Pachalski
- Mar 15, 2017
Correction: I have the ASUS 1080 Strix in this one with standard cooling, I stand corrected. thank you!Case looks great, tophat idea is pretty cool. Also the bigger CPU cooler height options make this intriguing and I appreciate the motherboard cutout for easy mounting. I would add to the chorus here asking for some more ventilation on the bottom and wondering about the perforated panel on the "core" piece and how that affects air flow.
I am curious about this comment earlier Pachalski :
Is that a 1080Ti on air? If so how is that possible? I have a Dan A4 and while your case is a little different it's not that different, at least in its default config. My 1080Ti FE sounds like a small hairdryer when gaming (albeit while playing demanding titles at 4K). At idle and just while browsing the internet my case is basically silent also, but at load my GPU is really loud and from reading about AIBs it doesn't seem any of them are inaudible either under load....
I basically would expect this case to have better thermals and noise than the A4 if you're using a bigger cooler and/or watercooling, which to me is the selling point here. But with basically the same components, for example a stock air cooled Ti (any of them), I would not expect much improvement over the same component in the A4, correct me if I am wrong? And I am asking as a curious possible buyer, not as a nitpicker! Like I said I really like the case.
