I will be starting new and fresh. Gameplay is just so much fun.So I haven't played CB in like a year or so, my character finished the main story and was left with a bunch of sidequests.
Question
I am thinking of buying it again, but on Steam @ $29, as I'm not a fan of Epic Game Store, and if I buy on Steam it would be a new game then, starting from scratch. And per the Forbes article, that guy is a huge fan of the 2.0 update and PL, but he says start the game now with 2.0 and then do PL.
Would you recommend I start a fresh brand new game, but now it will be version 2.0.
Patch is up. 29.4GB on PC.
They always do!I'm gonna be doing a fresh character when I get phantom liberty, i might be waiting a few weeks though, I still have a massive backlog of other recent titles to go through and I have a feeling that a few hotfix patches are gonna follow the main 2.0 release.
Need to play Postal 4 for more realistic policeI loaded up the new 2.0 patch.. Aimed my gun at a cop.. And nothing happened lol. Thought this was suppose to be fixed lol
8 posts up. You can select Phantom Liberty from the main menu like The Witcher 3 with Blood & Wine.Have they said if you can just play Phantom Liberty, kind of like TW3 expansions? Haven't been able to keep up with all the gaming news.
- Removed the silencer slot from Revolvers.
- Removed the scope slot from Light Machine Guns.
I am hoping a 7900xtx will run it well at 4k
I don't recommend removing a bounce. It drastically affects the image quality and makes the game look half finished. Better off going to one of the standard ray tracing modes.4k might be a stretch. But you can tap around the 50's @ 1440p with FSR 2 @ Quality. But you have to mod the PathTracing to 1xRay, 1xBounce and RIS to pull it off.
This mod lets you do that.
https://www.nexusmods.com/cyberpunk2077/mods/8059
and you can improve FSR2's quality considerably by using this mod...
https://www.nexusmods.com/cyberpunk2077/mods/7445
Also it's instructions can be followed to enable a form of FSR 2 Native AA... which is also handy if you just want an Anti-Alasing alternative.
Is keanu also in the DLC?
I agree I tested it out yesterday and DLSS Quality@4K was the only setting that Ray Reconstruction looked decent with. Might test out higher res DLSS with DLSS tweaks tonight if I need a break from Lies of P.So, after some more testing, Ray Reconstruction is far from perfect. In my opinion, everything below 4K + DLSS quality should be ignored. At lower DLSS levels, the image appears, apart from the significantly stronger ghosting, as if a certain cartoon filter were applied. Just like you know from an app:
[https://play-lh.googleusercontent.c...1DG9nZt3QZg7aXbYlhpuX4ec3U58UE8EcmUbCf1ZmnEc8]
Of course it's an extreme example, but I immediately thought of it.
This is particularly noticeable with DLSS Ultra Performance.
With 4K + DLSS quality I can still see some of it, but far far less. Overall for me, the advantages outweigh the disadvantagess at 4K DLSS quality, so I will definitely use it when playing Phantom Liberty.
The AI behind RR still has to learn a little bit more I guess![]()
Alex called it posterization, here at 20:30:I agree I tested it out yesterday and DLSS Quality@4K was the only setting that Ray Reconstruction looked decent with. Might test out higher res DLSS with DLSS tweaks tonight if I need a break from Lies of P.
Ray Reconstruction is ok, but its in the early stages, kind of like DLSS1 was just ok. It should improve within a few years.
Lowing image sharpening kind of resolves this effect. I'm testing right now and I actually really like the image quality with sharpening at 0. My only major complaint with RR is that in low lit areas the faces blur pretty bad. The trans woman in Afterlife.. her face looks better with the original denoiser than with RR. I hope this is fixed soon, because the more I test out RR, the more I like it. Still at DLSS Quality@4K only, the image quality loss is apparent at anything lower.Alex called it posterization, here at 20:30:
