dragontales said:HOLLA!!! 939 baby![]()
and i wanna be presidentCCUABIDExORxDIE said:but i wanna be a secretary!![]()
heh.beowulf7 said:Opteron CPUs work in Socket 939 motherboards?! I thought they required Socket 940.![]()
Wow! This will probably kill the traditional high-end 939 CPUs (i.e. FX series).(cf)Eclipse said:heh.
yeah, insane heat. here's the deal.. there seems to be a transition between just warm and insane. for the 144, i gained 10c from 1.58v to 1.62v.. ~38-40c load to ~48-51c load, with water. everything under 1.58v was around 35-40cCCUABIDExORxDIE said:these run hotter then san diegos, and water is useful, ask Ozzi about that
(cf)Eclipse said:whoever told you they run cooler.. emit a punch to the throat
No one said that. I just assumed. They are the better made chips are they not? Anyway, I do think it's a key part of that that it's running at 3.2GHz to get up to 46C on water. Actually, it still sounds like it runs cooler accounting for voltage and speed differences than my chip at least. You're just pushing it really hard. When I raised my voltages, I saw a not so dissimilar temperature increase, though I still have my fan on low (honestly, raising it doesn't seem to make a huge difference. In the end, my limit is my chasis not my HSF since I'm on air.) At any rate, these chips still run pretty cool, which is all I really mean. I was simply amazed (and a little annoyed) to find that I bought this expensive heatsink wanting to make sure that temperature didn't hold me back from ocing much and I can't even overclock enough for the heatsink to be all that much better than the stock thing (though at least there is nearly no temperature throttling going on, which can only be good for the CPU.)(cf)Eclipse said:whoever told you they run cooler.. emit a punch to the throat
(cf)Eclipse said:the same as any other san diego at the same speed![]()
either works. in the end, it comes down to your luck. do whichever one feels like a better choiceSomeoneWhoIsntMe said:Eclipse, think I should get a 144 or 146? The recent price drop puts the 146 in my budget![]()
