Epic Games Store
one of these giveaways in 2024 will be Death Stranding Director's Cut...book it!
Seems like a fun game but I dropped it as soon as I realized they didn't use the movie cast.
Same issue as Avenger's. Feels like a cheap knock off.
It is based off the comic books, which the movie is also based off of. But it isn't based off of the movie. I got over it after 5 minutes.
The movie cast straight up wouldn’t work with the game. The game uses the comic versions of the characters and their personalities. As good as the movie cast is, they would feel off if they were voicing the comic accurate (mostly) versions.
Epic Games Launcher Ending Windows 7, 8, and 10 Support on June 2024. 32bit so don't panic.
Today we’re giving a heads-up that the Epic Games Launcher will no longer support Windows 7, Windows 8, or Windows 10 (32-bit) starting June 2024. After this date, existing installations on these operating systems will no longer receive updates of any kind. The Epic Games Launcher will continue supporting Windows 10 (64-bit), Windows 11, and macOS 10.13 or higher.
After June 2024, players will still be able to use the Epic Games Launcher on Windows 7, Windows 8, and Windows 10 (32-bit), just not in an officially supported manner. Epic will be unable to provide technical support for users of these operating systems, and Launcher features on these operating systems may degrade or stop working over time.
https://store.epicgames.com/en-US/n...june-2024?lang=en-US&epic_affiliate=lowcygier
Makes me glad there is some competition, even if they aren't that good. Ever since Steam rolled out the "improved" version last year it has gone to shit. It runs like absolute dogshit now and often hangs loading a game forever. It also takes forever to load, exit, and pops up over anything else you're doing while you wait for it to load up. It can't even load up minimized so it has to ruin whatever you're doing while you wait for it.
Shitty game selection list doesn't scroll. Click on search does nothing. Literally can't play games on Steam because of how shitty it is now unless you already created a desktop shortcut or find the right .exe file to manually launch it. How wonderful. At least Epic figured out how to make a GUI that can launch games.
It is so shitty that it makes EGS look efficient, clean and functional. I'm going to have to pirate a game I bought just to avoid using Valve's shitware. Steam is so bad that I'd rather use Epic or pirated copies now.
This is 100% a you problem. Something is obviously broken somewhere. I've never had these issues with Steam.
I do agree competition is a good thing though.
It's not just you, brand new PC build and if I click on the steam icon from start / desktop it won't launch (when minimized) for a good 10-20 seconds, unless I go into the taskbar and launch it from there, very weird behavior. The search no working seems to be a loading issue, have to wait for steam to fully load up before search is functional, I have that issue primarily when browsing from my phone though.
I have no issues launching games from steam fortunately.
I'm glad for the competition, and until last year, would typically try and buy from epic more than steam, but now that I have a steam deck, I'm more inclined to buy all from steam again since other launchers just don't work as seamlessly on the deck.
Yeah the issues are numerous and many. I can no longer find Fallout 4 for example. I assume Valve removed it from my library. VR mode doesn't work half the time, numerous errors with launching games, where it just says "playing" without launching them. Won't shut down, have to manually end process.
Valve has let Steam become the worst launcher. Shame they threw in the towel. I wish we could revert back to the old version that actually worked, or if a 3rd party made a Steam freeware alternative to play our games and get our updates.
As it is: EGS is the best, Ubisoft Connect is next, EA's new abomination, and Steam is dead last. From 1st to worst in a few months. Great job Valve. Maybe they will continue to fleece people for their failed console instead of working on their PC platform.
Since when does Valve remove paid for games from your Steam Library??
They don't even remove de-listed games from it.
Sounds like you might need to nuke your install (making a backup of your common folder first) and reinstall because it sounds borked to me, then go through your library settings and make sure Steam knows where your games are at by pointing them out manually, one by one if necessary.
Valve is the worst with returns as well. In having an issue with gunbrella and I'm 3 hrs in. They said I've passed the 2hr play mark lol they said to contact the developers which are not responding to my messages anymore...I once returned a game on gog that was well into 5 hours of play time...
