NCASE M1: a crowdfunded Mini-ITX case (updates in first post)
does anyone know what pump this is?
It's been revealed weeks ago but it's only just available, so your shop isn't lagging far behind but you seem to have lived under a rock :p Or you may just have not cared as much as some of us do :D
Technically it's a C612 (chipset) board, which is geared towards enterprise use. It will be better in some regards but it will also be worse in others.
I live on a rock called Australia, and from the perspective of you guys on the other side of the world/hemisphere, I am therefore under the rock? :p
I guess I haven't really paid attention as I am perfectly happy with my undervolted i5. Was even looking at getting a low power version of an i5 for future builds (if only I could actually buy one here in Aus without ridiculous markup)
Shame to hear the new C14 cooler is 10mm higher. The C14 was so perfect for this case. Even if it needed trimming to fit my asrock z87eitx. Will the dark rock be similar in placement to the C14 (closer to centered above the CPU). From what I remember, the Shadow Rock was more offset to one side?
Black would really make for some great looking builds!
I said it incorrectly, I meant the mainboard (due to the server chipset) is geared towards enterprise.
2 rear USB ports, no audio, two Gbit LAN + IPMI, no official Windows 7, 8 or 10 support, 4x SATA-600 but no M.2 or SATA Express. So I'd not say it's not a big deal for many people if they need a USB sound card and need to use front USB to connect anything more than a keyboard and mouse.
Enterprise boards also have the tendency to take an extremely long time to boot, 2-3 minutes is not an exception. Also the UEFI is the classic blue-gray BIOS without mouse support. I also wouldn't call the memory cheap, that is basically useless outside of this board: http://www.crucial.com/usa/en/epc61...2ab&cm_mmc=CJ-_-2617611-_-7101224-_-Skimlinks
So don't see these as an alternative to the ASRock X99E-ITX/ac because the real user experience isn't.
Good points. :)
I didn't consider the scarcity of USB ports or overclocking an issue since I personally dont usually connect more than 4 things at a time, or overclock much any more.There's a max of 5 USB3.0, and 2 USB 2.0 (2 rear, one on the board, two front + 2 front USB 2) and, assuming the board mounted USB 3.0 works normally you could plug the sound card into that one, and use the rear USB3 for whatever, run a PCI slot USB 2 thing under the GPU and use that for keyboard/ mouse, and front and rear USB 3.0 for whatever.
TIL about the long boot times of server boards, do you know why that is? I'd think you'd want a fast boot time for a server.
Not saying this is a great option, just how it could potentially work if someone was determined to use it. :p
Boot times for servers are less than important, servers reboot very rarely. They need redundancy, so not "restart quickly" but "immediate fail-over". The slow boot times are as far as I know a lot of tests and optimized for stability, not boot speed. So everything is checked before boot to ensure proper hardware basic operation.
I noticed people were curious about the hybrid fitting in the m1 ncase, and I recently made a build that used an H55 and the hybrid in it, that you can see here
I'll just post some of those pictures here as well for you guys to see. If you have any questions about it fitting, let me know. All i know, is the way I oriented it, was the ONLY way I was able to fit it into the case.
There's more pictures on the other thread I made, if you want the higher res photos and all that, go here: https://drive.google.com/folderview...40RVZXMks4TVZVLUNUQlRINWlxQndqbWs&usp=sharing
Nice. First full build I've seen using a GPU with factory-integrated AIO. Cables are reasonably clean as well.
FYI you can switch the AC inlet with the model ID plate so the rad isn't pushing against connector like that. It doesn't look to be a major concern in your build, but the option is there if you want it.
Nice build! I'm thinking of doing something very similar. Do you think the H80i GT would work in place of the H55? It has a thicker rad and stiffer cables so not sure if it will fit. Still debating the 980 Hybrid vs. a Titan X. I would use the stock blower cooler for now on the Titan X. Does anyone have experience running a Titan X in the M1 with stock cooling?
