treadstone
- Jan 25, 2010
I've installed WHS on my system for testing and did not see any such messages....
What motherboard do you have in your system?
Try disconnecting the primary link...perhaps speeds will quadruple.![]()
> Hi cciss devs,
> I'm using cciss for Smart Array P212, but it requires me to create logical
> drive to access disks. The only way I can think of still using the linux
> software raid5 is to create 1-drive raid0 logic drive then present the logical
> drive to mdadm. But this will erase the data on the disks.
> Is there a way to bypass the logical disk layer and access the physical disks?
> This way I can use mdadm to manage existing array w/o backup/restore the data.
> And it would be possible to port the disk to another controller.
> Thanks,
No. It's a RAID controller, not a plain SAS HBA.
SuperMicro AOC-USAS-L8i - when I had both ports from the controller connected to the expander the speeds were terribly slow... unhooked the second link... doubled the speeds... Have only had the box going for a few hours now will be doing some more indepth testing with it over the next week or so.
Well I'm less than impressed with the HP P411 I have purchased. The management software for it is absolutely awful and on first boot of my system with the P411, SAS Expander and 3 of my drives to test with (all had data on) the P411 kindly decided to create a RAID 1 array out of two of the 500GB drives without any intervention from me.
I'm looking at replacing the P411 with something that can pass drives direct to the OS without having to create an array or put each individual drive into a RAID 0 array. Should I get the ARECA ARC-1300-4X or is there a better alternative for a similar price? If I get an answer in the next couple of hours I could order it and get it delivered tomorrow.
<snip>
No real reason to dual-link that Supermicro with the HP Expander, you're not going to saturate a single link with that LSI chip anyway. Not to mention very few if any third parties have tested or support dual linking with expanders, let alone the HP expander. Go ahead and test it but don't waste too much time, I don't think the implementation on the SM card knows how to deal with dual linking.
The only cards I'm aware of that can properly dual link are HP's own PMC-chipped raid cards, but I'm trying to push Areca to support it on current and future cards.
Maybe I should've yelled a louder warning in the OP that HP's raid cards aren't ideal for home use, too many shortcomings and too few options.
You haven't said which O/S you want to run and whether you want a striped array or not, those are the first questions in determining which HBA card to buy. If you ONLY want drives passed through to the O/S and don't plan on any striped arrays, then just get a non-RAID HBA like one of the Supermicro cards listed in the OP, or the Areca ARC-1300-4x.
EDIT: Open-box ARC-1300-4x on newegg right now: http://www.newegg.com/Product/Product.aspx?Item=N82E16816151060R
Not sure if it's any use to others, (no good for me as I am in Australia) but these guys seem cheap for NEW cards??
http://www.compuvest.com/Desc.jsp?iid=1215324
That's not that cheap. I got mine for quite a bit less, and from what I consider a much more reputable company.
Hey Guys,
I currently have a LSI SATA/SAS 9211-4i 6Gb/s and was looking in to getting the HP Expander, does anyone know if this card will work with my LSI? Thanks.
Care to share where to get them cheap?
Look up forum member SynergyDustin. Great service and the best price when I bought mine.
PERC 6/i: FAILURE
"Attached Enclosure doesn't support in controller's Direct mapping mode.
Please contact your system support.
System halted due to unsupported configuration."
Direct quote from PERC 6/i bios init. F/W v. 1.0 (HP SAS EXPANDER)
F/W v. 6.1.1-0047 (PERC)
Wont boot passed this screen. Chalking the two PERC 5 & 6 "internal" cards up as failures, even though the 6/i should support 16 drives on its 8 internal ports... possibly only in a special Dell system? or enclosure!? Unknown.
PERC 6/E for sure does work though!
Please update the first post!
Thanks!
I would be willing to bet they would work if you flashed them with an LSI bios
I did that with a perc5 when I had it cause dell quit updating it.
For example, while certainly an interesting project, I'm sure no one would suggest I do what this guy did:
http://www.servethehome.com/category/the-big-whs-30-drive-whs/
and use Windows Server 2008 R2 as the Host. I assume I'd want to have whatever file server OS I'm using installed on the bare metal.
"it's not going to work"
So does anyone know how well these work with the new Intel SASU8i cards under solaris?
