DooKey
- Apr 25, 2001
I'm in the alliance now. Check out my new rig in sig!
Nazo said:Hey, I noticed in your OP, you list all of the standard socket 939 Athlon processors, but, none of the Opterons. Ok, not exactly a big deal -- especially considering that the s939 Opteron is basically just a carefully picked Athlon, but, seems like they should be included and that anyone with a s939 Opteron should be included if you haven't already been including them. In the future, they'll probably end up being the ones that give s939 the good name when everyone else has socket F or whatever M2 will be called (I hear a reviewer -- I think German -- already received a demo system, so it won't be long now.) Since some of those babies go up to 3.2GHz on water, they will be kind of like those Athlon XP mobiles that ran 2.5GHz+ and kept Athlon XP alive so long when everyone called them CPU limiting (I still remember getting the FEAR demo to play surprisingly smoothly on my old 2600+ @ 2.5 with an unlocked 6800nu. AXP actually still isn't quite dead yet.)
Sure, I am. It's the only way to go...bertbuddy said:Can I be in the Alliance![]()
Sounds like you got the same kind of transistors I did (after all, S939 Opteron is more or less just a San Diego, albiet hand-picked.) Runs really cool (though mine maxes in Prime95 where yours idles) but maxes out somewhere between 2.5 and 2.6GHz (2.6 is Prime95 unstable and so far I've tested up to 2.52 where it gets my memory exactly right, and is 100% prime95 stable.) I can boot up to some pretty high speeds too (I think I once even got into windows at 2.7 and it actually acted stable, but, I consider it unstable if Prime95 finds any errors.)TSS Modder said:just got my Opteron 170, and currently its running stable at 2.55GHz. itll run MemTest stable at 2.7GHz, but wont boot.
36C idle, and it was briefly at 47C under load, but went back down to 46C.
Sure, but only if you fix your sig so that it says "S939" and not "S393" that it currently does.bertbuddy said:Can I be in the Alliance![]()
What's your address? I just want to, uh... deliver a big check, yeah... *hides the metallic round and rather hard check behind his back.*omz said:3800+ x2 @ 2.6ghz 1.41v
ShepsCrook said:What? Did people forget that there are Opterons that are 939? Are owners of these processors not allowed? lol
LOL why did you put the AMD 64 sticker on the PSU?User said:If I may, I'm in.
3000+ @ 2.4(267x9) Stock heat sink, TIM, voltage
My Case (Work in progress)
My Case #2
Don't mind the PCI graphics card. Only thing I had kicking around not AGP![]()
DDR2 is in the horizon now. Very soon S939 will be replaced (I think they call the new one AM2 or something?)DeadlyAura said:yeah, I saw the 754 club and figured that there must be a s939 club.
And I was so happy when I found it![]()
Anyways, long live the s939.
EDIT:![]()