How are they bad with returns? I've never had any issues. Their policy is less than 2 hours of played time within a 14 day period. You knew the rules and are complaining that they won't go against their own return policy. Just because you don't like their policy, doesn't make them bad at returns. GOG's return policy is 30 days, no questions asked, but they don't have a clear return window as far as hours played. They just ask that you don't try and abuse the system. Just buy games from GOG if you like their return policy better.
They state clearly that play time must be 2 hours or less to return a game. Just because you didn't adhere to those guidelines doesn't mean they are bad with returns. Your current situation is entirely your fault.
Epyc: 2 hours of play / less than 2 weeks of purchase return policy.
Ubisoft: 2 hours of play / less than 2 weeks of purchase return policy.
Xbox: 14 days, not played a lot of play time
Rockstar: 2 hours of plays / less than 2 weeks
Seem to be quite the standard, vendor have no obligation to return a game that has no big issue at all, your case if the game is broken and that discovered 3 hours in, would be a rare one and hard to be an automated at the store level affair with digital store, Gog would be an exception here in many regards.
Gog is actuality the best. They have refunded me in full past 2 hours mark. Anyways Steam wouldn't help nor devolver. I had to restart the game unfortunately but all good.
They wouldn't help because you went beyond their return limit. Quit blaming others for your inability to comply with their ToS.
Um the creator of the game could have helped lol I wasn't asking for a refund at that point but help in why the game wasn't letting me progress...
I can't even buy anything from GOG because they're entire billing system is in Cyprus, another country rife with corruption. My bank declines every purchase from them. Sucks I would love to buy games from their store.
They're in Poland, not Cyprus. Where do you live? Zimbabwe? I've never had any issues purchasing from there. If your bank is declining purchases, then you need to contact your bank and tell them it's a legitimate purchase, and any purchases moving forward won't be flagged.
If that fails don't they take PayPal?
Yes, they accept almost everything, including PayPal.
We currently support the following payment methods: credit cards, PayPal, paysafecard, SOFORT, Giropay, webmoney, iDeal, Skrill, Alipay, UnionPay, WeChat, BLIK, Przelewy24, Apple Pay and Google Pay. We also support payments via BoaCompra with a bank transfer, boleto, credit card, real-time online banking and wallet.
If your country (based on your IP address) is supported by these payment methods, they will be made available to you in Checkout.
The currencies that we support are AUD, BRL, CAD, CHF, CNY, DKK, EUR, GBP, NOK, PLN and SEK - which are available in supported countries -- and also USD, which is available everywhere.
https://support.gog.com/hc/en-us/ar...urrencies-do-you-accept-and-where?product=gog
GOG's payment processor is in Cyprus. https://www.gog.com/forum/general/payment_wont_complete_processing_stage
All my banks refuse them. Sorry this is the truth. Look it up on google. I am far from the only one who has problems with this. I belong to a credit union. And even the pre paid visa cards I buy get declined. Many people have issues with them. I am glad you don't.
I'll use my paypal from now on. Didn't know they used them. But tons of people have issues with them. Sucks.
I see. The point remains there are plenty of payment options if one doesn't work. Just use PayPal if that's what works from your experience. I try and to use PayPal whenever I'm dealing with purchases in foreign countries because PayPal purchases don't usually get flagged, regardless of where the charge is coming from, and that's a lot simpler than having to contact my bank every time. I've been buying from GOG for years without issues, but my bank is very easy to communicate with if I'm buying from overseas. They may flag something initially, but will whitelist the charges once I approve them.
It depends on your banking institution.
Every time I want to make a purchase from GoG I have to contact my credit union. They will decline the charge every single time unless I do so. It doesn't matter if I try to do a straight charge or if I use Paypal. At one time they didn't decline Paypal for GoG purchases but at some point in the past couple of years they started to. It's annoying as hell and the one reason I don't purchase as much from GoG as I used to.
Apparently Marvel's Midnight Suns is the next free game....always bloody happens when I have already grabbed it on Humble Monthly.
