Is VR even worth it?
elvn
Titles do not have to be made for VR. You can use VorpX to play games like Bioshock, which was really fun.
https://www.vorpx.com/
You can run games that natively have SBS 3D and VorpX also has a SBS 3D emulation mode called "Virtual 3D Cinema Mode" for games that don't have native SBS 3D support. Some have to use Bigscreen or probably Skybox. I prefer Skybox for 3D movies so I'd try that first. Some people with Nvidia gpus used to sideload moonlight instead of running virtual desktop since moonlight uses nvidia gamestream, for native SBS 3D games I'm guessing. From what I've read some people are running Wii and Gamecube games via emulators in 3D mode too... I hadn't though to try that.
Here is a list of supposedly every PC game that supports 3D side by side mode natively: https://www.mtbs3d.com/gg3d/index.php?sdr_dev=&sdr=all
The problem with some rpg games that have a lot of item and ability sheet text placards and other higher resolution fine detail games is the same problem as using most tiers of headsets for desktop/app text use without scaling things large --- the resolution isn't high enough. The farther away outdoor areas or long view areas end up blurry too, or even zooming out high in an isometric. Also screen door effect on the smaller details and text. Even if you had an O+ blending out the screen frame you wouldn't have the detail. Some of the only higher detail headsets are very expensive from Pimax. In future generations of VR headsets we should get more higher resolution model options and competition though.
That still leaves a lot of great PC games without small text and probably some that you can use pc interface choices to scale the HUDs and text larger on. I'm definitely interested in trying out some Wii and Gamecube games as well. It looks like you can run emulators like Dolphin on the quest itself untethered no less. Tethered to a PC would be a lot better performance though. I guess mario games and even mario kart in VR are incredible looking.
bobzdar
Thanks thats helpful. I think I'll wait for a quest 2 with native PC support then. O+ and daydream works well enough for me at moment. Would be nice to have one device to do it all though with more portable capability than the daydream.
Well... quest does have native pc support now. It will run steam vr games just fine, I just use the O+ for the increased fov and slightly better iq. When I take my quest and laptop I have access to my full library of games, which I don't with the O+.
Rizen
If you are into sim racing or just cars in general, VR is 110% worth it. It's incredible. iRacing in particular is a fantastic VR game.
DarkStar02
Good lord the clarity on that new Pimax 8kX is amazing. Makes the Index look like a DK1
Reactions: Youn
TLoki
You should try looking at the used market. You can find some for very reasonable pricing like the htc vive.
elvn
The 8k x model's resolution looks incredible from the reviews but the overall kit price is ~ $2000. The cable bandwidth at highest Hz and the GPU power isn't fully capable without upscaling so that is something to be aware of in gaming.
Hopefully higher resolution headsets will become more standard in competing models in the next generation of vr headsets.
cdoublejj
all i can say is the higher cost setup can be worth it. a friend of mine sunk about 4 figures in to his and the pay back is other friends buying him games and hanging out out his place on weekends, it gets used well. eventually when i get more space i plan to get similar setup with a dedicated room as my friend did.
SuperSubZero
I can't adjust to manipulating a "floating" control, like a flight stick or steering wheel. In No Man's Sky the ships are near impossible for me to fly using the stock VR controllers. I tried out DCS World (the air war simulator) and I *immediately* bought a HOTAS setup JUST for that game, but the issue there is the flight stick has buttons all over it which aren't visible in VR, so I found myself fumbling over the stick trying to find stuff.
