silentsod
- Dec 28, 2010
Yeah, the music in 2016 was much better with quite a few memorable tracks.
If you have an HDR monitor, you probably need to adjust the HDR settings in Doom for it to look okay.
I tried a bunch, and got it looking alright, but it was still a little washed out it never looked perfect.
I posted the HDR settings I settled on way back in the thread when the game first came out, and they work on both my OLED and IPS displays. It would really help if they put in a proper calibration setup in this game, though. The default settings indeed are quite washed out on the OLED when compared to the IPS.Are you guys playing the game on LCD displays? If so, IPS or VA? I played Eternal on my OLED and it was anything but washed out…but of course that applies to everything displayed on it.VA should be pretty good, though…
That hotfix patch fixed the issues I was having with the game. No more half FPS with V-Sync or intermittent crashes.
After trying to fine tune everything on my PG27UQ I just ended up with max-min settings and it actually looks pretty good, in my opinion. I tweaked the stops a little from the edges.
Brightness: 16.0
Saturation: 0.9
Min Stops: -8.0
White Point: 1.0
Max Stops: 8.0
HDR400 tricks your eyes into thinking that bright spots are overwhelming other parts of the image by decreasing the contrast of the screen and dimming the backlight. This results in crushed colors in my experience with such an implementation. The above settings might improve it, but there is only so much you can do with a display that doesn't have FALD or per-pixel dimming.I'm playing on an IPS panel. It looks amazing and the colors are very vibrant with HDR off.
Not sure if it's a issue with my display, but the HDR mode looks a little muted/washed out. It does look "more realistic" so I think it's working, it just doesn't pop like the SDR mode does.
My monitor is only HDR400, and it's been a real hit or miss with HDR games.
Ah, maybe that's why it looked good to me - I'm pretty sure that this is one of the HDR capable games where I actually took some time to tweak the settings.I posted the HDR settings I settled on way back in the thread when the game first came out, and they work on both my OLED and IPS displays. It would really help if they put in a proper calibration setup in this game, though. The default settings indeed are quite washed out on the OLED when compared to the IPS.
I generally feel the same way, though if you look at SDR brightness you still need to (or at least should) set up your brightness correctly inside of every game. The issue is that every display is different. With the consoles, though, my experience has been that once you go through the calibration tool that I usually don't need to do any tweaking in individual games. There are still some games that completely ignore the system and choose some seemingly random or otherwise out-of-whack defaults that need to be dealt with. I've read that the new auto HDR feature coming in Windows should at least bring something similar to PC, so hopefully the experience improves once that is released.Ah, maybe that's why it looked good to me - I'm pretty sure that this is one of the HDR capable games where I actually took some time to tweak the settings.
For as good as HDR can look, I'm a little disappointed with it from an ease of use standpoint. I wish that you could just enable it and have it work uniformly and already optimized (and then fine tune from there if needed). I get that there are different "levels" of HDR but would it be too hard for game devs to implement presets for the different HDR standards and you could select the one that your particular display supported and have it apply the appropriate optimized presets? As it is now, we have games where enabling HDR can throw the visuals way out of whack and you have to spend time adjusting sliders or researching the settings that other people have found to look best. I just want an on/off button without having to calibrate every game to my particular display, lol.
That's a good point. On PS4 Pro, HDR worked fine out of box. It's just PC that is the wild west.
Yeah, I'm talking about TVs. Of the HDR games I tried on the PS4, there was minimal setup. Maybe just the white point, but overall it "just worked" without a lot of config.
Even the same games, for example Far Cry 5 worked out of box on PS4 and a Samsung TV but looked strange on a PC monitor. It is strange they can't figure this out, I thought that was the point of having a VESA standard.
I'm guessing most didn't really give it a fair shake just because you can't mindlessly unload your favorite weapon at the enemies constantly like you could in Doom 2016.
while keeping around most of what made Doom 2016 great as well.
More mindlessly unloading your favorite weapon at the enemies is what people wanted from Doom, that is why it was criticized. Sure, you can still like it, but it's a different game and a lot of people just wanted more Doom 2016.
That's cause the original composer Mick Gordon wasn't able to finish mixing the music and id fired him.The only minor criticism I'd give it really is that the music wasn't quite as memorable or enjoyable as it was in Doom 2016.
This is exactly the issue. On Doom 2016 you could use the shotgun for 100% of the game and there wasn't even a challenge until the last level.I guess I can see why a lot of people criticized it so hard, but IMO I'm guessing most didn't really give it a fair shake just because you can't mindlessly unload your favorite weapon at the enemies constantly like you could in Doom 2016.
This controversy just had to do with the OST release, though. Mick completed the soundtrack that we hear in the game, but the standalone OST is what was not finished. For the 2016 release Mick remixed all the tracks so they made sense on an album release, with a defined start, middle and end. He was taking too long doing this for Eternal's OST, which is where the conflict arose. It didn't help that many people online kept pestering id about the release of the OST since it was promised with certain preorder packages.That's cause the original composer Mick Gordon wasn't able to finish mixing the music and id fired him.
https://screenrant.com/doom-eternal-devs-composer-mick-gordon-controversy/
I guess this update broke my damn game. After I hit continue it loads then says press the space bar but nothing happens when I do. It just keeps playing the music but the keyboard inputs do nothing at all and require me to restart my pc. It did that twice and then another time it just went to black screen with music playing and only the in game fps counter showing also requiring a full pc restart.6.66 is now available. This is mainly a content patch with few fixes and balance changes. The primary feature of Battlemode "2.0" is adding skill-based matchmaking based on win streaks...
https://slayersclub.bethesda.net/en...CjVV7d/doom-eternal-update-6-66-release-notes
Needing to update your drivers is making you tired of PC gaming?I guess this update broke my damn game. After I hit continue it loads then says press the space bar but nothing happens when I do. It just keeps playing the music but the keyboard inputs do nothing at all and require me to restart my pc. It did that twice and then another time it just went to black screen with music playing and only the in game fps counter showing also requiring a full pc restart.
EDIT: Tried several more times but then updated the drivers from 496.13 to the hotfix 496.61 and the game works fine. FFS I am getting more and more tired of pc gaming.
It is sad that this actually has to be explained to you but here goes. The game was working fine and then the new update broke the game for me. I was already on a recent driver and in fact after googling and digging through the game forums there were people saying the driver after mine was causing them more issues and should roll back to a driver from months ago. I did see that a hotfix driver driver had come out after the last normal driver but NOTHING was listed for Doom Eternal but I just tried it anyway after losing 30 minutes of trying to get the damn game to work. The hotfix driver was to fix three other games that the driver after mine had broken. It just never ends with drivers and updates breaking stuff and is frustrating to waste time tracking down what the actual issue is when I simply want to jump in game and play.Needing to update your drivers is making you tired of PC gaming?
Serious inquiry. There are things you need to do when using a PC for gaming that have been constants for decades. Updating or rolling back drivers is a common troubleshooting method when Windows came into the picture. I don't understand how that is all of a sudden an issue.It is sad that this has to be explained to you but here it goes. The game was working fine and then the new update broke the game for me. I was already on a recent driver and in fact after googling and digging through the game forums there were people saying the driver after mine was causing them more issues and should roll back to a driver from months ago. I did see that a hotfix driver driver had come out after the last normal driver but NOTHING was listed for Doom Eternal but I just tried it anyway after losing 30 minutes of trying to get the damn game to work. The hotfix driver was to fix three other games that the driver after mine had broken. It just never ends with drivers and updates breaking stuff and is frustrating to waste time tracking down what the actual issue is when I simply want to jump in game and play.
Sigh, it has only gotten worse over the years and the more games you have the more potential issues. Spending 30 goddamn minutes just trying to get a game to run is ridiculous and I should not have to track down fixes for every game or driver update. And every driver breaks something else in another game so I sure as hell don't want to be uninstalling and installing specific drivers for specific games as I go back and forth with numerous games. And this is not the only issue with pc gaming and you know it.Serious inquiry. There are things you need to do when using a PC for gaming that have been constants for decades. Updating or rolling back drivers is a common troubleshooting method when Windows came into the picture. I don't understand how that is all of a sudden an issue.
I suggest a Nintendo Switch and, to make life even simpler for you, this cell phone to replace whatever you're currently using with an age appropriate one:I guess this update broke my damn game. After I hit continue it loads then says press the space bar but nothing happens when I do. It just keeps playing the music but the keyboard inputs do nothing at all and require me to restart my pc. It did that twice and then another time it just went to black screen with music playing and only the in game fps counter showing also requiring a full pc restart.
Dealing with comments like this from the pc community is also tiresome.I suggest a Nintendo Switch and, to make life even simpler for you, this cell phone to replace whatever you're currently using with an age appropriate one:
That's a pretty poor attempt at trolling. When I tell somebody about googling something that means that the results are easily found by doing so and not trying to be a jerk. Just like I didn't act helpless here and googled and searched and realized people were having trouble with at least two different drivers. I realized I could go back to a really old driver or maybe try the hot fix driver which fixed it. I know you're a little slow so that means that googling can actually help you find an answer which it did. Too many of you in the PC gaming community are nothing but trolls and hypocrites and get a hard-on when people have problems or complain about anything.dealing with comments like "do a Google search" from the PC community is also tiresome...if you don't want to answer someone's post then don't say anything
The only reason that I stick with PC gaming is that I have such a massive library of games some of which are not even available on the consoles. If there was any way I could sell all these digital games to somebody and just move on then I certainly would.Buy a console.
