Deus Ex : Mankind Divided
Discussion in 'PC Gaming & Hardware' started by Blade-Runner, Oct 3, 2013.
  1. Stiler
    Stiler [H]ardForum Junkie
    10,538
    Jun 4, 2002
    i can't stand blur , I'll take some extra jaggies over blurry distance objects.
    yourgrandma likes this.
  2. Draax
    Draax [H]ardness Supreme
    5,086
    Aug 11, 2005
    I'm only about an hour in but I'm loving the game so far. As I am not offended by everything, I really enjoy the heavy themes and commentary, on current events, MD evokes. I'm playing at 5760x1080 on High settings, as pushing the graphic settings any further just wasn't smooth enough. Game looks great to me though.
  3. robble
    robble [H]ardness Supreme
    6,501
    Jun 6, 2004
    I'll likely be home in a couple hours.
    I plan on cranking 4k ultra no AA and see how that pans out.
    I didn't spend $1650 on graphics cards to play low res or low quality.
    Frraksurred likes this.
  4. Frraksurred
    Frraksurred 2[H]4U
    2,094
    Jul 25, 2008
    Are you my separated at birth twin brother!?! ;)
    jmaker and robble like this.
  5. robble
    6,501
    Jun 6, 2004
    Not home yet but I remoted into my computer. This is what nvidia is recommending I run the game at:
    [​IMG]
  6. Skids1
    Skids1 Gawd
    862
    Jul 16, 2004
    Is anyone else disappointed how wooden or clunky things feel? Jensen seems to move like a static stick...
  7. MavericK
    MavericK Zero Cool
    28,701
    Sep 2, 2004
    I haven't played much yet but this game definitely looks gorgeous. Not sure it justifies sub-40 FPS frame rates, though.
  8. pothb
    pothb [H]ardness Supreme
    4,997
    Mar 24, 2007
    It doesn't... I think it looks great, but nothing justifies sub 40.
    There are graphically glitches too. There are lighting problems, at times looking at a wall that's illuminated, it flashes on and off rapidly. At others, the ground gets completely lit up because of a clear baked lighting being displaced or something.
    I'm on an r9 280, so I don't expect the greatest but the game would be fine then hit extremely low fps then back again. It's pretty annoying.
    That said, gameplay wise, I'm hating on the climb mechanic, I wish they didn't have it and just worked like how it did before, or didn't make jensen look down like a fag every time, gives me a headache.
  9. MavericK
    MavericK Zero Cool
    28,701
    Sep 2, 2004
    Soooo....yeah, this game has microtransactions. In single player.
    You can buy Praxis kits and in-game credits.
    Performance-wise, it's playable at 1440 with Ultra (no MSAA) but barely...quite a bit of slowdown. Also, the graphics seem fairly inconsistent, like in one scene I will get awesome dynamic shadows and in the next, the same object has no shadows. Might be some bugs with this one, hopefully they can get them ironed out and improve performance.
    The game itself so far is awesome - very much Deus Ex.
    There is something weird going on with mouse movement...I don't know if it's acceleration or what, but I had to turn down the sensitivity to 25% to make it feel halfway decent, and even then it's not great.
    chockomonkey likes this.
  10. Stiler
    10,538
    Jun 4, 2002
    That's exactly what I had to turn mine to to get it to feel ok. The steam forums has a sticky with known issues and they say they are looking into mouse sensitivity.
  11. robble
    6,501
    Jun 6, 2004
    Ok, installed latest nvidia driver and ran 1080GTX SLI benchmarks. The results are surprising.
    4k resolution, Preset ULTRA, MSAA off.
    36 avg, 27 min, 43 max
    Changed Shadow Quality to HIGH
    Contact hard shadows OFF
    Temporal AA OFF
    35 avg, 29 min, 41 max
    WTH??? Worse if anything by lowering the quality.
    Going to play around a bit.
  12. polonyc2
    polonyc2 PM an Admin to Pick Your Title
    16,390
    Oct 25, 2004
    how do people play games with no AA and call it beautiful?...unless you're gaming at 4k or using DSR you need good AA (and this game has good MSAA)...I always go for image quality over 60fps every time
  13. robble
    6,501
    Jun 6, 2004
    Running with the NVIDIA recommended setting at 4k (listed in an above post) I got 52,46,62
    Put textures back to ultra and cloth physics on. Numbers stayed the same.