On a side note, one other annoying aspect of VR is when it hasn't been used in a while and things need to update. I recently started tinkering with my VR headset after a long break and games need to update. Welp, the games I tried didn't have in-VR update info or windows at all, so I'm sitting there wondering why the game isn't starting, I take off the headset and there's Steam with the "Play Game" button waiting to be clicked after an update. A couple of the games also staled out my logins so those also just sit at the desktop waiting for a login while VR is just showing blank. *Very* aggravating.
elvn
That sounds cool. Hopefully there will be a new generation of VR headsets by the time I get to the point where I can remodel my garage into a VR and workout space with a space heater for winter and a pillar "R2D2" AC in summer. That will be a while yet. Higher rez headsets should be more common next gen I hope. Not worth breaking the bank atm for me considering my space constraints and my current pc configuration, the roadmap of vr gaming and accessories (haptics, force feedback, etc) , questions about Pimax QC and delivery timelines, support and obviously price/lack of competition for their top segment, etc.
I'm sure its nice on a top tier setup right now but my personal roadmap for that level of gear is farther out where I probably start shifting future upgrades toward better VR editions rather than a PC desk setup. I'd really like valve, oculus, or samsung to come out with a very high resolution headset (like the pimax 8k+) but with a quality HDR OLED screen that can be used for movies as well. Perhaps with curved OLED screens if that works better for games. I'd also like some advanced high interpolation and perhaps eye tracking foveated rendering, etc. to go along with very high Hz rather than having to play at non-native resolutions on a very high rez headset. I'd prob build a mini itx just for VR at some point. That and something like a 7nm 3080ti to drive it, both with hdmi 2.1 and/or adaptable dp 2 I'd hope. Definitely some things to look forward to in the future.
I would definitely invest in a flight stick if you like flying games, even a modestly priced stick, and a steering wheel if you are into driving games - which you said you did. As someone who can touch type without looking at the keyboard (in fact all of my special keys are blank on the top), and who uses a many keyed mmo mouse without looking at any buttons - I'd say learn your flight stick buttons so you can use them blindfolded.
I've had some setup pains flipping my headset off to get around a dozen final settings set up in a SkyrimVR ultimate mod pack so I can understand the back and forth aggravation. Especially since my PC is in an adjacent room to where I put the headset on usually. If I had the virtual desktop type setups mentioned below it would have been no problem. Some other things to note are that if I break the guardian zone with my oculus quest headset it goes to a black and white camera view of the real world which can be useful to check on things in a pinch. For the moment I ended up propping up my 8.5" tablet with the instructions I needed for skyrimVR settings and just tilting the headset up a bit to read as a workaround.
Virtual screens , apps, windows...
There are a bunch of people I've seen playing VR games on twitch and in youtube videos that are using virtual desktop technologies to pin clones of their monitor in the VR world. Not only can you have a virtual desktop on your VR headset as a stand-alone app - - what I am talking about is that it's possible to pin a virtual screen or screen window in virtual space that will still show during the game, within the game (Walking dead: saints and sinners VR twitch player I was watching for example). This is most commonly narrowed down to a large (virtual) tablet or giant "phone" screen that they tie to their forearm just behind the controller which shows the channel's chat window and nothing else. This "screen" actually moves as if it's strapped to your forearm and the player tilts his arm up as if he's checking his watch sort of. I've also seen posts where people have a screen with their baby monitor feed or other screen in the upper right of the virtual game world. I've even seen people pull up triple monitor setups in VR (on a desktop anyway not in game so far) . However zooming in on a single screen is probably necessary for any detailed text due to the VR resolutions/virtual distance limitations. The singular windows and chat windows seem fine though since you are bending your forearm close to your face "checking your watch" which in this case is what looks like a larger tablet strapped to your forearm. Anyway the point is that you can have screens pinned or hotkeys or motion triggers that pull up your desktop display or window in different ways. That is one of the things on my "To Do" list so that I can take peeks at my desktop , steamVR or whatever is running while in the game.
