I found a Bovine Bardiche that seems fairly humorous. A chance on hit to summon a herd of murderous cows.
I did have an issue with a wizard character that before the patch was lvl 60, paragon 45. Now picking up some wizard items I find they are locked. Apparently after the update, this character isn't lvl 60 enough yet. Even at lvl 60 P91.
Did they change drop rates silently? 2 days ago I was getting tons of drops, now not so much.
What is with the difficulties? I used to be able to do MP1 or 2 Act 1 and 2 with my monk decently, now I get raped in Master and Expert. Meh.
Okay thanks, but I entered the game key when I installed the game. I better get a hold of support.
I contacted Blizzard and in my absence my account was hacked. I was told the hacker was banned months ago. Blizzard fixed it so I could logon to my old account. Hacker's character, a lvl 60 Monk named Monkey, was still there. He has over one hundred million gold and his stash is full of hundreds of perfect gems and stacks of hundreds of rare crafting material. He also has a few pieces of rare, legendary and set armors. I deleted Monkey but all his gold and items are still around.
When I started a new character he had all that gold, which seems kind of dumb. And my stash chest has all the hackers stuff in it as well. I have other characters the hacker never deleted. He just created Monkey and left all my characters alone. I wouldn't mind deleting all my characters if it would get rid of all the hacked gold to my credit and items in the stash chest. But my son thinks even if I were to delete every character all the gold and items in the stash chest would remain.
Is there a quick way to clean up this game? I could get back to Blizzard and have them clean it up, but that is time consuming and kind of a hassle. Drag and drop all that gold and all those items on the ground?
Why is this game so ridiculously easy on normal? I am literally one-hit killing practically anything I encounter as a level 30-ish monk.
Actually... there's another way to get rid of gold. In Act 2, there's an NPC that sells Blacksmith plans for 1.5m gold each, and you can buy as many as you like.
Gold is not hard to come by. You guys don't want this stuff, it only ruins the game. If you can buy everything you want or need at the AH right off the bat what's the point of playing through the levels killing stuff for loot? Hacking is a dumb way to equip your character.
Crafting should deplete your gold supply really fast when you hit level 70.
The new loot patch has brought new life to the game for me. I'm lvling a wizard and have found a dozen usable legendary items.
Btw, I have a decked out barb but I'm totally digging the wizard. Might be a new fav
Right now the Skeleton King is dropping a guaranteed legendary for first-time kills. I was able to take my 60s (one of each class) through on Torment1 and each got a legendary.
To continue getting the 'first kill' legendary, you have to reset all your quests and re-do it. Then play all through A1-A4, beat the story, then reset again. If you are going to do this anyway it basically gives you an extra free legendary every play of the story.
Can someone explain to me how crafting works? It seems like leveling up the blacksmith adds more items that you can use at higher levels, but are current items stuck at their current damage/armor levels, or do they upgrade as you level yourself/the blacksmith, or what? I haven't quite figured out the pattern yet, and I am not sure if it changed significantly with Loot 2.0 (I didn't really play before that).
I am really digging the game so far. It is much better when played with someone else though, in my experience. Loot drops are great and (for now) you can go on the gold AH and buy really cheap upgrades, as well as selling blue-level crafting materials for a ton of gold. I am a level 24 DH and I think I am at like 500k gold already on the AH just selling rares and blue crafting stuff from breakdowns. I guess after the AH goes away that will be gone, but it's still fun to mess with right now.
I haven't found a ton of legendaries yet (I think 3 or 4?), but so far the ones I have found have been pretty significant upgrades to what I had before, so that is good. I think two of the legendaries I found were for other classes or crafting plans for weapons for other classes.
You can craft some very good stuff now, i tryied Bracers for my barb got like one pair with 300str 200 vita, 5,5% crit chance, 50 all res and 4% ranged dam reduce.. pretty good and they are account bound tho.
Can't help on the crafting, although I do have both maxed, I just don't see anything in the recipe book that would be better yet. Maybe I'm not looking at the right stuff or maybe I am missing some crafting recipes.
I do however like my amulet that blocks all arcane damage and returns 21% of the blocked damage as a heal. Makes me immune to the those damn arcane lassser beams.
Also, I am not a huge fan of RoS-only items dropping in the game thus far, because if you don't buy the expansion they are basically worthless.
