Relativistic
- Jan 20, 2010
What cables does the U2412M box come with?
DVI only?
DVI only?
I'm missing the emergency. It's easy to get carried away with one's own anxiety.
Fair enough. It's helpful to relate the specific need, such as the time crunch you face(d), because I assume you've seen how many "urgent" or "emergency" posts forums get.genegold99 thank you for attention. I used the emergency word to stress both my urgence and a bit of humour. "missing"? anyway, not important to that extent. first of all, I skimmed the pages of the thread especially from beginning to 50s and also made a search with in the thread with u2311h keyword and read them all. Some of them were about DV's review about pixperan response time issue and few of them related to my comparison of 2311h.
I compare these monitors because they are affordable for me. ok, why the situation is urgent? because the company that brings dell monitors has a limited days for discount and there is no other company own that monitor-2412m. therefore, I need to go for one of the monitors immediately, probably in 2 hours aprox. I saw this forum while I was making research about this comparison, 2311h 2412m. I asked 16:9-10 ratio question because it is related to both computers and the comparison. I just wanted to find some people who use them both, I wrote my needs, and as I am not experienced and did not use any of them, I asked for which one can fit to my needs. I wanted final words for those who are also in between 2311h and 2412m.
Excuse me for some of my general and specialized questions, that I explained why, but I am sure some of the users will voluntarily reply it and help for my situation and give a vision. if i was impatient then i do not make a research for one week and write such a post. thank you anyway.
received my 3 this afternoon, took a few minutes to check bleed/pixels. for the most part they look great, although i can't tell if i'm looking at ips glow or back-light bleed on one of them
my new galant and fxtristand arrive this weekend, i'll play with settings more and post some pics after i set everything up
Has new Dell monitors been released?
It may have been me. I pondered doing a bezel strip across the 3. I might still do it one day.
But having pulled the front bezel off to take a look (pull from the inside with something flat to protect the panel surface, on the OPPOSITE side to the OSD control buttons) I decided it wasn't worth doing at the moment. The bezels don't really bother me that much, and the panel is reasonably flush against the outer plastic. You'd still gain about 2-3mm on each bezel I think, though.
small update...I noticed a small issue.....right part of the screen (very narrow area, just within the bezel, maybe 3 mm wide; from bezel towards the screen center) from top to bottom of the screen has a barely noticable backlight bleed (if it is backlight bleed I dunno, but on that part the screen is brighter). But its barely noticable. My wife didnt noticed and I have a better eyesight (almost perfect). This is not really an issue but it looks like the film is not centered on the screen, like its moved to the left by 3mm and some lighter parts popped in in 3mm wide range. I will see if that will be sorted out in next few days. If not - no probs since its really almost non existing for naked eye. I noticed that only when I stare at that part or when I change the brigtness drastically.
The big problem is the bezel is basically keeping the panel in place. It's otherwise held on to the electronics by cheap fabric electrical tape. You completely remove the bezel and the panel just falls out and separates from the electronics.
I almost ended up having it fall out of my hands. Good thing for my super-panic reaction time or the panel would have ended up leaving a dent on my floor
Beware
New review on Tomshardware:
24" LCD Round-Up: Acer S242HL, Dell U2412M, And Samsung T24A550
The Dell took top honors.
Of course it did, they compared a 1920x1200 IPS monitor to two 1920x1080 TN monitors. I guess they are learning how to review monitors?
Been thinking of getting one of these, any significant ghosting?
Somebody else earlier asked about disassembling this monitor earlier in the thread. I'll put it lightly:
DO not disassemble the monitor. Putting it back together is painful and the construction is not made for servicing.
Trust me on this.
Also it won't help with the backlight bleed. The backlight bleed is definitely from the panel seated in the assembly and not being perfectly straight.
Just thought I'd let people know
Do you have pictures of internals of this LCD?
Is panel floating alone or is it screwed to the electronics behind?
I'm quite sure the backlight is caused by curved panel (as you can fix it temporarily by manual twist) - so is it curved panel alone or some other parts have their own 3 pennies in that?
ok - last question
USB ports PCB is attached to panel or back case part?