elvn
from https:// www.youtube.com/watch?v=sMixxsn8IVQ
In this video I show you how you can have Twitch Chat or YouTube chat display in Virtual reality with any Virtual Reality game. This will allow you to then interact with Your stream audience without having to take your Virtual Reality headset off or use a Desktop view. Download Link for Open VR Desktop Display Portal - https://github.com/Hotrian/OpenVRDesk... Download Link for Open VR Twitch chat (I recommend using Desktop display portal instead) - https://github.com/Hotrian/OpenVRDesk... Download link for Restream Chat ( this lets you view both YouTube and Twitch chat at the same time) https://restream.io/chat
https:// www.youtube.com/watch?v=Xe-seYTX3HI
SuperSubZero
Touch typing isn't the point. The game draws a stick, and it doesn't match the stick on my desk. As well, the game doesn't do a particularly good job of mapping everything, so a lot of stuff is still on the keyboard, which again, I can't see. Even part of touch typing is knowing where the home row is, and when your hands are on a flight stick, well.. what home row? Also, the stick controls change per plane. Keyboards don't change per app. That aspect simply wasn't fun for me, I decided to play other games, and the HOTAS just collects dust now (Mechwarrior Online "sort of" supports it but piloting a mech with a flight stick is weird).
elvn
It can be momentary on a toggle , depending how you set it up that is. Like pulling up a minimized window. There are a bunch of options on how you do it I believe.
You obviously want the apple experience out of everything as opposed to PCMR and sound like you are doing a linus tech take your ball and go home when you aren't spoon fed. VR is not AR mapping your room and controllers, at least not yet.
elvn
From researching this so far it seems oculus desktop has their own virtual desktop screen/window pinning called Oculus Dash which might be a little less resource intensive, there is OVR Toolkit for steam which I will probably go with, and Virtual Desktop app also has this kind of functionality.
Among other things, with some of these virtual desktop pinning apps you can:
-Pin windows or desktop views at different sizes and transparencies (i.e. "see through" or not).
-Can pin a view to somewhere stationary in the game world environment.
-Can pin a view to your headset so it follows you around at whatever relative location, size and distance you specify.
-Can pin a view to your controller/forearm similarly
-The size/location options and especially the transparency makes it less obtrusive
- Depending on which app, you can show multiple monitors and/or windows shrunk and zoom in on one, or manually cycle which monitor is shown on one view panel.
- Depending on which app, you can see UAC popups and can click through them from the pinned view window in the VR headset's view.
- You use your controllers like a laser pointer and click things on the desktop. You can also use the "laser pointer" controls with a virtual keyboard on the desktop.
- You can now, in beta/experimental stage at least, enable hand tracking in the oculus quest interface so you don't have to use the controllers to manage windows and watch movies, point-typing on virtual keyboard, etc.
- Considering the pin location freedom, I'm thinking that you could probably pin a screen below your knees or on the floor below you so you could look down to check on your desktop but not have it in your view during gameplay. Otherwise a show/hide toggle would be nice for a more direct viewing position too. I'll have to experiement with the apps.
edit:
Oculus Dash seems to do almost everything without using more resources like the others. For just checking on your desktop for messages/errors or prompts, progress meters, etc you could just pin a window or desktop view the oculus dash screen so that when you pull up the oculus menu (pausing a playing app or game), you could see your desktop/monitor views or pinned windows.
However I've also learned that there is a row of buttons in the lower right corner of each desktop window that gives you extra panel functions: Pin , Pull up virtual Keyboard, and Minimize. Minimized windows appear on your oculus dash bar and can be restored from there. To maximize an already shown window, point at it and pull the trigger or tap the button. This is like a show/hide taskbar type of setup, where you can have multiple minimized virtual desktop/window views without having them always in your game view.
polonyc2
why is the Valve Index so much more expensive then all the other VR kits?...is it worth it?
ProfessorUtopia
The cost is higher than most other headsets for several reasons:
  • It's one of the few headsets still using external base stations for tracking.
  • The panel supports a refresh rate of up to 144 Hz.
  • There are more features for customizing the fit and focus.
  • The controllers are technically complex.
  • The general build quality is very high (though, there have been QC issues).
