davemm said:
archevilangel said:![]()
My tforce 6100 939![]()
MC FLMJIG said:I would have loved to have seen a pic live...
I c wat ur saying though. Would the placement o the Biostar cpu area allow it? I just can't see it. There is a PSU there but I wouldn't know... I have an SI 120 and that 4 dure won't fit.
If i get Preslers and then.. Conroe maybe I'll try it... I doubt a Zalman 7700 would be enough for an OC.
Yeah it fits, the powersupply clears the xp-120 + fan.MC FLMJIG said:I would have loved to have seen a pic live...
tiger6400 said:HI Guys,I am new to this forum and would just like to thank you all,I can't believe how much I've learned from you guys in such a short time,I knew nothing of overclocking just a few weeks agk here it goes,I've got the TforceSLI Board running a athlon64 3200,I have it at 270 x 10 with the HTT set to 4x, I would like to set the the HTT to 3x and overclock further,But just like the 6100-939 board the HTT is locked at 4x, You guys have ben talking about a mod bios for the 6100-939 is there a mod bios for the TforceSLI so I can drop the HTT to 3x, If not can 1 of you guys mod one for this board thx guys.
buzzly said:I have been Priming a Opteron 144 at 325x9 = 2930 on my second Tforce6100-939 for a few hours this morning. Voltage is at 1.44v. Look like I got a good board.
BTW, the stepping for the Opty 144 is cacje 0602gpmw.
sabrewolf732 said:Hmm, make sure you drop the upstream and downsteam both in the oc menu and in advanced chipset menu to 3. Also, drop your ram divider to 133 (to eliminate ram as a variable). Get back to us after trying that.
sabrewolf732 said:did you drop the chipset htt multi to 3 in both menus?
Ice_Wewe said:Hey all,
"I have a Biostar TForce 6100-939 that I bought in December. I think it had a BIOS from like July of '05 on it, so I flashed it with the newest at the time. I used their auto OC program, but I can only run V6 and V8, V12 causes instability. I have an AMD64 3200+ Venice 2.0Ghz. I've heard that this CPU can do more than 2.7Ghz. I'd like to see if it can do that, but I have a few problems. I just flashed my board with the CU51M306.BST BIOS, and I'm still having problems."
It's not guaranteed that your processor will hit 2.7 Ghz. It will depend on the processor stepping that you have. Be careful with the auto OC program. I have the skt 754 version and the V12 setting pumped >1.7 volts (!!!) through the processor. I shut that down as soon as I could and fortunately, my processor (E6 Sempron 2800+) is ok. It's priming at 300x8 at 1.45v right now.
Serge84 said:My Crap powersupply drops to 11.65 at high OC's. o.=.O Thats whats been limiting my OC the whole time, I have a weak 12v rail and my cpu isn't getting enough power. I'm going to spend a good 80 bucks on a Kick ass Ultra powersupply with dual rails. I'll put a 500Watter in this baby with dual rails. If you don't have a expencive powersupply with low amps at 20A in the 12v then it sucks bad. Maybe some ppl here are having that prob, CPU needs more Amps. If your voltage in your rail drops to or below 11.65 it is very unstable. My PSU will have atleast 35A/40A amps in dual 12v rails.
I have reached very nice 350+HT in my OC's check sig. Highest HT OC i ever reached was 390 before my PSU supplyed about 11.45v in the rail then afew sec's my system cut off. No errors, no freazes nothing... yes this isn't the limit of my cpu all along. With a new PSU I'll reach 3ghz stable. I can reach bloody 2980mhz... no errors, passed 2.81ghz most of the time power just cuts off after that, all stable 24/7 at 2.8Ggz. Sometimes I get lucky and reach about 3ghz. Depends if its not stressing the cpu cus as soon as it goes to ateast 25% power cuts off for no reason. Could run 2980 all day only as long as the power doesn't drop in the 12v rail. Bastard powersupply was the bugger all along each time I monitor that now. My god, but at the time all I could get was a cheap 350watt PSU. >__> Time to change that... XD
I'll try the new bios soon that just came out ver 300 it was. They added new memory timmings that take it upto 17.
