@grazina
Yes, you can control the pump in the mobo with pwm.
Just so you know, I have 3 motherboard fan controls. 1 is the CPU pump, the 2nd is the CPU fan, and the last is the GPU fan. The GPU pump is getting power from where the blower style fan normally gets power.
I also took some pictures of the 3 pin being plugged into a 4 pin, not sure if you were asking so i posted them anyway.
Check it out here: https://drive.google.com/folderview...d2VVVxZlY0bG5GR3lGUklZU1VQdWFXRjg&usp=sharing
Sorry I wasn't clear enough. What I meant was, The noctua fans you're using have 4 pin connectors right? And the fan connector on the 980 hybrid is 3 pin. How did you connect the 4 pin fan on the 3 pin connector? Or are you connecting both fans to the mobo?
P.S - Thank you for the pictures.
@DfknG be sure to post pics!
It's pretty clever, this guy has one SSD facing down, and the other facing up. I imagine it won't fit unless you do that because of how close they are. Unless you just mount the SSD's in two separate locations.
According to the drawing there's 49mm of clearance between board and cooler, while the M1 needs only 46mm to clear the SFX bracket. That's with the bottom fan mounted, which you couldn't do with the the NH-C14. So this cooler is potentially even better than the NH-C14 for the M1
I'm hoping so badly that it'll fit on Asus Impacts without any issues...
Here's the dimensions of the Dark Rock TF, for those who are interested.
It seems like, unfortunately, the mounting system is really awful, but the cooler itself it pretty great, on par with the NH-D15.
http://i.imgur.com/tpSNhLJ.png
According to the drawing there's 49mm of clearance between board and cooler, while the M1 needs only 46mm to clear the SFX bracket. That's with the bottom fan mounted, which you couldn't do with the the NH-C14. So this cooler is potentially even better than the NH-C14 for the M1![]()
So this cooler [Dark Rock TF] is potentially even better than the NH-C14 for the M1![]()
With the (now discontinued) NH-C14, the cooler overhangs the front of the motherboard and the SFX bracket, which prevents the second 140mm fan from being installed on the bottom of the cooler:What's the problem with the SFX-bracket? I've never heard of that before.
Looking at the drawing of the Dark Rock again, it might actually be possible to orient it so the heatpipe ends are pointed towards the rear of the case, which would allow the HDD cage to fit. It seems very tight though, and a few mm one way or the other on the socket location could make or break it.So.. any thoughts if this one might clear the HDD cage?
It appears to be a few mm narrower than the C14, but over 10mm wider than the C12.. so I'm guessing no. And it seems to be 0.8mm too tall for the M1 with its stock upper fan.
He must be using some very low profile connectors on those hard drives, because early on in the M1's design I discovered that orienting the drives that way wasn't going to fit in the width of the case with standard right-angle SATA connectors. I'm actually kind of surprised the cage fits that way, though he did have to remove the front USB ports to get it in.And whoa, why didn't anyone show me this build before..
Beautiful. Hmm.. make room for bigger cooler, or cram 4x 3.5" HDD for a 20TB+ M1?![]()
I have the Noctua NH-C12PSE14 with their 3000rpm industrial fan and even than the temps go really high.
Oh okay. Yeah i just plugged it into the motherboard, even though you can do a jank mod and just cut the little piece in the way of plugging it in. The only reason I didn't do that is because I saw that you can't control the fan speed through that because it's only 2 pin. However even at around 1000rpm under load, it never got above 55c so I don't think i'm going to mess around with it until i start overclocking
I have the same cooler but it is 4670K running at 4.4GHz and with heavy load it stays below 75oC.
Are you doing a huge o/c?
Btw: with low load I set this fan to run at 300 rpm. (very low noise)
I tried searching but it is not working well, so sorry if this has already been answered (I'm sure it has). Is there any chance that the v3 SFX bracket be restocked prior to a future case production run?
No. But the 4th production run is imminent, and we'll be opening pre-orders next week for the first batch that will ship from Taiwan around July 20th.I tried searching but it is not working well, so sorry if this has already been answered (I'm sure it has). Is there any chance that the v3 SFX bracket be restocked prior to a future case production run?
Looks very close for the heatpipes
Yeah, sales did pick up a bit in the last couple months. I fully expect demand to rise and fall at different times of the year, but I think the increased coverage from things like the Linus and HardwareCanucks reviews helped out. There wasn't much of an initial increase in sales immediately after those reviews, but as I've explained to w360, most people only buy a case when they're doing a new build, and they don't do new builds that frequently. They're not going to just go out and buy a case because they saw a review on it - it has to be available and in the public consciousness (in reviews, forum discussion, etc.) when they're ready to build. Awareness + desirability + availability = sales.Nice, I take it the 3rd run sold better than it was doing for a while there?
We're considering changing the fan bracket to SECC (steel) for V4. It's not for strength reasons though - it's to allow us to include a magnetic filter with the case that attaches to the bracket. This is what it looks like on a Lian Li case.are there any proposed significant changes for the 4th run (V4?) that would make another purchase over the V2 worthwhile? i love my V2 but im happy to purchase a V4 to continue supporting Ncase and would probably end up selling my V2 secondhand.
- i think i saw Necere mention potentially having stronger metal on the fan bracket around the screw mounts (which i have had some problems with wear).