People have done it with the original H80i, though not with both fans. The newer H80i GT has an even thicker rad (49mm vs. the 38mm of the old model), so it would be extremely tight, even with a single fan. Since it's so tight, and since you're limited to only one fan (reducing performance), I really recommend against it. Single fan AIOs with a rad <30mm are a better choice for the M1.
@tblake
I wouldn't recommend using a h80, but I think it's possible on the side opposite the motherboard however.
ALSO If you're considering getting a titan x, you can use the 980 hybrid kit to modify the titan x to a hybrid. It works because it's the same reference design and it's been posted before on an EVGA forum here: http://forums.evga.com/Titan-X-and-980-hybrid-cooler-official-thread-m2327117-p7.aspx
The only thing is your Titan x would have the "980 Hybrid" on the shroud, (you could paint it if you wanted to though).
@Necere
Yeah it's not too bad, but it's good to know i can do that to tidy it up a little more. Every little thing can help make it look more organized especially with the space utilized in this.
@Necere and @Greasy Bacon - thanks so much for the feedback! Sounds like the best bet for a dual AIO solution is Corsair H55 and 980 Hybrid (or Titan X with 980 Hybrid kit).
I'd be willing to try a custom water loop in my build. I have never attempted one before, but am pretty experienced with building PC's. Is anyone aware of a custom loop kit offered specifically for the M1? Barring that a really good build log that I could follow as an example? I am aware of the FrozenQ Reservoir and would use that. Would a single 240mm rad be enough for a non-OC 4790K and a Titan X? I would use Noctua NF-F12 fans. I won't get my M1 tracking number until June 1 so I have time to do some planning. Thanks for any advice!!!
Tom
UPDATE 2015-05-25: will the next M1 be V4 (with changes) or still V3?
A new high performance SFX/SFX-L should be revealed at Computex 2015 and we will make a decision after the announcement. Based on the information we have, there is no need to update M1 V3. However, until the announcement is made, specifications could change. So we will wait and see.
@tblake
I would say in some ways, the custom loop is better than the two AIO coolers.
If you're willing to go full custom loop, you'd probably benefit from it because of everything being cooled by liquid instead of the vram being cooled by the air cooler on it. However the two AIO coolers are nice because of how easy it is, as it's done as soon as it arrives at your door step and then you just plug it in. Depends on how much you're willing to invest and how much time you want to spend doing it.
I haven't messed with custom loops myself, therefore opt'd for the two AIO coolers for convenience and time.
I think it might be how much time/money you're willing to invest into it.
@Greasy Bacon
Yeah, I researched a custom loop and to do it the way I'd want would cost about $550. That's quite a premium over the $170 for the dual AIO approach. I will probably start with that and can always consider an upgrade to a full loop if temps are unsatisfactory or I want the challenge.
One question on your build - why did you configure the fans as exhausts? I would think you would want them as intakes to ensure a positive pressure design? Are you seeing any dust issues? Your build will likely be a model to mine in the near future :)
Thanks!
@Necere
Hey I took your advice and reoriented that power plug now it's a lot easier to put back the side radiator mount, thanks!
@tblake
I actually initially went with intake as well and it was fine until i started playing some games that tested this GPU. However I switched to exhaust because the radiators put out some serious heat (that would otherwise be in your case) when under higher load.
Yes you're correct, the dust would be the only factor making this flawed. However, there is a solution to this.
http://www.demcifilter.com/c220/NCASE-M1.aspx
This site sells filters for every panel side of the ncase m1, so if you went exhaust you can put a filter on every side except the exhaust part, however if you have it intake configuration, you'll only have to put filters on the two intakes. However, this solution is also not perfect, any little cracks that aren't fan filters would also be considered a possible entry point for dust, but I would assume the fan filter entry points would be where most of it is coming from.
It's up to you and how comfortable you feel with hot air always being inside your case versus dust.
