xfoureyedgeek
- Mar 20, 2002
Hehe, I hope you're getting rid of that BIX.
Yes. I am replacing it with the ThermoChill HE120.3. I am going to ditch the reservoir and add two fillports for filling and draining.
xfoureyedgeek said:Yes. I am replacing it with the ThermoChill HE120.3. I am going to ditch the reservoir and add two fillports for filling and draining.
Finsta said:cornelious,
You're gonna get a NeoPower after all the crap that has been said about them? Heh, what a risk taker you are![]()
cornelious0_0 said:and leave more room for those "down and dirty" cable shots. 8)
Alex41290 said:but yeah, it looks nice on the one side...but can't anyone rate MY cables? lol
Hey, somebody beat me. No fair.cornelious0_0 said:That hurts my eyes.....
Impulse said:Five HDDs...I bet if you put a marble on the top it'll bounce/shoot right off from the vibrations... jk.
What do you do with all that space?
pr0n?Impulse said:Five HDDs... I bet if you put a marble on the top it'll bounce/shoot right off from the vibrations... jk.What do you do with all that space?
Circuitbreaker8 said:![]()
Mine owns you allIts actually cleaner now...i just cant find the charger for my frickin cam. I'm gonna buy 2x white cothode lights ( or blue..cant decide ) and a Cooler Master door w/ window. The front bay is already hooked up ( has an aerogate II, CM drive covers )
Mine owns you all Its actually cleaner now...
n64man120 said:I was gonna paint my interior but it would either be too hard or i'd have to take too much apart
Finsta said:I could learn a thing or two from you two. Heck, I'd really need to. I need suggestions for the side panel fan after I have an idea for that -- I know what to do.![]()
Will do...Does anybody have any ideas for a side panel fan?n64man120 said:lol thanks,
feel free to hit me up on aim if u ever wanna ask me something
I have a window with a side panel and it has a 80mm fan on it. I need suggestions on how to clean it up.n64man120 said:what do you mean, like modding a fan into the side panel? Have any pics of what you are trying to mod
Placement for the fan wire. Everything else I can work out except that one fan.n64man120 said:clean what up? The wiring inside or the fan
n64man120 said:Well your a bit screwed, I would run it in the direction to get it out of view shortest, and then down an edge of the case and around the side. Extend it if needed
My windows spans to the near bottom of the case. What I am thinking is something like this:cornelious0_0 said:Yes, that would be easiest.....straight down teh case out of sight....and then you can get a 3pin extension and route it along the back corner of the case from there.
Well, first I'd unplug the 4pin to 3 pin connector. Then it's all good?cornelious0_0 said:That could work, but you may run into troubles when you try and take your side panel off if the wire is tucked away into a hole and plugged in on the other side of the mobo plate.
What you could do is have the wire run to the back like that, but you coudl be creative and adjust the length of the wire and resolder the plug on the fan so that you can unplug the wire right at the base of the fan, making it easier to get the panel off.
I dunno if that makes sense but.....
Where's the drives?Alex41290 said:after a little more work:
getting close to [H] standars...i can feel it
