mm fan and not using some shoody adapter - this gave me a bit of headache mounting my H50 on it but I got it on and modified it for my own need.How are you liking the Bulldozer case?
