My picture above with the wiring mess has the 9700 in it.
how hard was it to install that 9700? I temporarily put my 9500 in this case and it was hard enough for me lol
got it up and running last weekend... here are some images.
IMG]http://i110.photobucket.com/albums/n101/carbon12/A05_FULL.jpg[/IMG]
IMG]http://i110.photobucket.com/albums/n101/carbon12/A05_3QF.jpg[/IMG]
IMG]http://i110.photobucket.com/albums/n101/carbon12/A05_SD2.jpg[/IMG]
IMG]http://i110.photobucket.com/albums/n101/carbon12/A05_Zoom.jpg[/IMG]
IMG]http://i110.photobucket.com/albums/n101/carbon12/A05_3QB.jpg[/IMG]
yeah, that's what it was called. I was trying to rember what model it was. It was a g60, fit perfectly. Also, once I get the accopanying expansion slot bracket fan, things should be really be nice and cool.i'm assuming you got that side panel off a V600 or G50 no?
This case looks really nice. I have a question to all owners though: How is the air flow if all 3 hd bays are filled? I am looking to use this for a small server and I want to make sure the hds dont get too hot
Where did you get it from? I really want some air vents on the side like yours.yeah, that's what it was called. I was trying to rember what model it was. It was a g60, fit perfectly. Also, once I get the accopanying expansion slot bracket fan, things should be really be nice and cool.
Or you can do what I'm doing and getting someone to cut holes in the side panel.
Technically a "mesh" area like that could be made simply by drilling lots of holes in the right places and with the right machinery you could even keep them even.
Too... lazy... :Xor you can cut the square out and buy some mesh to put in![]()
Awsome, just awsome, love everything about it, though I might not have used that heatsink, but I love the way you put it togather.
What's wrong with that HSF?
You might want to try to find a place that sells lian li side panels. I just had a G50 from a friend that updgraded to a v1200. Swapped panels with him and that was that. If you do find one though, it fits perfectly and will allow you to use the v1XXX series plus vga cooler fan bracket.
-RC
^^^ i would def want to know where i can get my hand on g50 side panel also..![]()
i bit the bullet and ..well i ordered one....and ordered two yate loons...thanks for making get this!! haha..i cant wait
First post, here's my A05B.
Comments welcome!.
how quiet does that thing run?
Comments welcome!.
