LIAN LI PC-V350 !!!
Discussion in 'Small Form Factor Systems' started by emax, Jul 14, 2007.
  1. conraddungan
    conraddungan n00b
    5
    May 9, 2010
    Pictures of my Lian Li v351 (old parts but still kickin'). Did a hell lot of work for me to accomplish (particularly making assumptions an praying that the Mjolnir concept would actually fit :cool:)
    The concept actually revolved around the Xigmatek Thor's Hammer cooler since among all other tower coolers, it has the most sinister form (well taste is subjective :p) I wanted it to appear that it was running on passive form when in reality it is cooled by a very thin Scythe Fan.It was a miracle that it fitted because if ever the depth of the Scythe Slim fan was more than 12mm, it won't actually fit.
    My Specs:
    Intel Core 2 Quad Q9550 overclocked 24/7 to 3.4GHZ
    8Gb (4 x 2GB Team Xtreem Dark Cl4 DDR2 800mhz)
    DFI Lanparty P45 Jr. T2RS
    Corsair HX620w
    Leadtek Winfast NVIDIA GTX 285 1024MB
    Western Digital Caviar Black 640GB 64mb Cache
    Xigmatek Thor's Hammer (yes that's right, I successfully fit the hammer on our chassis)
    3 x Xigmatek 120mm XLF fans at 89cfm each :p
    Scythe Slimfan (120 x 120 x 12mm)
    Modified Lian Li v351b
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. xveganx
    xveganx [H]ard|Gawd
    1,052
    Aug 27, 2004
    Just an FYI for everyone wondering.....
    REV2 5870's with the plugs on the back will fit without modding. The cable does rest on the metal fan protector thingy but I had no problems with it.
    A Corsair 850HX will also fit without modding but it is a TIGHT fit, all connectors need to be on before installing.
    Also you can get almost another inch of clearance on the gpu if you pop the fan out, put the fan grommets and screws on the other side and slide the fan in on the backside of the holder thing. Just a thought for people that may be tight for space for whatever reason.
  3. ebolamonkey3
    ebolamonkey3 [H]ard|Gawd
    1,234
    Sep 2, 2008
    Hey guys, I just finished building my computer in the v351 and it is running real warm, too hot for my tastes. The CPU is idling at 60C and GPU at 55C. What are you guys using for your heat solutions? I don't really want to mod the case or go to water cooling (that's why I didn't go with the Noctua U9B cooler). Right now I have a Phenom II X6 and a Radeon 5850 in there, as well as 2x Samsung Spinpoint F3 hard drives.
  4. fochkoph
    fochkoph [H]ard|Gawd
    1,613
    Nov 23, 2008
  5. zerodeefex
    zerodeefex Limp Gawd
    264
    Apr 8, 2008
    Any of you guys know where I can get replacement screws? I had an unfortunate mix up and need to replace them all now :(
  6. Kr1z
    Kr1z [H]ard|Gawd
    1,287
    Nov 1, 2007
    Jesus... been trying to find the final file for the V351 cut out to send to that cutting company...
    Any one know where I can get this or any member here on hard or another forum that could make that custom blackplate?
  7. WiLLiSTER
    WiLLiSTER 2[H]4U
    2,702
    Mar 24, 2008
  8. mezstah
    mezstah n00b
    1
    Dec 8, 2009
    I have modified my front i have a version of the backplate which is good.
    [​IMG]
  9. Tremeloes
    Tremeloes Limp Gawd
    224
    Nov 26, 2007
  10. kysl
    kysl n00b
    2
    Jan 21, 2009
    can you pls post a link or copy of your working backplate?
  11. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    So can one get a custom backplate still made?
    I still like the look of the 351 vs 352...
    -Nigel
  12. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    What model are those front 120mm fans? I can't read the label on them.
    Thanks,
    -Nigel
  13. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    What fan is on the CPU cooler and on the front of the pc?
    Thanks,
    -Nigel
  14. Machine-code
    Machine-code [H]Lite
    109
    Mar 30, 2010
    The fan is Noctua. So is the heatsink.
    I really need to pick up the NH-C12P SE. It fits perfectly in the 350.
    I'm currently using a CoolerMaster Gemini II and it sucks on my 920. The heat pipes practically burn my hand after playing BC2 for an hour and that's at STOCK.
  15. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    Do you know the fan sizes for the front. I noticed that they have different width and want to make sure I grab the correct 120mm ones.
    I am looking at the NH-C12P SE, so you think go with that rather than what you currently have?
