I want to replace the front and back 120mm fans of my new PC-A05 case with two 120mm Noctua NF-S12 800rpm Quiet case fans and then another 800 RPM fan sucking air through the Thermalright Ultra-120 Extreme.
Would three 800rpm fans be enough for airflow through this case OR should I look at getting 1200rpm fans?
Finally put together a new computer.
I have my Xigmatek fan sucking in air instead of blowing so basically it's running a dual fan setup since the intake fan is so close. Since the powersupply is flipped, it's harder to hide the thick wires coming out of the power supply ><!
