- May 5, 2006
There is a way to "disable ABL" sort of, by changing your settings to remain under the threshold.
From the Rtings C9 Review, regarding SDR settings concerning ABL:
"If ABL bothers you, setting the contrast to '80' and setting Peak Brightness to 'Off' essentially disables ABL, but the peak brightness is quite a bit lower (246-258 cd/m² in all scenes)."
So it sort of avoids ABL by doing that but like
Still it would avoid ABL on one or more sets of named settings (like standard, APS or whatever) that you could swap to and from (either by navigating with the remote or using the mic+voice) when you are using the display for documents rather than media, HDR media, games, HDR and auto HDR games, etc. Then just engage the other named mode you want when you are viewing media. In fact that is probably best to have a dim setting for documents vs eyestrain, especially for things that don't have or benefit from dark modes.
There are a lot of named modes you can edit for specific usage on the LG OLEDs, and you can break them down and customize them so that they no longer have the settings their default named mode usage scenario is based on at all.
mirkendargen
replied to me when I posted that info over a year ago last June:All that's really doing is turning "Automatic Brightness Limiter" to "Always Brightness Limiter", heh.
- Vivid
- Standard
- APS
- Cinema
- Sports
- Game
- FILMMAKER MODE
- iisf Expert (Bright Room)
- isf Expert (Dark Room)
- Cinema Home