    -Nigel
  16. Machine-code
    109
    Mar 30, 2010
    The case uses standard width (25mm) 120mm fans.
    I think he's using these in the picture because there are 7 blades:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835608009
    IMO, the NH-C12P SE is still the best heatsink for this case because it cools very well and it fits without modding and on most motherboards you can still slip the tray out with it installed.
    The tower heatsinks cool a bit better buy you have to do some serious modding to move the PSU to the other side.
    The Corsair H50 also works well but you have to do a little modding to get the fan to fit at the front of the case. However, from what I have seen, it doesn't really cool any better than the NH-C12P SE.
  17. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    Awesome!
    Thank you for the help!
    I wish someone would make and produce those custom backplates post earlier... thats' the only thing that I really want on the 351 with the fan and psu swapped... I was going to get the 352 for that reason but can't stand the front of it and the rear external 80mm fan.
    -Nigel
  18. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    Where did you get the heat sinks for the memory?
    I can't find anything like that... just normal heat spreaders..
    Thanks,
    -Nigel
  19. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    Where did you get the mesh at? I like how it's bent outwards.
    -Nigel
  20. Darkside
    Darkside [H]ard|Gawd
    1,249
    Jun 29, 2004
    @conraddungan.. really nice work on that box
    @Nigel I think the heatsinks on 2red's memory are the older verison of these. Arctic Cooler
  21. Protolisk
    Protolisk n00b
    39
    Jul 1, 2010
    Just installed the C12P SE14 into the V351 and under load (prime 95) it reaches 72C. Is that normal for the C12P or did I do something wrong?
  22. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    Just got the pc-v351r...
    Just wow... I am blown away yet again with Lian li! sersiouly... I have all their black towers and love them but this red one blows them out of the water! Sorry pc-6b :-(..hahah
    -Nigel
  23. someclown
    someclown n00b
    3
    Nov 18, 2009
    These are/were my two spring projects. They are only half-assedly done due to $ issues.
    [​IMG]
    The PC-V351 is my first Lian Li case, so TBH, I hesitated hacking it up too much. As such, pretty much everything is boringly stock. I had wanted these pictures to wait until I had installed a modular (Seasonic X Series) power supply. Unfortunately, that isn't going to happen any time soon - so I guess I've got some cable management ahead of me...
    [​IMG]
    The main reason for posting these pics is to demonstrate what I've resorted to for acceptable cooling. I wanted a small tower HSF and I wanted to buy locally. These two prerequisites left me with a Scythe Ninja Mini rev b as my only option. The height is perfect for an unmodded v351. The only real problem I had was I was forced to move my Ripjaw RAM to my Sugo SG05b due to the height of the 'teeth'. I was happy to find the ECO series as a more than suitable replacement.
    [​IMG]
    [​IMG]
    I used the included 92mm fan clips to attach another 80mm fan to the rear of the heatsink to give me a push pull arrangement.
    The only other thing I did was to swap the rear exhaust out for what I perceive to be a more efficient setup. I was also able to increase the fan size to 92mm from 80mm.
    [​IMG]
    Anyway, that's it. I know my cable management is practically non-existent, so flame away if you must. Compared to many others, this is the opposite of [H], but I simply wanted to provide another example of an easy, "middle of the road" v351 build for anyone interested.
    I7 860, Gigabyte P55M-UD4, 8 GB GSkill Eco series, Sapphire 5850, Kingston (30GB) and Intel (80GB) SSDs and a 1 TB Samsung Spinpoint hd., ...
  24. NewShockerGuy
    NewShockerGuy Gawd
    684
    Jan 24, 2002
    You did EXACTLY what I want to do to the rear and make my 92mm bracket...
    What size aluminum did you use? Have any extra... want to make another..lol
    Looks good!
    -Nigel
  25. HelioX
    HelioX Gawd
    705
    Jun 11, 2010
    Where did you find the ninja mini?
  26. barfastic
    barfastic n00b
    61
    Jan 25, 2011
  27. Prelector
    Prelector n00b
    56
    Aug 20, 2008
    Anyone have a source for a spare/replacement motherboard tray?
    I'd hacked mine up for a previous build, and wanted to start from scratch. :p
    Thanx!
  28. CrimsonFury
    CrimsonFury Limp Gawd
    185
    May 8, 2005
    I took some rough measurements (hard to get tape measure in because mine is stuffed full of components)
    That space is around 35mm x 272mm
    You can get them here: http://www.performance-pcs.com/cata..._info&cPath=130_210_750_753&products_id=20966
  29. Prelector
    Prelector n00b
    56
    Aug 20, 2008
  30. barfastic
    barfastic n00b
    61
    Jan 25, 2011
    Thanks!
