That's good to hear.
Since the AOC will be hooked up the HP, I'll probably go with the AOC-USAS-L4I instead of the MV8. This will make it easier for me to add the 2nd drive cage box down the line. I already have 32 2TB drives in transit from the egg and I still don't have most of the other parts for this build yet.
From the thread, the USAS-L4I was confirmed working but Tau posted that it was 'slow' when both interfaces was hooked up. Was this because both was connected to the same HP expander? I understand it's pointless to dual-link this. Just wanted to make sure the cause was because of that and not because both interfaces was 'active'. If the internal 8087 was attached to an HP and the external 8088 was attached to a 2nd different HP it shouldn't be 'slow', correct?
I suppose I can always go from the AOC to internal HP SAS with the 8088 connected externally to 2nd HP in 2nd box as well. Are there any potential reason to go with the MV8 vs USAS? Mainly support or problems I could end up running into with either.
