Harddriver
- Feb 13, 2006
Some have found that 'un-checking' the P2P in the game downloader-updater to be of some help. I've personally tried it, and it seemed to help a bit. Otherwise, the game - as you can see - isn't totally optimized quite yet, but I'm sure that will change come release. Also note: In order to change the P2P options, I believe you must uninstall/reinstall the game and then uncheck the P2P option. However, there may be an easier way of doing it... I'd look around before making that decision.Does anyone else get terrible lag in the D3 beta? I will ping 30ms in WoW and then go on to D3 and hit 400ms with 4 people and it is damn near unplayable.
They have not removed the 4 player limit, nor do they plan on doing so. If you've had a chance to play the game, you'll quickly understand their reasoning behind that particular implementation. If you'd like to hear my take on it, then go ahead and respond with this post and I'll try to explain why they did it in a bit more detail.I did TONS of PVP on USWest in the leagues over at dii.net if any of you frequented the site was considered pretty good at the time xD. Good days. I played Necro with the same name as my forum name if any of you are old school PvPers from USWest.
I may not have agreed with many of Blizz's decisions but I'll support D3 just because it's D3 and my GF is interested in playing it.
Have they removed the stupid 4 player limit? Or is it really going to be a 4P limit in production?