    I already took the dive and ordered the case, i REALLY like it... ive always wanted one, and now that i ahve my full tower up and running, i can finally paly around with a SFF :D
    Should be here in a couple of days! and shrotly i will be posting up pictures :D
  31. Sir_Poop_Alot
    Sir_Poop_Alot Gawd
    683
    Aug 2, 2008
  32. fr0sti3
    fr0sti3 n00b
    1
    Mar 6, 2011
    heya all, just to check.
    i removed my v351 HDD cage last year, now i'm thinkin of converting it to a NAS.
    any ideas what rivet to use for the HDD cage? is it countersunk rivets?
    thanks in advance :)
  33. Shark00n
    Shark00n n00b
    47
    Aug 30, 2007
    Hey guys! Just thought I'd introduce my, I might say, pretty darn modified PC350!
    I wanted to keep the outside appearance as close to the original as possible, becasue that's one of the biggest reasons why I lose this case so much.
    And I also wanted to fit 3 120mm radiators, a reservoir, a full size graphics card and PSU, and a cool and efficient watercooling loop for my OC'ed i5 2500K.
    How it all started
    [​IMG]
    Stock front plate
    [​IMG]
    [​IMG]
    It was too close to my graphics card (at the time an ATI 4870X2), so I modified it slightly
    Before
    [​IMG].
    [​IMG]
    After
    [​IMG]
    [​IMG]
    Now she could breathe!
    [​IMG]
    But then I thought I'd mod the front plate a wee bit more
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    So then I made a custom backplate
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And adapted an HDD cage from a Silverstone TJ09, I had to cut it in half...
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And I NEEDED to do something with the 5.25'' bay drives support bracket
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Then I decided I needed some new, better, hardware, so I got this
    [​IMG]
    And this
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Started assembly
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Pump ready
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And then we just put it all together!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Driver bracket, has a Y shaped connector for a release line to make things easier when it's time to bleed the WC system
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Bracket in place
    [​IMG]
    Everything in it's place
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Inside
    [​IMG]
    [​IMG]
    [​IMG]
    Outside
    [​IMG]
    [​IMG]
    [​IMG]
    And in it's rightful place on top of my desk! (notice how I also changed the front LED from blue to yellow, it was darn hard and it's probably the thing I'm most proud of, 'cause I think it just looks way cool!)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I know this is ALMOST a full worklog, but I didn't want to make a new thread just for these few photos, and I thought you guys would like to see my case as much as I enjoy seeing yours!
    Thanks! ;)
  34. Sir_Poop_Alot
    Sir_Poop_Alot Gawd
    683
    Aug 2, 2008
  35. Shark00n
    Shark00n n00b
    47
    Aug 30, 2007
    thanks man!
    CPU's running at 4.5Ghz, at a stable temperature (less than 70ºC under full load)
  36. bastage
    bastage Pics of your wife?
    12,788
    Mar 4, 2010
    Thats impressive. Very nice job.
  37. nxcess
    nxcess 2[H]4U
    2,657
    Dec 22, 2004
    Nice custom backplate. I don't know why it wasn't designed like that from the beginning.
  38. CrimsonFury
    185
    May 8, 2005
    Very nice setup Shark00n. I am currently working on a watercooled V351 myself. Couple of questions:
    Do you have an image file or cad file template for the custom backplate you made? If so, any chance you could post it here for others to use? I would love get a backplate like that made for mine, but I wouldn't know where to begin designing one in CAD or whatever.
    What made you go with 2x separate 120mm rads in the front, rather than a single 2x120mm rad? Seems like a lot more fittings and cost, a single rad would have slightly better flow and surface area.
  39. Shark00n
    Shark00n n00b
    47
    Aug 30, 2007
    [​IMG]
    (It reads: "bend down")
    I'm sorry but this is all I have, I lost all my cad files a while ago, along with some other things when my usb pendrive broke...
    I'm sure that if you take this image as a sketch and also your case to any competent laser cutting company they can measure and make an identical one in a flash!
    I went with 2 separate rads because:
    1) I had them laying around here
    2) It leaves a nice space between them were I managed to hide a bunch of cables
    3) Although a lot of cutting was necessary, it looks like it came this way and I really like the look of the two rads together
    4) I know the difference is almost none, but two 120mm rads DO perform better than a single 240mm rad.
