BigMacAttack
- Jan 5, 2006
Its time to get a new mobo then. I can change multi's anytime with either my Asus K8N4-E Deluxe or my Abit NV8. See sig for oc on the s754 3200+ Venice.
noobtech said:I can't overclock my venice more than ~2.4.... on my epox 8npa board. I'm using 1 stick of ddr400 @ 240 and multi at 10 X 2400... it won't let me change my multiplier... if i I change it to 9 or 8 it still says 10 X 2000 when I reboot.
1. Put your RAM on a divider so its nolonger a problem.noobtech said:I can't overclock my venice more than ~2.4.... on my epox 8npa board. I'm using 1 stick of ddr400 @ 240 and multi at 10 X 2400... it won't let me change my multiplier... if i I change it to 9 or 8 it still says 10 X 2000 when I reboot.
1. Make sure your HTT multi is down at 3x instead of 4x so your HT link stays under 1000MHz.DuffMan72 said:I can't seem to overclock my Sempron 64 2800+ over 250fsb. At 250, it is somewhat unstable too.
Sempron 2800+ (@ 2.00ghz, 250fbs, 31 celcius according to everest/speedfan/msi core center)
512MB ddr400 ram (@166mhz)
MSI K8N Neo v2.0
Even when I set my memory to 133mhz, I still cannot get over 250fsb.
MSI K8N Neo v2.0
Anyone know the problem? Could it possibly be badly set memory timings?
you should try 3 too, some chipsets tend to have wierd issues with 2x HTDuffMan72 said:The HT link is the hyper transport frequency, right? Mine is currently set at 2. I'm going to try lower.
If your HT Link is under 1000MHz, and your ram is on a divider, the only other thing it could be is lack of voltage going to youre processor...Unless your motherboard is topping out (I doubt it).DuffMan72 said:The HT link is the hyper transport frequency, right? Mine is currently set at 2. I'm going to try lower.
See my sig for some voltageDuffMan72 said:Got it up to 305 without any issues. I'm not sure if I want to raise the voltage, as the only option I have besides default is 1.55v and above. The chip runs at 1.4 volts according to CPU-Z (though, oddly enough, it runs at 1.45 when it's not overclocked).
It evens runs between 28-31 degrees idle, stock cooling. These chips rock![]()
i wasn't aware.BigMacAttack said:Also, (cf)Eclipse runs his Sempron at 1.7v 24/7 with no problems. You certainly don't need to be afraid of 1.55v even with the stock hsf. If you want/need to go higher than that you'll need to invest in a better one.
Sorry Eclipse. I thought you had been running the old s754 Sempy at 1.7v 24/7, not the new AM2. Sorry if I spoke out of turn. BTW - I have enjoyed your eval of the AM2 Sempron. Good stuff.(cf)Eclipse said:i wasn't aware.![]()
1.65v would probably be the max i would do for 24/7.. 1.7v should be fine for benches
plus, this chip doesn't have a 24/7 speed yet. haven't even had it for a week yet
and yay.. 1 year![]()
BigMacAttack said:Sorry Eclipse. I thought you had been running the old s754 Sempy at 1.7v 24/7, not the new AM2. Sorry if I spoke out of turn. BTW - I have enjoyed your eval of the AM2 Sempron. Good stuff.
Personally I run my A64 s754 3200+ Venice at 1.66v (1.69 as reported by CPU-z) when I have the machine powered up. I don't leave it on 24/7 but sometimes play a 4 hour game session with no problems. Good cooling is key to running the higher voltages.
my 3400+ sempron is pretty cool at stock speeds, but is a furnace once pushed to the limitEmission said:They say people are getting really low temps with the AM2's, around 15-25C range for the lower range. And from what iv'e heard they overclock like mad. I wanted to get the A64 3000+ Orleans AM2 and give it a test drive but I don't have cash. Anyone willing to donate?![]()
it's impossible to cool anything that outputs heat to 0 c/w unless they're doing phase(cf)Eclipse said:my 3400+ sempron is pretty cool at stock speeds, but is a furnace once pushed to the limit
though 15c sounds a little low, as it's a touch under normal room temp at 59f![]()
Unknown-One said:Thermal diodes gain resistance the warmer they get. By simply sauldering across the thermal diode, the fan should run at full speed.
Heck, even just drawing all over the thermal diode with a pencil might do the job, just as long as it shorts across it.![]()
Emission said:You have to take into account that the NewCastle is 130nm. Those process types tend to run hotter, espeically the AMD variations.
I have taken both my 3000+ and 3200+ Venices to just over 1.7v on air but not for any longer than 2-2.5 hours. Funny thing is, when volts are up around 1.66-1.7 the temp doesn't seem to go up all that much. Running full load under Prime95 I notice temps in the 55C-57C range on air when running at those volts. Gaming temps don't get that high, though. Temps while gaming are in the lower 50's.Yeah - that does seem to be the case. The s754 Venices seem to need to be jolted quite a bit to get up over 2.5. Mine will do 235x11 @1.48v but it needs 1.66v to get to 246x11. Thats quite a jump
