Ive not seen the BS-03 but performancepc sells the BS-01 that bolts to the A05 vent.
On a side note, Has anyone seen a retailer that has the Zalman ZM-MFC2 in stock? I need one for the next phase of my A05 build![]()
Yeah I got the BS-01 from there, but finding the BS-03 is impossible. It seems like it'd work great too.
Have you tried Ebay for the fan controller? Or do you really want a retailer?
anyone know where to buy that bs-03 side cooler? Would work wonders for that hotspot above the vid card![]()
If you're planning on leaving the side off then I wouldn't find it necessary to have that fan blowing into the upper part of the case. Taking the side off of my case drops GPU temps by at least a few degrees because heat isn't being trapped anymore. If you're going to put the side on then yeah, finding a way to get cool air in the top of the case should help quite a bit.
You should get better airflow to the psu with the fan on the bottom. The HDD cage would be pretty restrictive in trying to pull air through it like that. I have mine mounted with it on the bottom and it seems to be fine.
Very nice Magnum, but why doesn't the Southbridge have a heatsink?
The slats give in when i press them, But they work fine for what i have it for.
Here(see picture below).
That picture was taken during some test fitting with more hardware. You can see where I am going to place the PSU (its only tied in with string right now). I have a semi-worklog going on at another forum.
Having a nightmare trying to source one of these in the UK, does anyone have any links to anyone with them in stock?
Ye Kustom is just down the road from me and that`s the 2 sites I use mostly but both out unfortunately
heres a quick update....put the drive cover and a matrix oribtal
for the love of god adjust your white balance!
"I think it would be possible to mount the rad on the top too but you would lose at least the 1-2 PCI slots and a 5.25" bay."
I think someone willing can do it up top. Yes you will loose 5.25 and some pci, it would also be some interesting tube managment.
Heres a reference shot.
This one is a lil blurry, sorry.
<img src="http://i34.photobucket.com/albums/d128/Viktors/100_0204.jpg" alt="" border="0">
<img src="http://i34.photobucket.com/albums/d128/Viktors/100_0238.jpg" alt=""border="0">
<img src="http://i34.photobucket.com/albums/d128/Viktors/100_0195.jpg" alt="" border="0">
I would love to have internal wc in mine but I don't want to block any expansion ports. Do you think a single 120mm rad. on the front fan would cool a e6400 @ 3ghz and a nb? Also, would the internal temps increase because of a radiator on front?
I don't know why you wouldn't be able to. The only concerns I would have would be possible space issues between the top GTX and any optical drives you have, but I think you'd be okay. I know for a fact that a single GTX fits into the A05 just fine, but I haven't seen a pic with two. At worst you might have to plug in the external power plugs and stuff before you actually install the card so you didn't have to mess with smaller working areas, but it should fit. The only other thing to consider would be heat. You'd probably want to mod the case to have an exhaust fan over the GTXs or some sort of blower setup because that will get hot real quick.Ok..you guys sold me after looking thew this Whole Thread..sweet..but I have a question..Can I put both of my 8800 GTX (XFX SLI Baby!)...
Inside this case..I think I've read every post in here,,and I didn't see any info on this...anybody![]()