On the more speculative side, Valve might not enjoy the economy-of-scale Oculus and some others may have.
Whether it's "worth it", is subjective. I am very satisfied with my purchase.
Hagrid
The base stations gives you much more accurate controller placement than the sensors on the HMD. People always say it works fine while playing beat saber but never any games that require much more arm placement.
elvn
It's sort of like having a 7.1 surround system and a big oled tv and a sectional couch compared to a modest smaller TV with built in speakers, or using a console gaming system rather than a loaded expensive pc with an expensive monitor. Personally I'd rather wait before going higher end, for the next gen of headsets where hopefully higher resolutions per eye becomes more standard along with higher bandwidth ports (displayport 2 or hdmi 2.1), perhaps hdr, better oled (and maybe even curved oled) and other enhancements.
The pimax 8k x is very attractive but the company's timeliness/support, the unit's durability/build quality, etc have mixed reviews and a full kit with index controllers and 2 lighthouses is very expensive $1600 - *$1900 + tax vs a $250 samsung or a $350 - $500 oculus Quest that has untethered gameplay to boot). The 8k x seem to have much better fov and resolutions but like I said, hopefully those features will be available in headsets from more manufacturers in the next generation of vr headsets and with higher bandwidth ports and when more powerful pc gpus like a 3080ti are available so that you wouldn't necessarily have to rely on up scaling in order to support higher fps and higher Hz.
Of course I'd love a full 8k x kit or a full index kit but I have to pick my battles. I really can't see such a pricier purchase being worthy of the limited space I have available right now either. However I'm hoping to remodel my connected garage into a vr/workout area sometime this year so I should be set up a lot better for room scale eventually on my quest and eventually a better VR headset. That might motivate me to do a miniitx build around a future 3080ti purchase, or save money by moving my whole desk setup to the garage. I'll have to insulate the new room and especially the doors, installing a wall space heater for the winter and using my old pillar style stand alone air conditioner in the summer.
I'm looking at it like building a home theater hardware setup or a modest gym in a house. VR isn't quite yet there for me for that level of spending. For now a Quest was a good way to dip my toes in very affordably.
RanceJustice
Just letting everyone know as they discuss the topic - Humble Bundle is offering a VR Bundle at time of writing!
https://www.humblebundle.com/games/vr-bundle
It includes a handful of well-reviewed VR titles via Steam, at current.
$1=
Cosmic Trip - VR sci-fi RTS
Smashbox Arena - Lighthearted arena combat and minigames
BeatTheAverage $14 =
Gorn - Gladiator combat physics sandbox, humorous "Devolver Digital" published.
Budget Cuts - Sci-fi stealth action title, inspired equally by the Portal series and Metal Gear Solid.
Space Pirate Trainer - VR take on an old school arcade shooter like Galaga, mixed with rhythm gaming into a hectic attack-and-defend setup.
Full Package $15 =
Superhot VR - VR entry in the Superhot series with completely different content/features compared to the standard title. Lo-res hacker gun-kata adventure where time only moves as you do!
Moss - Storybook-like adventure tale of a mouse off on a quest, designed specifically for VR.
Especially given that many VR titles seem to cost more and don't go on sale as quickly/dramatically as conventional play, this is a fantastic deal - its no surprise that the "average" is so close to the fulll package. I personally have been waiting to see discounts for Gorn, Superhot VR, and Budget Cuts so I'll definitely pick it up, interested to try out the rest as well. This is the first time I've seen a bundle with "big name" titles anywhere near this inexpensive - mostly its exclusively the 'very limited tech demo" types, if bundled at all.
This may give owners of VR hardware an affordable pack of titles to showcase some of the benefits thereof, at least on an entry level. There are lots of other games and experiences that can extend things beyond, but certainly a good start to illustrating the value of VR on the cheap.
elvn
https://uploadvr.com/facebook-ai-quest-superres/
Facebook Researchers seem to have figured out a way to use machine learning to essentially give Oculus Quest apps 67% more GPU power to work with. However, Facebook informs us this is “purely research”.
