Did you scroll down the resolution list in Windows and select the 3840x2160 under the “PC” heading?I just hooked up this tv to my 3090, it is only giving me 4k 60hz though.. what settings do I need on the tv in order to get 4k 120? I am using hdmi 4 and set it to PC mode.. and tv is in game mode.
Hmm, I will double check that.. I was just looking at the resolutions at the top of the list and max it went to was 60hz.Did you scroll down the resolution list in Windows and select the 3840x2160 under the “PC” heading?
PC mode will disable some settings.I see on yt videos of people changing settings on the tv under picture and advanced or other settings menu (don't remember what its called exactly) It has gamma white balance etc options in there.. Mine are all greyed out.. ideas why that is? (latest firmware installed). I am in Game picture mode and hdmi input set for PC.
I got the CX at launch. Used 16 hours a day, everyday, at 120 nits on the desktop with automatic dimming and screen shift disabled. No sign of burn-in yet.So what are the thoughts now on burn-in on these screens using this for primary desktop display?
I do keep some static windows open most of the day assuredly, that is my concern.What is your daily routine, I mean do you browse internet for hours each day, using like Chrome with bookmarks bar on?
Do you often use Office software like Excel or Word so you have large white area on screen for longer period of times?
I'm guessing you keep taskbar hidden and no desktop icons.
Mine is fairly new I’ve probably got 300 hours on it so far, used for gaming and office work (Excel, Outlook, Word, etc.) and I’ve got no signs of burn in. I’m not doing anything overly conservative to protect it, just turn it off if I know I’m going to step away from the computer for 20+ minutes.So what are the thoughts now on burn-in on these screens using this for primary desktop display?
6 months of 8+ hour desktop use and no burn-in. 120 nits brightness, dark mode in use wherever it is available and taskbar/topbar/dock hidden. Black background. I turn the display off when taking longer breaks.So what are the thoughts now on burn-in on these screens using this for primary desktop display?
How do you do a full power cycle? The remote does not turn it off?7 months here and 10+ daily hours, 80 nits for SDR because the room is very dark. Same as above, dark mode when possible, auto-hide taskbar, black background and I turn it off with the remote when walking away for a few minutes or playing in VR (not a full power cycle though, I do those only when it's going to be several hours).
This reminds me, I have 3 lg tvs on this setup, the cx 48" and 2 nano 85 49" screens.. but the remote works on all 3, is there a way to change it so they are individual. There is an ID setting in the menu, I changed that but does not do anything it seems.
which region ?Just got the 03.21.09 update OTA.
Eastern USwhich region ?
2831 hours on the TV. HDR is permanently enabled on the desktop with SDR content at 120 nits. 90% of the time the browser is maximized with the icons, address bar, and scrollbar statically in place. I've hidden just the Taskbar but am considering unhiding it as it's buggy. I'm fine with junking the TV in 2 years, as a comparable monitor like PG32UQX / Predator X32 would cost $4000.What is your daily routine, I mean do you browse internet for hours each day, using like Chrome with bookmarks bar on?
With IR remotes it's easy to shield the receptor on the tv or to use a repeater receiver near you and the transmitter pointed directly at the tv's receptor on the other end.. but RF remotes aren't so easy. You can use your phone or a tablet to control the TV remotely over WiFi though so that might end up being a better option if you keep having issues.How do you do a full power cycle? The remote does not turn it off?
Got it here on west coast as wellEastern US
Still no update in EUGot it here on west coast as well
Brother I think you will love it. You think the JS9000 was good? This is better in every way. Input lag, 120Hz, VRR, ridiculous image quality. Just try to vary your content from time to time and you should be fine. I've used OLEDs for over 3 years now as my daily drivers and haven't had any issues. The CX is a stunning display!OK, mine is on the way. Going to give it a shot.
Yeah, I have been waiting for a jump-off point from this JS9000 and like what you say above, it seems to be the time.Brother I think you will love it. You think the JS9000 was good? This is better in every way. Input lag, 120Hz, VRR, ridiculous image quality. Just try to vary your content from time to time and you should be fine. I've used OLEDs for over 3 years now as my daily drivers and haven't had any issues. The CX is a stunning display!
Well, a $2000 JS9000 a few years ago says this ain't my first 48" 4K rodeo.You will look at the very top quality LCD monitors and TVs and be like oO From now on.
I do have a second 47" LCD TV as monitor #2 that I toss stuff on that will stay static for hours. As cheap as big screens are now, it's no big deal for this kind of use.
I would strongly recommend a dual monitor setup for this reason. It's what makes dealing with the OLED easy. If I had to constantly think about whether I CAN leave something up all day, vs just tossing it on monitor #2... yeah that would be really annoying.
It supposedly fixes the raised blacks while using HDR/Dolby VisionAny changelog on fw 03.21.09 compare to previous version? I just had it popup to update today but I decided not to, since I haven't had any issue. (Though I don't have a 3080 yet, so I don't have VRR or raised gamma issues. lol)
Check the event viewer to see if the nvidia display driver stopped responding, if so, updating your bios and setting the gpu mode to performance in the nvidia panel may fix it (it fixed the issue here).Randomly I will lose signal to my monitor. The image just freezes for a split second and then the screen goes blank and say "No signal" for then to imidiately go back to a signal where it will say the usual "Game mode". I see that Windows Night mode/light does not work after this. So I have to disable and enable it. This happens in idle just browsing the internet.
Is this my screen, GPU or Windows that is causing this? I cannot believe its the cable as I have tried to different with no change. My setup is of cause the 48" CX and then a RTX 3070 TUF OC from ASUS.
It can’t be completely disabled unless you use the service menu (so I’ve read, haven’t actually done). Also there are a bunch of YouTube 4K HDR videos of people walking through city streets at night (Tokyo, etc) that look fantastic on this TV.Can someone explain how to disable auto brightness that dims the screen when the background is predominately white? I didn't see that in the various settings. Thanks.
Loving this TV for computer use. I was using 2 30" HP IPS monitors since 2005 or so, so this is a massive upgrade. 4K nature documentaries as suggested by a [H] forum member do look fantastic, as does scifi like Blade Runner, Serenity, and The Expanse.
I think I have it detailed somewhere in this thread, search for ASBL. Requires service remote or suitable Android phone and app.Can someone explain how to disable auto brightness that dims the screen when the background is predominately white? I didn't see that in the various settings. Thanks.
If it's 'under the hood' non-authorized tweaking I'll probably leave it as is. It's a very minor annoyance.I think I have it detailed somewhere in this thread, search for ASBL. Requires service remote or suitable Android phone and app.
