I am hoping a 7900xtx will run it well at 4kthis is the only game where I wish I had a 4090
I'm in the same 'hope my 3080 can run it decently'. Can't see buying a 4x series, the actual upgrade is so small in most situations that it would have to come down in price fairly dramatically for me to be interested.
4090 is around double the speed of a 3080, and it has frame gen to take into account beyond that. It's even faster in raytracing. That's not my definition of a small upgrade . Personally I'm sticking with my 3080 until the 5xxx series.I'm in the same 'hope my 3080 can run it decently'. Can't see buying a 4x series, the actual upgrade is so small in most situations that it would have to come down in price fairly dramatically for me to be interested.
Same.I game at 1440p so I'm hoping the 3080 can handle path tracing at around 45-50+ fps (DLSS Quality)
True, but 3080 to 4090 is a generation and a level upgrade. And would make the video card worth more than the rest of my entire setup (esp. after waterblock). I'm holding for the 5xxx.4090 is around double the speed of a 3080, and it has frame gen to take into account beyond that. It's even faster in raytracing. That's not my definition of a small upgrade . Personally I'm sticking with my 3080 until the 5xxx series.
Frame gen isn't even needed on the 4090. I get around 60-80 FPS at 4K with DLSS upscaling set to Quality and all the path tracing options turned up to their maximum settings. Without DLSS I get 30-40 FPS.4090 is around double the speed of a 3080, and it has frame gen to take into account beyond that. It's even faster in raytracing. That's not my definition of a small upgrade . Personally I'm sticking with my 3080 until the 5xxx series.
This a Standalone expansion?
Pinned by ACG
@ACGreviews
43 minutes ago
CDPR requested that only B footage and trailers be used. I was impressed by the continued slow chopping away of perf issues and the 2.0 update over the top of a solid expansion that has a good number of acts and some unique continued gig types that never really stop.
Depending how it look and run (Frame gen figure so one would need to try, the numbers not telling all the story), if RT Overdrive play well on a 4060 at 1080p and 4070 at 1440p, not a bad place to be at all.Official Performance charts
https://www.techpowerup.com/313784/...zes-nvidia-dlss-3-5-full-ray-tracing#comments
Unless you have problems I wouldn't bother. A while back I was later than usual in updating my driver and Diablo would give me a warning when I started it but it really didn't matter much.I have a RTX-4080 haven't updated my driver in a few months. I'm assuming there's a brand new driver specifically for this game being released or just released recently?
Can my rig run this game maxed out at 3440 X 1440 res on my OLED monitor?
i13900k
32GB DDR-5
RTX-4080
Solid State Drive
PT was already available for the 3080 and frame rate is going down, not up with this patch and DLSS 3.5. Think I got 35fps or so with DLSS balanced at 1440p when I tried it. It will look nice with RT though, which is the point of DLSS 3.5 and it's improved ai based denoiser. Probably also some other improvements as well now that they can kind of "drop" old hardware as in the old consoles and stuff.I game at 1440p so I'm hoping the 3080 can handle path tracing at around 45-50+ fps (DLSS Quality)
That's a huge difference and kinda makes me question the testing... I could absolutely see some positive difference with the denoising now being rolled into the upscaling step, but a 50% gain just from being able to skip NRD seems suspect. FWIW, benches of Cyb with Frame Generation have occasionally resulted in odd results because toggling FG automatically sets DLSS upscaling to "Auto" regardless of the previous scaling setting and if the reviewer misses that, it can throw off the comparison if they meant to have DLSS set differently- I've seen it happen before and I wonder if that's what's going on here. 50% gain just from combining the denoising and scaling just seems too much.On Overdrive, with the path tracing tech demo at 4K, and with DLSS set to Quality and Frame Generation set on, I was getting 69 fps on average...but with Ray Reconstruction enabled that leapt up to 103 fps simply from ditching that denoising step...that makes Ray Reconstruction an absolute must for high-end GPUs running ray tracing...
TPU had to re-do all of their Ampere and Ada numbers after publishing, due to the Ampere numbers being incorrect for some uncommunicated reason. And the Ada numbers were originally posted with Frame Gen turned on.That's a huge difference and kinda makes me question the testing... I could absolutely see some positive difference with the denoising now being rolled into the upscaling step, but a 50% gain just from being able to skip NRD seems suspect. FWIW, benches of Cyb with Frame Generation have occasionally resulted in odd results because toggling FG automatically sets DLSS upscaling to "Auto" regardless of the previous scaling setting and if the reviewer misses that, it can throw off the comparison if they meant to have DLSS set differently- I've seen it happen before and I wonder if that's what's going on here. 50% gain just from combining the denoising and scaling just seems too much.
I'm in the same boat. I think the 40 series is shocking price to performance and my 3080 is weeping at the prospect of these new ray tracing updates. I just wish frame generation could be jury rigged into the 30 series somehow.I'm actually slightly considering getting a 4090...especially if the rumors of the next-gen Nvidia GPU's not arriving until 2025 are true...I could hold out until mid-2024 but 2025 is a long wait...then again $1700 for a GPU seems crazy
4070 ti is only 15-25 fps better than a 3080 at 1080p and 1440p, with and without ray tracing. At 4K its a wash. Some games the 3080 closes the gap more, because it has more bandwidth than the 4070 ti. Or if the game is a couple of years old, the 3080 has a more optimized driver profile.I'm in the same boat. I think the 40 series is shocking price to performance and my 3080 is weeping at the prospect of these new ray tracing updates. I just wish frame generation could be jury rigged into the 30 series somehow.
Not sure I could pony up for a 4090 but maybe a 4070 Ti if the price is right. Feels like it would be more of a side-grade rather than a generational leap though. 2025 for new cards is kinda depressing.
Phantom Liberty Benchmark Test & Performance Analysis Review
With DLSS enabled, in "Quality" mode, the RTX 4090 gets 47 FPS at 4K—much more playable...if you enable DLSS 3 Frame Generation on top of that, the FPS reaches a solid 73 FPS...without DLSS upscaling and just Frame Generation the FPS rate is 38 FPS at 4K, but the latency is too high to make it a good experience, you always need upscaling
the review embargo for DLSS 3.5 Ray Reconstruction hasn't expired yet, we will follow up with a separate article very soon...
https://www.techpowerup.com/review/...-liberty-benchmark-test-performance-analysis/
