How much RAM you got?
How much RAM is installed on your rig?
  • 4GB or less
    Votes: 1 0.1%
  • 4GB+
    Votes: 0 0.0%
  • 8GB+
    Votes: 14 2.0%
  • 12GB+
    Votes: 1 0.1%
  • 16GB+
    Votes: 115 16.2%
  • 32GB+
    Votes: 318 44.8%
  • 64GB+
    Votes: 222 31.3%
  • 128GB+
    Votes: 24 3.4%
  • 256GB+
    Votes: 9 1.3%
  • 512GB+
    Votes: 6 0.8%
  • Total voters
    710
TrueNAS Core - 128GB (4 x 32 DDR4 Unbuffered ECC 3200MHz)
Proxmox Mini PC - 64GB (2 x 32GB DDR4 SO-DIMM 3200MHz)
Primary Desktop - 64GB (2 x 32GB DDR5 6000MHz)
Laptop - 16GB (2 x 8GB DDR4 SO-DIMM 3200MHz)
Secondary Desktop not used very often - 32GB (2 x 16GB DDR4 3200MHz)
I hope the zvault project takes off. TrueNAS Core just saw its final released based on FreeBSD 13.3, so after about December there will be no way to update the software I have running in jails. RAM is adequate for my use cases in all machines, but the primary desktop is probably a little overkill.
My main rig still has 64, which is plenty, but my DP server currently sits at 96GB, just because 8GB RDIMMs were what was cheapest and there are 12 slots. Doesn't use very much, but it does benefit from the bandwidth.
I'm the only one with 4GB lol
Somebody has 512GB RAM. I've just got an old laptop atm, and that's my HDD size. The battery has a dead cell, so it's only about 20 minutes without AC.
The PC part mnufacturers must be buddies with the Software manufacturers, they probably roll on the floor laughing everytime they manage to require another 4GB for the same task. My second PC was 2MB ram and ran Win 3.11 ok, when we got it up to 8MB that was huge.
I have 4GB in my xp machines. :)
What gets me about win 3.11 is that does notepad really require so much more ram than it did in win 3.11? Like really?
To be fair, XP only let you use 3.25 GB of it, anyway, unless you went for the PAE kernel hack.
I think it's more to do with OS and GUI overhead than anything else. Just opened a txt and Notepad was using 2MB (the program file remains at under 200k in size). In college and my teaching years, I wrote text-based qb64 math demonstration programs for my classes where the code was sometimes less than 1 or 2 kb, balloned to 4 or 5 MB on compilation (libraries, I assume) and used 12MB of memory. There were maybe half a dozen 64 bit variables.
Yep, but it's still super fast looking at pdfs with a gpu. :)
I still remember how small the borland turbo c dos executables were compared to the ones compiled with the windows version we were required to use for testing and submission. I figured out how to use gcc and started using that instead as it would pick up stuff turbo c for dos and windows would miss. And each submission was pass/fail so you had to get it right.
Finally got my last ramkit for the epyc local AI node, now running 12x 96GB DDR5 ECC at JEDEC timings/speeds (locked by supermicro motherboard).
Gaming system hanging out with 64GB (2x32); plenty for what it needs to do :)
More than 1TB of RAM?!
Ladies and gentlemen, we got him.
Time for a little update for me.
Main workstation: (Threadripper 3960x)
128GB (4x32GB) DDR4-3200 Unbuffered ECC
Game Machine*: (Ryzen 9950x3D)
64GB (2x32GB) DDR5-6000
Backup Workstation / Testbench / Old Decommed Server Board: (Dual Xeon E5-2697 v2's)
256GB (16x16GB) DDR3-1600 Registered ECC
Main Server: (Epyc 7543)
512GB (8x64GB) DDR4-3200 Registered ECC
Secondary Server: (Xeon E-2314)
32GB (2x16GB) DDR4-3200 Unbuffered ECC
Old (but still serviceable for my needs) Laptop: (Core i7-4810mq)
16GB (2x8GB) DDR3-1600
*Game Machine parts are all here in boxes. Have not had the time to assemble them yet.
So... Which one should I list in the survey? :p
I probably spend most of my time on the main workstation, so 128GB? Then again, I will be doing most performance/gaming type of stuff on the game machine, so 64GB? Or should I just go for impressing everyone and choose the server, so 512GB? Or should I just stay understated and go with the Laptop's 16GB?
Or maybe I should just add all of them up? 😅
For now I've just put myself down as 128GB.
