Stryker7314
- Apr 22, 2011
The input lag test causes concern, I thought it should be near 0 with the g-sync ultimate module installed :
He's demonstrating the extreme but depending on a viewers seating distance preference it's important because even on a IPS you can lose some saturation at the edges on a display this wide when seated at a desk that isn't super deep. This monitor basically allows for ideal viewing conditions in any ergonomic position a user pleases.I don’t get the viewing angle hype for a monitor. I’ve never had a monitor not be directly in front of me when viewing it…
TVs are a different story.
The majority of modern ultrawide monitors of this size are curved in towards the user making this largely a non-issue. I’ve used three IPS Ultrawide monitors since 2017 on both deep and shallow desks. One had trace amounts of backlight bleed on the edges due to being edge lit, but not anything tied to my viewing angle when looking at the monitor from my seating position.He's demonstrating the extreme but depending on a viewers seating distance preference it's important because even on a IPS you can lose some saturation at the edges on a display this wide when seated at a desk that isn't super deep. This monitor basically allows for ideal viewing conditions in any ergonomic position a user pleases.
Seems like you sit ergonomically and proper position. Great! What was being showcased was for others who don't, have multiple monitors, move throughout the day, etc. Someone is just excited to finally have amazing viewing angles is all it is.The majority of modern ultrawide monitors of this size are curved in towards the user making this largely a non-issue. I’ve used three IPS Ultrawide monitors since 2017 on both deep and shallow desks. One had trace amounts of backlight bleed on the edges due to being edge lit, but not anything tied to my viewing angle when looking at the monitor from my seating position.
Now my OLED TV on the other hand is a god send since some seating positions are very much off at an angle in my living room.
You aren't sitting right in front of all your monitor. The sides are off axis to you, generally by as much as 30-40 degrees, even more depending on how close you sit. Curves can help mitigate that, of course. But that is why it matters, the edges are not viewed straight on so you see shift.I don’t get the viewing angle hype for a monitor. I’ve never had a monitor not be directly in front of me when viewing it…
New video from Vincent discussing some of the downsides.
Definitely, me too. 38" is the only way. The only thing that my current 38S is missing is the OLED black color. It tries really hard to emulate, but no, man, this is no oledTo each their own. I’m still looking forward to the first QD-OLED 38”!
I'd love to see a 38" QD-OLED but I think it's too niche of a market at this point in it's evolution.Definitely, me too. 38" is the only way. The only thing that my current 38S is missing is the OLED black color. It tries really hard to emulate, but no, man, this is no oledNice try though 🙂
It’s a smaller market than the 34” size but grew quite a bit in popularity the past couple of years. So it makes sense starting with the 34” and then release a 38” in the next couple of years.I'd love to see a 38" QD-OLED but I think it's too niche of a market at this point in it's evolution.
Congrats!Just got mine delivered today despite Dell originally saying 4th of May.
Man, what a monitor, absolutely stunning! Yes, text can be a slight issue but I've already gotten used to it and it's a downside worth paying given just how good the PQ of this monitor is
Should probably use LCD cleaning wipes or maybe camera lens wipes. I've had that issue before with LCD's.Fellow owners, another thing to be cautious about. This thing is near impossible to clean. Even with a microfibre cloth it can still make microscratches in the AG coating
The way I'd describe it is that the colors on the Alienware screen look more pure than the colors on the CX I have since QD-OLEDs don't have the extra white sub-pixel that can dilute the colors.Anyone with this screen and a LG CX/C1 OLED want to post their views here?
Are the colors really that more vibrant? If you had to only have one screen what one would you choose?
I'm trying to get as much info I can before the 42" release.
Does the manual say anything about automatical refresh? Then it would be better to not do manual refreshes.If you guys see lines appearing on your screens like image retention/burn-in, then do a panel refresh. It sorted mine that developed the last couple days.
Before:
After:
4 hour pixel refresh would probably take care of it also, without causing as much panel wear as the 1500hour/manual refresh.You can do a manual refresh whenever you like, the manual even points to this fact. The manual also states that a panel refresh happens every 1500 hours (via a prompt on the OSD), a pixel refresh happens every 4 hours (or at the 20th hour if you skip the 4 hour prompts). Panel refresh takes 1hr to complete, pixel refresh takes 7 minutes to complete.
Did you turn the monitor off? IIRC it should do it while its turned off, in in standby power.I'd already ran a pixel refresh as the PC has been on all day so a pixel refresh would have ran at least twice by the afternoon. Only the panel refresh sorted it.
Yes it /only/ runs when the monitor is powered off with the button or enters standby via the sleep command from the OS like when you shutdown/sleep or the display sleep state is activated when idle.Did you turn the monitor off? IIRC it should do it while its turned off, in in standby power.
I have a feeling, with this panel and the 42" LG, that OLED will be anything but "niche" by next year.I'd love to see a 38" QD-OLED but I think it's too niche of a market at this point in it's evolution.
