- May 5, 2006
For some reason after doing a Windows reinstall last week and unplugging then replugging the digital audio cable from the LG 48cx into my Logitech speakers, when I choose Realtek as the audio option I Windows, the audio plays through my laptop speakers and not the Logitech speakers. In the LG settings, I have selected Optical as the audio option, ditto on the Logitech. Not sure what the problem is here, or if its a Windows things or a setting on the LG 48cx. Can anyone assist?
So you have no digital audio output on your laptop and you are passing hdmi audio to the tv, then outputting the TV's optical output to the speakers/amp? What graphics card / hdmi audio are you using? If you are trying to pass hdmi audio, you'd need to select the gpu's hdmi audio out to the tv, in the panel screenshot I linked above.
The realtek digital out is only for actual optical (or maybe even coaxial) outputs from the device. If you had a direct optical out from the laptop, you wouldn't need to pass audio through the tv at all necessarily, unless you had to for the WebOS or other inputs (consoles, etc). Did you try running optical out to the speakers from the TV and playing something from the WebOS? (youtube, emby/plex, whatever) to see if you get sound with the laptop out of the loop? Then try running the laptop directly to the speakers (if possible, outputs wise) and see if you get sound that way. Process of elimination.
You can get a cheap usb audio device if nothing else works but you should be able to get it working eventually.
