Intel_Hydralisk
- Feb 6, 2005
For those of you discussing MF: http://www.diablofans.com/topic/579...ind-and-its-efficiency-a-statistical-insight/
From my experience magic find does very little. When fighting packs. Went through 5 runs with 291 Magic find and 5 runs with 100 MF.........Didn't notice a difference at all between the two.
Fighting white groups though do drop more items with high magic find.
I'm really not sure why my dps is so low. I have 900+dps 1h too. I still am lacking IAS and Crit tho, so that's likely it. Rocking 210 MF, and think it was a poor investment considering you can farm without it and still yield the same quality drops![]()
But it will take you longer.
boom. thank you sir..
MF at 210% is going to slow you down significantly
where as you could just have 100% easy and 30k dps and be destroying act 1 like its nothing and quickly too.
all mf does is increase your chances at getting higher quality look.
if i kill 8 packs at 2% drop rate
you kill 2 packs at 4% drop rate
whos winning here?
Doesn't sound as large of a sample as in your link but MF to me doesn't really seem worth the hassle. You might even be able to argue that keeping an entire MF set in your inventory will cause you to return to town more often, thus taking longer for farming runs. So if you can farm faster then MF really becomes a moot point imo. Of course, if you're able to have MF on your already best gear then I guess it wouldn't matter or hurt any.
Well you know you can just switch gear right before killing an elite, right?
Selling stuff takes less than 30 seconds. A well-rolled rare is exponentially more valuable than any blue, so it most definitely is worth the hassle.
whos winning here?
whos winning here?
Are you using magic weapon?
Well, as said above, if you can have magic find on your farming gear, that works best. Why kill 8 packs at a 2% drop rate or 2 packs at a 4% drop rate when you can kill 8 packs at a 4% drop rate! But, I try to use a hybrid gear which allows easy kills and decent drops. It's about 213% in Act 1 and 108% in Act 2. Unfortunately, Acts 3 & 4 don't work quite as well, as I need survivability gear, and only 1 of my pieces has magic find.
Where were you when you found that hat?
It worked quite well for me during the heyday of siege breaker runs. You get used to the swapping. Even without a macro it'd take maybe 3 seconds. It was very noticeable with and without swapping. This was a bigger deal before the NV change though.another person mentioned switching your gear out.. this can be pretty risky. also it seems to me spending time kiting to switch out your gear properly would just slow you down
@Intel agreed. Now with the new change to NV not sure if it's as big of a worthwhile change.
Also, if you're using MF gear that slows you down, your MF gear blows and you're doing it wrong IMO.
The way I see it,
Progression -> Progression Gear
Farming -> Gear that maintains the same level of killing speed but now with MF/GF on it.
Yea... i just figured that since Diablo is all about finding those dropped items, there's no reason not to try to progress with MF gear on, just getting better MF pieces as you go. As previously mentioned, however, they're fucking expensive so progression is slow.
I don't usually farm Act 2, but i got it while i was there killing elite packs in the Oasis Path , then killed ZK, went all the way to Belial
when i got to belial i couldn't even solo him as a DH![]()
itemization is hard enough without trying to include MF.
most gear that has All Res and the attributes you want with magic find is extremely expensive and in general not worth the price.
always worth the price man... I'm starting to search for 150+ int, 40+ res all and within 3% of max MF. It takes a while to properly replace your gear but its nice to have 40k dmg AND above 200MF which is what I'm working on having
For Act 1/2 on a barb it's not too bad to sacrifice a stat for MF, just a pain to search for since I would ideally want STR/VIT/ALL RES/MF and the dumb auction house interface limits me to searching for 3 stats. So for now I get the pleasure of Searching for either STR/VIT plus the other two essential stats nd then scrolling through pages of listings to try and find a decent combo worth buying. Hopefully they update that one day.
The absolute worst is trying to find a source for a wizard offhand. The damage stat is the primary stat that drives everything, yet it is impossible to search for. Very frustrating.
Dammit!!! Fuck you Blizzard. I was sitting and waiting to bid on some sweet gear (with 3mins to go on the auction) and I get booted by some weird error. Now Battle.net is down. Sons of bitches!!!
So my current goal is to save up a pack full of ilvl 63 rares and identify them all at once. I would not be at all surprised if I didn't find a single good one. I have one 63 belt so far, lol, long way to go.
I was about to kill the butcher when I got "There was an error creating your own party" and was disconnected.
