Take note of the dedicated Page Up/Down keys on the AAO if you're comparying keyboard layouts too, often overlooked but a pretty huge convenience imo (considering all the scrolling you'll do on these netbooks), particularly where they're placed.
You can buy the AAO with a 6-cell as well now bruce...
lenovo S10, by far the smallest volume of all the 10" netbooks, smaller than most the 9" ones too.
And very limited on what you get... Personally I don't want to buy ANY netbook unless it comes with a 6-cell battery or gets at least 4-5 hours of battery life with what it has... 6-7 is much better.
I just bought one yesterday (Black, 1GB RAM, 160GB HDD for $449 at CircuitCity.com), it should be here by the end of the week. I hear what you're saying about the battery, but I wouldn't say the S10 is limited. They will be offering 6-Cell batteries soon enough, albeit at a price premium, but I'm used to the 45 minute battery life of my T30, so 2-3 hours is an eternity for me.
Hey that ones not so bad. I've only seem them for sale on the Lenovo website... $399 for 512mb ram, 80 gig HDD, 3 cell battery... wasn't such a good deal compared to the Aspire One at ALL.
Edit: There is a review here
Not sure if this is helpful but I made this about a month ago: http://spreadsheets.google.com/ccc?key=pMt8loY0duBjqyiUK506QCg&hl=en
Either way, I doubt it magically ekes out an extra 2 hrs out of the same kind of batteries as the other netbooks, they've got several mish-mash updates that don't quite clarify this but provide a notice of sorts. Then again, after seeing Anand's tests of battery life on the Macbooks with OS X vs Vista I guess anything's possible...
Note: When we first ran the LAPTOP Battery Test the NC10 yielded a runtime of 7 hours and 34 minutes. This was with the Samsung Battery Manager 2.0 enabled, which dims the screen to its lowest setting after 30 seconds of inactivity on the keyboard or touchpad. The screen is usable during this time, but it's uncomfortable. When we ran the battery test at 50 percent brightness with the Battery Manager disabled, the NC10 ran for 6:34; cranked up to 100 percent, it ran for 4:48.
Some teasers of my S10.
that last pic is awesome, it's nice to have a size comparison
I like the look of the Samsung as I think it has a slightly better graphics chip than the norm.
Whislt I wouldnt be playing hyper games on it, it would be nice to know for maybe the odd 3D app and video playback to have a bit more horsepower under the hood.
Even with the battery manager disabled (that dims the screen to absolute minimum after 30 seconds of inactivity), it still gets 6:34 at the 50% brightness that they tested the other netbooks at, which is VERY impressive. And 4:48 on full brightness is no slouch either. Assuming that the battery manager jumps the screen back to normal brightness upon activity, I could see actually using it that way. Not when watching a video, obviously, but when word processing possibly.
I'm all about having options when it comes to battery life, the NC10's solution sounds like a real winner.
when can we buy Samsung NC10?
So i own a 901 eee PC, what is the advantage of the S10 over thee eee PC?
price seems similar, the eee PC has the multitouch touchpad, SSD drive and a 6 cell battery
I have been using the asus 900 for a while now and it has replaced any need for a conventional laptop. These things are great. From the specs I have come across the version i have is basically the smallest form factor around. The 10 inch asus 1000 seems much larger. But either way they are a great buy.
The dell mini 12 is going to be the netbook to beat when it comes out. http://www.notebookreview.com/price...uctFamilyID=1258&Laptop=Dell+Inspiron+Mini+12
i hope the new Intel atom processors are more powerful.