I also retook some pictures and uploaded them on the linus tech tips forum here: http://linustechtips.com/main/topic...coolers-in-my-m1-ncase-pictures/#entry5058116
I also have some higher resolution photos on my google drive including an animation of putting the side panel back on here:
https://drive.google.com/folderview...RPVm5LbGJsak8wMkp2eTQ5eGp3ai1mb3M&usp=sharing
Which might be useful because the video card I found only went into the case 1 way and it could be helpful seeing the orientation i have them to better help you fit them if you do this.
Best of luck to you!
@Greasy Bacon - thank you SO MUCH for posting the additional pics and especially the animation! That will be very helpful :) I did order an H55 and the Titan X today so now I'm commited. An EVGA rep on the Titan X/980 Hybrid Cooler thread you linked indicated they should have a Titan X version of the AIO cooler available by the end of May. Only difference will be the shroud. I'll post some pics when I am done. That probably won't be until end of June or so as I am supposed to get my M1 tracking number on June 1. Thanks again!
@tblake
Awesome, good luck dude. Glad to of helped! You'll have good temps and in a small case before you know it!
Be sure to post pics, I really want to see someone else do a build like this, honestly the only other thing that could be better are custom power supply cables to route better for the 24 pin power connector, it could be routed better, and obviously that titan x!
@Greasy Bacon - thanks! One last question - do you think it would be desirable and/or useful to squeeze in a Noctua NF-A9x14 in the rear case position for further exhaust or possibly as an intake? Looks like it would fit. It is something I am considering.
Tom
@Necere
@tblake
Been dying to put a liquid cooler like the one you did to cool my 4790k. I have the Noctua NH-C12PSE14 with their 3000rpm industrial fan and even than the temps go really high. Keep wondering if the H80i GT would fit, given the 49mm thickness.
Question for you: You're using the same industrial noctua fans as me but both you pumps have a 3 pin connector and the fans have a 4 pin connector (a 2000rpm model has 3 pin). How did yopu connect them to the pump connector and do they still have pwm function?
@tblake
If you're able to fit a fan in the back, that'd be even better because then you'd only need 1 fan filter, it'd be best if you can somehow create positive pressure, not sure if you'd be able to with two 120mm exhaust. However if the intake was strong enough it might. It'd be interesting to see if I can fit a 120mm intake on the bottom next to the hard drive and an 90/92mm or 80mm intake on the back as well and see If I can pull off positive pressure with that. I'll see if it fits and take pictures if it does and post it.
Also believe it or not, a non-slim will easily fit (25mm - 30mm), I have a 90mm fan and it fits (width wise) in there. You'd have to fit the small fan in first before you do so however.
I happen to find a random 90mm fan laying around and popped it in for size so you can see, it's not plugged in, but I could easily use a splitter and share a fan slot on the mobo
Link to pictures: https://drive.google.com/folderview...dDSkNFeXp4TjRBZExRc0F5RTRmLXlFbXM&usp=sharing
@grazina
Yes, you can control the pump in the mobo with pwm.
Just so you know, I have 3 motherboard fan controls. 1 is the CPU pump, the 2nd is the CPU fan, and the last is the GPU fan. The GPU pump is getting power from where the blower style fan normally gets power.
I also took some pictures of the 3 pin being plugged into a 4 pin, not sure if you were asking so i posted them anyway.
Check it out here: https://drive.google.com/folderview...d2VVVxZlY0bG5GR3lGUklZU1VQdWFXRjg&usp=sharing
I'm new here. I want to build a new computer soon, and the M1 is an appealing case. The reviews of the Hybrid 980 seem very positive, and it's the GPU I'd like to go with. I still haven't decided between the 4690k and the 4790k.
I'm looking for a quiet cooler than can handle the 4790k at 4.5 GHz that could fit inside the M1. If the forward 120mm position is occupied with the GPU cooler, what's the quietest CPU cooler that can be used?
I don't mind the CPU being on air if that's the quieter solution. I hear that basically all the 120 mm liquid solutions are noisy...
@tblake: @12V the Vantec Tornado pushes about 9mmH2O and 85 CFM (assuming I'm reading the graph correctly...it's a bit convoluted), but it's a bit loud. Their stealth fan is a bit quieter, but only pushes about 1mmH2O. Of course, that's just going by their specs, but should be about right.