The new technique works by rendering at a lower resolution than usual, then the center of the view is upscaled using a machine learning “super resolution” algorithm. These algorithms have become popular in the last few years, with some websites even letting users upload any image on their PC or phone to be AI upscaled.
Given enough training data, super resolution algorithms can produce a significantly more detailed output than traditional upscaling. While just a few years ago “Zoom and Enhance” was a meme used to mock those who falsely believed computers could do this, machine learning has made this idea a reality. Of course, the algorithm is technically only “hallucinating” what it expects the missing detail might look like, but in many cases there is no practical difference.
TuesdayNewsDay VR news youtube channel:
The Oculus Quest just got 67% more powerful with AI
"Just Got" is a little overzealous hah. However it does hold promise for the future and into the whatever the next gen of headsets are in 1 -2 years too.
elvn
yes and I guess amd is working on something similar. Facebook is working on this in particular with their system for higher fidelity untethered gameplay though, so in that case you wouldn't be linked/tethered to your pc and nvidia gpu power.
VR is great if it's developed well. I have had fun watching movies and playing certain games on a Rift. Games where you use the controller to move like FO4 can be rough but you could get used to it. It would be nicer if you could sit, I've had some success with using a stool but the setup is based on height so it's like you're in a wheelchair...
I love Robo Recall, it uses teleporting for movement. Fruit ninja is a great game for everyone including beginners
Hagrid
You can set the Rift to a different height. Some games even have it as an option.
Reactions: MaZa
True but last time I tried height adjustment it was a PITA. If I recall Occulus wants you to rerun the whole room/sensor calibration every time you adjust, but it is fun to stand up and be a giant after calibrating it for sitting! I played FO4-VR with a mix of standing and sitting and I just put up with the UI being goofy. Either way I feel like sitting down while moving with the controller was a lot easier to handle.
My friend has a 360 treadmill thing I've been itching to try, it would be a lot better than the floating movement.
MaZa
Yeah Beth dropped the ball (for the nth time) when they never added the heigth adjustment in FO4VR, something they did include in Skyrim VR. Changing the height is PITA in Oculus too because you have to go through the recalibration process every time.
Decibel
Other than a few games, I play VR out of an office chair in the middle of my play space, including FO4. For games on Steam that don't have good individual settings, which is nearly all of them, you need OpenVR Advanced Settings: https://github.com/matzman666/OpenVR-AdvancedSettings
Exactly! I haven't tried Skyrim VR yet, but that is odd that they included height for Skyrim but not FO4...
Thanks, I'll check this out!
I haven't tried mixing standing and sitting for the last several months. Perhaps it helps to start it up after picking a position. I recall the GUI for Oculus and Steam not rendering properly, along with several games that were launched if you sat down after equipping the headset. I assume the hardware thought I was just crouching/bending, and everything rendered at the standing height.
123Lanoix
My B-Day is coming up and I want to make myself a present. Whatever in $500-700 range should be ok, IF it's actually worth it.
I did a quick Google search, and it doesn't look like theres very many "good" VR games out there.. i'm talking truly AAA titles like Fallout 4 or Resident Evil 7.
I experienced VR only once, back when the original Oculus rift came out. It was very cool, but not super useful. Very few games supported it, and mostly it was about demos and such.Also, there was this horrible side effect, when after using for 10 min, I had to take it off because it made my head spin/dizzy - very unpleasant.
How much have things improved since then? Does it really make a huge difference in games that support it?
What else can you do with it? Aside from gaming?
Thanks!
Do you have a good gaming PC ? Get a Rift S. I won't really bother with anything else unless you want to spend $999 for a valve index and even then you need a pc that can push 144 frames.
Hagrid
It does not have to run at 144. It is able to run 80,90, 120, and 144 according to online info.