Here is my condition.
http://img480.imageshack.us/img480/568/img12630ow.jpg
That is maximum setting that my computer will still boot. It will boot with higher settings, but only AFTER S.R.S has reloaded the BIOS settings and set them back to default. I've heard of people getting 292 clocks... my thought is,wtf?! Why wont my mobo get that? I've tried going higher with the SB and NB at 4x, it doesn't work. I've tried it at 3x, it still doesn't work. I'd love to get this worked out before I invest in an Opteron, because the board is useless to me if I can't OC the Opteron. Thanks for the help.
tiger6400 said:It still looks like you have an old Bios. You say you flashed it in December. The latest Bios for that board is 3/7/2006 You can find it here http://www.biostar.com.tw/t-series/products/socket 939/tforce6100-939/product_details.php and you might want to check to see if you have the latest chipset drivers also, Don't forget to uninstall your Graphic driver first if you install new chipset drivers,Good luck let us know how it works out.
drteming said:Ice_Wewe said:Hey all,
Yes, my system becomes unstable when running the V12 program. The V8 program on the December BIOS ran my CPU at 1.6x volts, the 3/7/2006 BIOS with the V8 program, runs it at 1.52V. Just proving, once again, that Biostar has no clue on what settings are approate when overclocking.
And yes, my CPU is a Venice core, which has time and time again, has hit above and beyond 2.7Ghz. I'm running it at 2.4Ghz right now. I still feel it's not meeting it's full potential.
Also, could someone please give me a time frame for when AMD is going to discontinue the Opteron 1xx line? I did some googling, and found some people talking about it, but I don't have any dates. Even if it's a guess, that'd be great. I'm planning on replacing my 3200+ with a Opteron 165.
Biostar doesn't say this board supports and Opteron CPUs, anyone have an Opteron working on a TForce 6100-939?
EDIT #1:
I don't know the stepping on my CPU. I neglected to take a picture of it before I installed it.
EDIT #2:
Ok, CPUZ reports it as...
AMD Athlon64
Venice Core (Brand ID 4)
Family F
Model F
Stepping 0
Ext. Family F
Ext. Model 2F
Revision DH-E3
Instructions:
MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Ok... and if that didn't give you enough data, here is a picture of CPUZ.
Gio said:Ice Wewe - The board supports the Opteron fine (see my sig)
As Serge84 mentioned a strong power supply is needed for overclocking. Look more at the amps of the 12v rail then the overall watts. Not sure if this may help some, but on my perticular overclock the K8 > NB is at 16X, but my NB > SB is at 8. It wont post at my current settings unless I lower the northbridge to southbridge Transport.
Tiger6400 - The bios link you posted does show a date of 3/07/06 but if you check the bios file it's still from 1/27 (cu51m127.bst). I downloaded the newest one from the link posted before by JWilson here
There is finally the option to disable the splash screen as well as a couple new memoy options. I did notice my SATA drive now shows up in the bios in the first screen as well as Floppy Controller seems to be gone?
tiger6400 said:Ice wewe I'm running the athlon64 3200 venice right mow at 270 x 10 = 2.7ghz.@1.55V the only difference that I can see is that I'm running a HT Frequency at 4x and I don't have that watch dog setting I'm running the Tforcesli board.From what I've read the Opteron runs just fine.I would't run that v12 in bios sets the volts way to high I would leave it to manual.what do you have for memory?Do you have them in the right slots.For dual chan.They should be in slot 1 and slot 3 or in slot 2 and 4 same colored slots if so try loosening the timing a little bit maybe start with 2.5.4.4.10.
Serge84 said:Yes yes, and I'm getting one of these.
http://www.newegg.com/Product/Product.asp?item=N82E16817148008
http://www.newegg.com/Product/Product.asp?item=N82E16817152025
One is single and another is dual 12v railed, I think I'll go with the aspire. Not sure whats up with the reviewer saying about a powersupply effected my your OCing when its that strong of one. Anyways what would you all pic? Think i would have the same prob with that RAIDMAX? Or any others that maybe better?