    Turned on Ambient occlusion: 51,43,61
    Turned on Volumetric lighting: 49,43,59
    LOD to very high: 49,41,59
    enough benchmarking for now. Time to play the game with these settings.
  14. KickAssCop
    KickAssCop [H]ardness Supreme
    6,549
    Mar 19, 2003
    How the 980 Ti doing in this game? Will try tonight if I have time.
  15. socK
    socK 2[H]4U
    3,656
    Jan 25, 2004
  16. pothb
    4,997
    Mar 24, 2007
    No way, unless the image quality goes to absolute shit, there's no way I'd pick it over good framerate. And I'm not even one of the frame rate people.
    TBH, I think the game is built towards these micro transactions, which saddens me greatly. A shotgun is 3k, praxis is 10k. In the first game, a shotgun is 750, and praxis is 5k, and weapons sold for like 2 to 3 times the amount it does in this game. Balance seems really out of whack. However, I am still only in the start of the game so maybe it balances out better later on.
    With the gameplay being good, this game still has so many that annoy me. Sigh..... but I did get it for 33 bucks, which is probably the amount it's worth, so I'm not getting screwed like people who paid 60.
  17. polonyc2
    16,390
    Oct 25, 2004
    I don't mean AA over frame rates in the 20's...I'm talking about AA goes first and I can deal with frame rates in the mid to upper 40's and beyond...I never heard about in-game microtransactions until this thread...did they add it at the last minute?...can the game be played just as easily without them?...is it just to give people higher powered gear earlier in the game?
  18. Stiler
    10,538
    Jun 4, 2002
    60fps smooth non-stuttering frame rate>some jaggies.
    Maybe it's cause I grew up playing games that didn't even use AA.
  19. pothb
    4,997
    Mar 24, 2007
    As I've said, I am only a mission or so into the first hub area, so I'm not at all far into the game. So I can't say with certainty...
    I'm personally not using any of the microtransaction in this run ( I got some since I pre ordered or bought day one or something but not using those either.) It seems like you don't get as much exp for things, but I think that's for spreading the game's exp so that you can play one way or another without being too impacted.
    That said, I think you can, but not like you could in the first game. The first game you get a lot of praxis points if you do everything, in this, it seems like you get a fair amount if you do everything. But this is more like a prejudgement as I am still only a little bit in.
    Oh, and though I don't look a great deal into most games, this included, I did look around for some info on this, and I never encountered any info about buying praxis with real money either, til I played the game. So I doubt many people knew. Though, if you pre ordered, you would see that you get praxis as a DLC. Ugh.
  20. polonyc2
    16,390
    Oct 25, 2004
    for MP it's more about frame rates but single player it's IQ (for me)
    Reality likes this.
  21. Comixbooks
    Comixbooks Ignore Me
    13,029
    Jun 7, 2008
    recommend using a console controller for this makes it smoother to play
    Solhokuten likes this.
  22. Derangel
    Derangel [H]ard as it Gets
    17,551
    Jan 31, 2008
    It plays fine for me. Though I'm not as sensitive to issues with mouse smoothing as other people. I dropped the sensativity down a bit and everything feels fine. I'll take the worst mouse smoothing in the world over a controller for a first person game though.
  23. Reality
    Reality [H]ard|Gawd
    1,883
    Feb 16, 2003
    [​IMG]
    I'm sorry, but an RX480 shouldn't be anywhere near a 980 ti. this is ridiculous.
  24. polonyc2
    16,390
    Oct 25, 2004
    it's an AMD Gaming Evolved title so I'm not surprised...as with previous AMD sponsored titles (Tomb Raider, Bioshock Infinite) an Nvidia patch or 2 should get things back to normal :D
  25. Blade-Runner
    Blade-Runner 2[H]4U
    3,027
    Feb 25, 2013
    Uch....trust Square Enix to fuck up a good thing.
  26. Reality
    Reality [H]ard|Gawd
    1,883
    Feb 16, 2003
    [​IMG]
  27. Blade-Runner
    Blade-Runner 2[H]4U
    3,027
    Feb 25, 2013
  28. KickAssCop
    6,549
    Mar 19, 2003
    I will never understand why reviewers keep running ref 980 ti clocks in benches.