Choices... choices... lol. If I pick my Voodoo 5 PC, I have 1GB in that, so less than 4GB! :ROFLMAO:
Gaming rig - 32GB
Gaming laptop - 32GB
Streaming recording NUC - 16GB
Proxmox server - 512GB (have enough to add another 512GB in 64GB dimms, just don't need it yet)
PBS - 128GB
Test server - 128GB
Firewall - 16GB
Desktop - 32GB
Laptop - 32GB
FreeBSD server - 32GB (max supported, wish it were more)
TrueNAS server - 128GB
Old Supermicro x8 test system (not active ATM) 64GB
pfSense box - 8GB
Arc hits are at 97% on the FreeBSD machine so I'll run it until it doesn't meet my needs anymore but I do wish it was on a newer platform with more memory.
Made a few updates since I first cast my vote here:
Main gaming/vr rig (in my sig) is now at 64Gb
Secondary rig (GMKtec Evo X2) for messing with AI and tinkering is at 128Gb
TV surfing / Home Theater rig (GMKtec K8 Pro mini-pc) is at 64Gb
Kids Gaming PC (AMD 5950x) is at 32Gb
Kitchen PC (AMD 5600x) is at 32Gb
Home Assistant Server (Beelink Mini S12 Pro) is at 16Gb
Arcade Cabinet (GMKtec G5 mini PC) is at 12Gb
Not really counting my daughter’s laptops as they are taking them off to college, but one has 32Gb, the other 64Gb.
recently went from 8gb to 16gb, with 22 tabs opened or so I had about 500mb of ram left and VM was likely being used a lot, 16gb same tabs uses 12, system if faster, probably not touching vm much if at all
new RAM arrived today for my other build, mushkin DDR4 redline 3200 16GB for 45 bucks, that's stupid cheap
back in the day one stick of 2GB DDR2 would cost that much, I remember the pain
I've got 64GB of DDR4 ECC SODIMM on the way for the Shuttle DH370 I bought from eBay as parts only, not working. It had a single bent CPU pin that was easily straightened. The 64GB was $80 shipped.
I am thinking it might be time for me to grab a 64 GB kit. Thoughts?
Just don't feel like spending 250 smokes for a decent CL28 kit.
Kit I am thinking it might be time for me to grab a 64 GB kit. Thoughts?
Hah! And I was toying with the idea of jumping to a 96GB kit myself, but also don’t feel like spending that much in doing so. There’s really no real world difference jumping from CL30 down to CL28 on an AMD rig unless you really, really enjoy running and graphing RAM benchmarks as a side hobby. :D
Tell you what, I’ll sell you my 64GB kit for $175 if you want - would help offset my upgrading to a 96GB kit and you’d be able to jump to 64GB kit and save a few smokes in the process as well as sell your 32GB kit to further offset cost. Mine’s a G.SKILL Trident Z5 Neo RGB Series kit (AMD Expo) DDR5 RAM 64GB (2x32GB) 6000MT/s CL30-40-40-96 1.40V - Matte Black (F5-6000J3040G32GX2-TZ5NR).
Thanks bud, I appreciate it!
but
No RGB no buy
Also need CL28 at least
Ah, you wrote matte black. There are some kits with that name that are just black.
Can you run CL28 on the kit and is it A die or M die?
No idea… I’ve always just run it at stock Expo settings. This is the kit I have: https://www.amazon.com/dp/B0BJNTLJ5X
Not understanding why CL28 is so important to you with a 9950x3D. Tuning DDR5 RAM on a 3D cached (x3D) AMD CPU when already starting with a fast/quality kit is pretty much a waste of time… like taking a piss but deciding to see if it’s more fun turning into the wind. :).
Unlike regular CPUs, there are very little (if any) gains to be had with an x3D CPU when it comes to playing with RAM timings, especially with a 6000Mhz DDR5 kit with a CAS latency of 30.
If you are really into competitive gaming at 1080p, and you tweak the hell out of CL28 6000 DDR5, you’ll see a massive .5 FPS performance improvements in 1% Low frames for most games over using stock settings on a CL30 kit:
And going up to 1440p or 4K gaming, those differences will be even less noticeable - the above tests are with 1080p to really isolate/stress just the CPU/RAM performance.
So if you are playing Counterstrike 2 at 1080p and really need that extra .6 FPS (694.9 over 694.3 FPS), then yes, tweaked CL 28 DDR5 6000 RAM is your god send when it comes to selecting a memory kit. :D
Source:
View: https://youtu.be/M4EzlrNK5vU
