What is the model of your power supply?
It seems you are slightly backward. The power supply exhausts its hot air into the front bezel. Perhaps its intake ("PSU points down") is blocked or you have a defective power supply.
The rear 92mm fans are designed to act as intakes. Do yourself a favor and cut out the rear grills, then ditch the factory 92mm fan and install two of these.
No case is perfect. They are a form upon which you work your magic.
Good luck.
Good luck.