Might be good if paired with low airflow high static-pressure fans in exhaust? Dunno, haven't studied fluid dynamics. :/
@Lt Broccoli
I'll tell you, I have the h55, and the hybrid in that M1 ncase, and the loudest thing under full load is the HDD western digital black idle. If that gives you an idea I would hope. The h55 and hybrid have their fans set to around 1000 rpm and it's still quiet and never goes above 55c under full load.
@Nobu
That'd be interesting, If It could be possible to create positive pressure with a little fan in the back without being louder than everything else, that'd be amazing. Otherwise the only way that'd be possible is to start utilizing real estate under the video card which ain't going to happen. (Trust me I tried to fit a 120mm down there with the full size HDD installed). I mean I'd like to be proven wrong that you can fit a 120mm fan at the bottom as well as a full size HDD as well, but I doubt it.
So this arrived you know that it means!
Asrock X99E-ITX/ac arrives tomorrow.
Gonna be maaaaaaaad in the NCASE
@Greasy Bacon
Thanks again for the information! Your pictures are really helpful - I truly appreciate them :) I am kind of shocked that a 25mm deep fan fits in the rear, but that is awesome. From the angle on your new pics it looks like 2 stacked SSDs would fit at the interior front panel position. True? If so I can also get a fan on the bottom of the case under the intake fan for the GPU. I would likely use a Noctua NF-A9 PWM for the rear and an NF-12 SA PWM for the bottom. With those two for intakes hopefully that would be enough to create positive pressure. Then I would only need filters for the top and side (behind MB) of the case. I am going to use an Impact VII mobo which has 4 fan headers, so I would only need to split one of them (5 connections needed including H55 pump). I just need to mount 2 SSD's inside the case so that frees up some options on the bottom. I have mechanical drives but they can all be external to the case. Looking forward to giving it a try!
@Nobu
Thanks for the info on the Vantec fan. It looks interesting but at 38mm deep there's no way it will fit at the rear position of the M1 with this dual rad build. Since I have always had good luck with Noctua fans and I already have them to use for the radiator exhausts I think I'll just stick with that brand.
@tblake
Ah, sorry, mis-read his post, thought there was more space than that. Oh well, probably would have been too loud anyway, even with 5v or 7v, or would have been too little air flow. They do have smaller fans, but they don't list the static pressure for them, and you might as well go with a brand you're comfortable with.
FYI there's no room for a filter on the inside of the right side panel - the SFX bracket is right up against it. Even excluding the bracket, there's only ~1.5mm between the motherboard tray and side panel, while the Demciflex filters are 2.5-2.8mm thick.
The only Demciflex filters I endorse for the M1 are the square 120mm design with the corners notched out, and those are meant for the fan bracket and bottom of the case. The larger rectangular filters were designed by other people, and may not fit well with things like bottom-mounted drives or non-low profile screw heads on the fans.
@DfknG be sure to post pics!
@tblake
Yeah no problem, I really wished there was some info when I was looking up on how to do the build I currently have, so i'm glad to help someone else out that's interested!
Also Necere makes a good point, however, I bet if you really wanted to. You can custom order them to the specific dimensions and have them ordered and not have to deal with those said issues and it'd take into account those little mounts hanging out the bottom of the case with drive mounts and fan mounts etc.
In my opinion, if you're not going to have any full size mechanical drives, you can fit a 120mm on the bottom right side of the case in under the blower fan intake as well as that back 92mm fan, and with filters covering those and the top (top because dust falls and all that, unless your computer is on 24/7) then you should be good!
You have a couple options for SSD mounting, you could definitely fit 2 SSD's on either the bottom under the video card, or behind the front panel with the doubling bracket that came with the ncase. I found this image that perfectly represents what the bracket can do.
It's pretty clever, this guy has one SSD facing down, and the other facing up. I imagine it won't fit unless you do that because of how close they are. Unless you just mount the SSD's in two separate locations.
That's a pic from the prototype testing I did :p It's in the first post of this thread.