  29. Comixbooks
    13,029
    Jun 7, 2008
  30. Comixbooks
    13,029
    Jun 7, 2008
    Have fun playing with Keyboard and Mouse :p suckers ;)
  31. Domingo
    Domingo [H]ard as it Gets
    17,012
    Jul 30, 2004
    I'll take the controversial stances of not caring about AA vs. needing 60fps AND playing with a gamepad. KB/M is nice and pretty helpful with the twitchy sections, but I'm going slow and lazy with this one.
    Q-BZ likes this.
  32. Comixbooks
    13,029
    Jun 7, 2008
    [​IMG]
    Game really shines though whatever keyboard mouse controller setup you use not sure if it's really addicting took me a while to figure out how to get the use stealth to get in the library.
  33. ghostwich
    ghostwich [H]ard|Gawd
    1,723
    Sep 10, 2014
    I think I'd be upset if I didn't have a G-sync monitor. I'm definitely sub 60, averaging in the 50's or so. I tried the Nvidia settings then went off the rails of that a bit and turned on a few things to make the image look better. I tried it at 1080p and it was much better but ain't no way I'm playing in that resolution. I tried all AA off, can't do it - went with TAA and will revisit MSAA when I get home tonight.
    The issue with mouse acceleration is crap, and a lot of the UI makes no sense with a mouse (radial menus, c'mon) so it's a bit clunky. Definitely feels two steps forward and one step back with this game.
  34. Q-BZ
    Q-BZ [H]ard as it Gets
    18,181
    Sep 28, 2007
    I know it's going to be the end of the world to some people.
    It's silly throw away garbage looking to make a cynical cash grab off of people that don't know what a trainer is for. I'm sorry to see the likes of it but thankfully it's something that is a complete non factor ultimately.
    I'm assuming that's their fault. They really have had a fairly nice streak by and large and Nixxess usually does a beautiful job on PC versions of games so I'm fairly optimistic that some of the performance and mouse bugaboos are going to be helped out in the near future.
    That, and updated GPU drivers for both brands.
  35. ghostwich
    1,723
    Sep 10, 2014
    Nvidia's drivers were out way early.
  36. Rustynuts
    Rustynuts [H]ardForum Junkie
    10,370
    Feb 6, 2003
    I dunno, for some reason the graphics/animation seem stale/dated to me. Just starting the game, but the gameplay is also lacking. Solid game, but not buying the hype yet.
    StryderxX likes this.
  37. MavericK
    MavericK Zero Cool
    28,701
    Sep 2, 2004
    It's not the end of the world but it just tarnishes the brand IMO. There's no legitimate reason to have microtransactions in an SP game other than as a cash grab from impatient or ignorant gamers, and I feel that's a shitty thing to do. This is a full $60 title, as well, not some indie or F2P.
    Q-BZ and chockomonkey like this.
  38. LordBritish
    LordBritish 2[H]4U
    2,062
    Jan 28, 2001
    That Hair looks dreadful. Hair is kind of tricky to render realistically though.
  39. ob1
    ob1 2[H]4U
    2,274
    Apr 17, 2000
    That is kind of a cut scene to be honest. I had other issues with the video during that same cut scene, like barely noticeable dots, almost like wire frame points showing on her skin/forehead. On one of my saves, significant amounts of tables/counters do not render, so walking around with stuff apparently floating in air. I restarted again, went through the "tutorial" and it is fine now. I'm liking the game, but it is harder than I expected to get into. Once I am able to figure out a good way to do the abilities, I think it will be fine.
  40. jiminator
    jiminator Capt Obvious
    10,951
    Feb 2, 2007
    Launch directly into game: In steam options, add -nolauncher
    Skip into videos:
    in steam\steamapps\common\Deus Ex Mankind Divided\runtime
    find the smallest pc_binkvid, copy and paste it 6 times
    find and delete the following files
    A25DE802B5F763BC2E933535CD9DC727.pc_binkvid
    5ED546466C171E858CC5A68F29A23284.pc_binkvid
    4A0E2951DDC2FCAAB24181DC99805D79.pc_binkvid
    61F7622A655F804A87F7991025FADC0C.pc_binkvid
    CA6F14742B3E9F4540E4AEA8826D4BA8.pc_binkvid
    D6303B081E3752D30912AD69F480282D.pc_binkvid
    Search for "copy"
    Rename the 6 files using the names above
    if the instructions are hard to follow, you should not be modifying anything
    Q-BZ, Saturn_V, Frraksurred and 5 others like this.
